FGG.1B.304.CLAD62Z
FGG.1B.304.CLAD62Z
    LEMO(雷莫)
    FGG.1B.304.CLAD62Z
FGG.1B.304.CLAD62Z 数据手册
FGG.1B.304.CLAD62Z www.lemo.com SUMMARY # Wires Low voltage 4 Image is for illustrative purpose only Series 1B Termination type Male solder IP rating 50 AWG wire size 30.00 - 22.00 Catalog Cable Ø 5.30 - 6.20 mm See video assembly instructions Status active Matching parts EGG.1B.304.CLL Download Request a quote Eplan PHG.1B.304.CLLD62Z TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet and nut for fitting a bend relief Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 15.55 g Performance Configuration 1B.304 : 4 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 10 Amps Specifications Contact Type: Solder Contact Dia.: 0.9 mm (0.035in) Bucket Dia.: 0.8 mm (0.031in) Max. Solid Conductor: 0.34 mm^2 (AWG 22) Max. Stranded Conductor: 0.34 mm^2 (AWG 22) R (max): 4.8 mOhm LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Vtest (contact-shell): 1450 V (AC), 2050 V (DC) Vtest (contact-contact): 1350 V (AC), 1910 V (DC) Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A L M S1 S2 mm. 12 42 31 10 9 in. 0,47 1,65 1,22 0,39 0,35 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Spanner wrench: DCD.1B.015.PA090 Caps: BFG.1B.100.PCSG Cables 4220 PVC Black LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.1B.304.CLAD62Z 价格&库存
很抱歉,暂时无法提供与“FGG.1B.304.CLAD62Z”相匹配的价格&库存,您可以联系我们找货
FGG.1B.304.CLAD62Z
    库存:112
    FGG.1B.304.CLAD62Z
    • 1+358.169331+46.49620
    • 10+304.4258210+39.51942
    • 30+281.7246630+36.57244
    • 50+271.7560850+35.27836
    • 100+258.79672100+33.59602
    • 250+242.61665250+31.49559
    库存:242
