Additional Resources:
Product Page
PCB Footprint
date
09/01/2020
page
1 of 4
SERIES: MD-CV │ DESCRIPTION: MINI DIN CONNECTOR
FEATURES
• panel mount
• locking nut
• plastic bushing
RoHS
PART NUMBER KEY
MD - XX CV
Base Number
Notes:
Pin Options
30* = 3 pins
40 = 4 pins
50* = 5 pins
60 = 6 pins
80 = 8 pins
*Discontinued models MD-30CV & MD-50CV
SPECIFICATIONS
parameter
conditions/description
min
rated input voltage
rated input current
typ
max
12
at 12 Vdc
contact resistance
insulation resistance
at 250 Vdc
voltage withstand
for 1 minute
9
operating temperature
-20
life
UL94V-0
yes
A
mΩ
250
Vac
45
N
30
N
85
1,000
RoHS
2
30
MΩ
insertion force
flammability rating
Vdc
50
withdrawal force
cuidevices.com
units
°C
cycles
Product Page
PCB Footprint
CUI Devices │ SERIES: MD-CV │ DESCRIPTION: MINI DIN CONNECTOR
date 09/01/2020 │ page 2 of 4
MECHANICAL DRAWINGS
units: mm[inches]
tolerance:
X.X ±0.2 mm
X.XX ±0.10 mm
X.XXX ±0.050 mm
X.XXXX ±0.030 mm
MATERIAL
PLATING
earth terminal
brass
nickel
terminal contacts (1~8)
phosphor bronze
tin
housing
PBT (UL94V-0)
black
nut
PBT (UL94V-0)
black
RECOMMENDED
PANEL CUTOUT
MD-30CV
MD-40CV
3
4
2
1
2
MD-50CV
3
4
5
1
3
2
1
9.4 0.370
9.4 0.370
5.6 0.220
3
5.6 0.220
0.40 0.016
1
2
0.90 0.035
(3 PLCS)
PCB LAYOUT
TOP VIEW
4.6 0.181
1.60 0.063
1.9 0.075
4
0.40 0.016
2
0.7X1.3
(2 PLCS)
5
3
1
PCB LAYOUT
TOP VIEW
2.70 0.106
0.90 0.035
(5 PLCS)
1.00 0.039
PCB LAYOUT
TOP VIEW
cuidevices.com
0.7X1.3
(2 PLCS)
Product Page
PCB Footprint
date 09/01/2020 │ page 3 of 4
MECHANICAL DRAWINGS (CONTINUED)
MD-60CV
6
MD-80CV
8
5
4
2
7
2
1
6
4
5
3
3
1
PCB LAYOUT
TOP VIEW
PCB LAYOUT
TOP VIEW
cuidevices.com
Product Page
PCB Footprint
date 09/01/2020 │ page 4 of 4
REVISION HISTORY
rev.
description
date
1.0
initial release
02/23/2006
1.01
new template applied
02/20/2012
1.02
updated datasheet
09/01/2017
1.03
discontinued models MD-30CV and MD-50CV, brand update
10/08/2019
1.04
updated housing
11/19/2019
1.05
updated PCB footprints
09/01/2020
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“MD-30CV”相匹配的价格&库存,您可以联系我们找货
