EGA.0B.307.CLL
www.lemo.com
SUMMARY
# Wires
Low voltage
7
Image is for illustrative purpose only
Series
0B
Termination type
Female solder
IP rating
50
AWG wire size
34.00 - 28.00
Cable Ø
0.00 - 0.00 mm
Status
active
Matching parts
FGA.0B.307.CLAD52Z
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
EG*: Fixed receptacle, nut fixing
Keying
2 keys (alpha=30, plug: male contacts, receptacle: female contacts)
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
4.37 g
Performance
Configuration
0B.307 : 7 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
2.5 Amps
Specifications
Contact Type: Solder
Contact Dia.: 0.5 mm (0.02in)
Bucket Dia.: 0.45 mm (0.018in)
Max. Solid Conductor: 0.09 mm^2 (AWG 28)
Max. Stranded Conductor: 0.09 mm^2 (AWG 28)
R (max): 8.7 mOhm
Vtest (contact-shell): 700 V (AC), 990 V (DC)
Vtest (contact-contact): 800 V (AC), 1130 V (DC)
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Others
Endurance (Shell): 5000
Temp (min / max): -55°C / +250°C
Humidity (max): 1000 hr
DRAWINGS
Dimensions
A
B
E
L
M
N
S1
S3
e
mm.
10
12.5
7
20.7
1.2
19.1
8.2
11
M9x0.6
in.
0,39
0,49
0,28
0,81
0,05
0,75
0,32
0,43
RECOMMENDED BY LEMO
Tools
2/3
Cables
CMN.07.T28.044PGZE
Grey
CMN.07.T28.044PNZE
7041
PVC
Grey
7050
PVC
Black
717920
PVC
Grey
CTR.75.030.121875G
PVC
Grey
3/3
很抱歉,暂时无法提供与“EGA.0B.307.CLL”相匹配的价格&库存,您可以联系我们找货
