UTGX6JC10E7S
UTGX6JC10E7S
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    CONN PLUG FMALE 7POS SOLDER CUP
UTGX6JC10E7S 数据手册
- UTGX6JC-----P 8 7 Operating temperature: -40 C up to 105C Insulation resistance: 5000 min M Corrosion salt spray: 500 hours Durability: 500 matings and unmatings Sealing conditions: SEE TABLE WIRING AREA (between insert and backshell seal) E4 WIRING AREA (between insert and backshell seal) E3 6 NOTA: 4 1- Contact to be ordered separately for version UTGX6----- : refer to corresponding catalogue. 2- Insert arrangement refer to: UTO-CONTACT-L-C02 (Female insulator) UTO-DHP-003-C01 (Female insulator #20) UTO-DHP-002-C01 (Female insulator #16) 5 UTO-CONTACT-L-C01 (Male insulator) UTO-DHP-003-C01 (Male insulator #20) UTO-DHP-001-C01 (Male insulator #16) Sealing in MATED conditions with COUNTERPART: Sealing in MATED conditions with COUNTERPART and UNMATED conditions: C144-UTS1-A (HiSeal Version) 3- This part shall be used at the place of the -IP68 1 bar during 1 week: immersion under 10 m of water. (IEC 60529) -IP68 1 bar during 1 week: immersion under 10 m of water. (IEC 60529) -IP69K : exposure to high pressure water of cleaning equipement -IP69K : exposure to high pressure water of cleaning equipement standard seal to accomodate with different cable (DIN 40050) (DIN 40050) 4- Plug, backshell and the reducing seal are delivered a a kit. The backshell already includes the standard seal. THREAD COUPLING RING BACKSHELL BODY 3 HEXAGON D (See tightening torque in table) CONDITIONS 5 SEALING SHELL :PA UL94 V0, UL746C F1 Black color COUPLING RING: PA + Nickel-plated brass BACKSHELLS : PA UL94 V0 F1 Black color BACKSHELL Seal : CR INSERT (UTGX0-----) : PA UL94 V0, UL746C F1 INSERT (UTGX0--E---) : Polychloroprene O'RING : NITRIL MATING SEAL : SILICON CONTACTS: brass + coated depending on P/N PERFORMANCE CHARACTERISTICS : BACKSHELL SEAL BACKSHELL NUT CountryJurisdiction& Control List FR NOT LISTED A MAX INSERT SHELL PLUG MATING SEAL O'RING P/N : CROSS REF TABLE SHELL TYPE 2 MAX STANDARD MAX THREAD CLASS 2A 10% (g.) 1 D Tightening torque (N.m) E1 E2 E3 E4 1.5 / 5 18.5 1 21 34.1 29 33.5 9/16-24 UNEF 30 5 / 12 3 / 9 24 2 25 38.1 33 37.5 11/16-24 UNEF 40 7 / 14 5 / 12 26 2.5 29 42.1 36 40.5 13/16-20 UNEF 53 A B C 10 12 14 TYPE OF CONTACTS P: MALE S: FEMALE TYPE OF LAYOUT Standard layout (No digit) E : HISEAL Handsolder contacts INSERT ARRANGEMENT See NOTA 2 14/02/2020 10 26.2 66 2.5 / 8 12 29.7 69 14 34.6 75.5 Scale 3/2 G F E D -Update drawing -- 25253J Latest modification - by: J.FEURPRIER PE.LANDAIS Date:10/05/19 C A2 CUSTOMER DRAWING MOD N 3 2 PLUG T6 WITH BACKSHELL JC - SIZE 10 12 & 14, Standard and Hiseal version UTGX CONNECTOR Dimensions in mm General linear Tolerances: 0.2 www.souriau.com FORMAT H DATE TITLE MASS Normal (no digit) W,X,Y,Z SHELL SIZE Designed by: HEXAGON backshell nut Plug JC ISS MAX 6 * P/N for example BACKSHELL B SHELL SIZE UTGX 6 JC 14 E 19 P BASIC SERIES B MAX REDUCING SEAL (NOTA.3) 4 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) CAPACITY C 6 UTGX6JC-----S 7 COMMON QUOTES FOR ALL VERSION A UTGX6JC--E--WIRING AREA (between insert and backshell seal) E2 WIRING AREA (between insert and backshell seal) E1 B C D E F G H UTGX6JC----- MATERIAL : 8 B.3; Validé SIDE VIEW FOR EACH VERSION SOURIAU DRG N° UTGX-0005A-C B NPRDS / PROJECT GBB This document is the property of SOURIAU It must not be reproduced or communicated without permission SHEET 1 / 1 A 1
UTGX6JC10E7S
物料型号:UTGX6JC,有不同版本,如UTGX6JC----、UTGX6JC--E--
器件简介:文档描述了一种连接器,包括其外壳、接触环、后壳、密封圈、接触件等部件的材料和特性。
引脚分配:文档中提到了不同版本的连接器,但未明确列出具体的引脚分配
参数特性:操作温度范围为-40°C至105°C,绝缘电阻至少为5000 MΩ,耐盐雾腐蚀500小时,耐用性为500次插拔,密封条件见表格。
功能详解:连接器在连接状态下和未连接状态下的密封性能,分别满足IP68和IP69K标准。
应用信息:文档中未明确提供应用信息,但根据连接器的参数特性,可能适用于需要高密封性能和耐腐蚀性的场合。
封装信息:提供了不同尺寸的后壳和六角螺母的尺寸和紧固扭矩信息。
UTGX6JC10E7S 价格&库存
很抱歉,暂时无法提供与“UTGX6JC10E7S”相匹配的价格&库存,您可以联系我们找货
