PM108FRAOHB
PM108FRAOHB
    ANDERSON
    POWERMOD 1X8FEMALE RIGHT ANGLE P
PM108FRAOHB 数据手册
PowerMod® One Row - Female The PowerMod® connector family offers minimum size and high power. The high performance contacts and insulator are rated for 30 amps continuous. Applications requiring lower operating temperatures can be de-rated using our current-temperature chart. FEATURES • High performance contacts Rated to 30 amps per IEC 512-3 • Mechanically polarized housings Only mate one-way, ensuring proper mating The one row female PowerMod connectors are offered in 3, 4, 6 and 8 circuit sizes. The connectors are available with straight crimp, straight PCB or right angle PCB contacts. • High reliability positive retention latches Are made from stainless steel to provide optimum performance APP connectors are manufactured using the finest materials and world-class manufacturing processes. They embody the highest quality in the industry and meet all applicable industry standards. • PCB, panel or cable mounting A wide variety of contact styles with optional mounting brackets, panel clips and back-shell hoods provide broad design flexibility SPECIFICATIONS Electrical Mechanical Current Rating Mating Cycles No Load per IEC 512-5 1,000 30 Mating / Unmating Force per IEC 512-13 10 oz (3N) avg. UL / CSA Voltage Rating (AC/DC) 600 Contact Retention per IEC 512-8 Creepage / Clearance Distance 3.2 mm (.125") Min 18 lb (80N) Crimp 9 lb (40N) PCB Connector Contact Resistance per IEC 512-2 3 milliohms Materials Dielectric Withstanding Voltage (AC) 2,200 Insulator Contact Wire Range (AWG) (mm²) * #24 to #12 0.25 to 4.0 Socket Body PPS UL94 V-0, material group IIIa Copper allo y , 200 µ inch Sn Bright over Ni Socket Contact BeCu, 30 µ inch Au over Ni Operating Temperature (°C) (°F) -55° to 180° -67° to 356° Retention Clips Stainless steel Hoods PBT UL94 V-0 IEC 512-3, UL 1977 (Amperes) * Stranding, IEC class 5 or lower ORDERING INFORMATION Tooling PowerMod Part Number Plan - One Row Female Series PM Rows 1 # Poles Gender Contact Latch Mounting 03 F BA L CH 1 03, 04, 06, 08 Poles F - Female OO - None (Crimp contacts ordered separately) BA - Straight PCB Solder Standard Length-RoHS RA - R/A PCB Solder Standard Length-RoHS Customized Connector - X X X Consult factory for options OO - None SB - R/A PCB Snap Bracket HB - R/A PCB Bracket with Hole ST - Self-tapping screws for straight PCB mount SP - Push in fastener for straight PCB mount CH - With clam-shell hood PC - Panel Clip MC - Mounting Clip SC - Screw for 1.6mm panel mount L - Connector with latch (standard for contact type OO) O - No latch www.andersonpower.com Part Number TM0001 TP0001 Mil-Standard M22520/1-01 N/A Description AF8 hand tool WA27F pneumatic crimp tool Turret & Locator for TM0001 & TP0001 TL0001 N/A For pin contacts TL0002 N/A For socket contacts PM1000G1 N/A PM1002G1 N/A PM1003G1 N/A Four indent hand tool with locator Contact insertion tool Contact extraction tool 1 Row Current vs Temperature Rise 100 90 80 70 60 50 40 30 20 10 0 Temperature (°C) Temperature (°C) TEMPERATURE CHARTS 0 5 10 15 20 25 30 1 Row Ambient Temperature De-rating 200 190 180 170 160 150 140 130 120 110 100 0 5 10 Amps 4mm² 12AWG 20 Amps 12AWG 4mm² 3 circuits all energized 15 25 30 3 circuits all energized DIMENSIONS - mm(in.) Cable Connector ROWS CONTACTS 1 - 03 1 - 04 1 - 06 1 - 08 A -Amm in. 28.5 33.5 43.5 53.5 1.12 1.32 1.71 2.11 10.4 (0.41) 9.4 (0.37) 23.4 (0.92) 9.0 (0.35) See accessory section for panel clip and mounting clip cut-out dimensions. ORDERING INFORMATION Cable Connector Panel Mount With Mounting Clip With Clam Shell Hood & Strain Relief Part Number PM103FOOLOO PM104FOOLOO PM106FOOLOO PM108FOOLOO Part Number PM103FOOLMC PM104FOOLMC PM106FOOLMC PM108FOOLMC Part Number PM103FOOLCH PM104FOOLCH PM106FOOLCH PM108FOOLCH Description 1x3 FEMALE Cable Connector 1x4 FEMALE Cable Connector 1x6 FEMALE Cable Connector 1x8 FEMALE Cable Connector Description 1x3 FEMALE Cable Connector 1x4 FEMALE Cable Connector 1x6 FEMALE Cable Connector 1x8 FEMALE Cable Connector Description 1x3 FEMALE Cable Connector 1x4 FEMALE Cable Connector 1x6 FEMALE Cable Connector 1x8 FEMALE Cable Connector Panel Mount With Screws With Snap-in Panel Clip Crimp Contacts Part Number PM103FOOLSC PM104FOOLSC PM106FOOLSC PM108FOOLSC Part Number PM103FOOLPC PM104FOOLPC PM106FOOLPC PM108FOOLPC Part Number PM16S2024S32 PM16S1620S32 PM16S1416S32 PM16S12S32 Description 1x3 FEMALE Cable Connector 1x4 FEMALE Cable Connector 1x6 FEMALE Cable Connector 1x8 FEMALE Cable Connector Description 1x3 FEMALE Cable Connector 1x4 FEMALE Cable Connector 1x6 FEMALE Cable Connector 1x8 FEMALE Cable Connector Description Socket Socket Socket Socket Wire AWG sq. mm #24 / 20 0.50 / 0.75 #20 / 16 0.50 / 1.5 #16 / 14 1.5 / 2.5 #12 2.5 / 4.0 www.andersonpower.com DIMENSIONS - mm(in.) 1 Row - PCB Right Angle Connector 1 Row - PCB Hole Layout For Right Angle Connector ROWS CONTACTS A 1 - 03 1 - 04 1 - 06 1 - 08 3.7 (0.15) 15.2 (0.60) A mm in. 28.5 33.5 43.5 53.5 L1 mm in. 1.12 10 1.32 15 1.71 25 2.11 35 0.39 0.59 0.98 1.38 L2 mm in. 22.3 27.3 37.3 47.3 10.4 (0.41) 9.4 (0.37) Finished hole 1.6 (0.06) 5.0 (0.20) 2.5 (0.10) ORDERING INFORMATION With Latch Part Number PM103FRALOO PM104FRALOO PM106FRALOO PM108FRALOO No Latch Description 1x3 FEMALE 1x4 FEMALE 1x6 FEMALE 1x8 FEMALE Right Angle PCB Solder Right Angle PCB Solder Right Angle PCB Solder Right Angle PCB Solder Part Number PM103FRAOOO PM104FRAOOO PM106FRAOOO PM108FRAOOO Description 1x3 FEMALE 1x4 FEMALE 1x6 FEMALE 1x8 FEMALE Right Angle PCB Solder Right Angle PCB Solder Right Angle PCB Solder Right Angle PCB Solder Snap Bracket & Latch Snap Bracket & No Latch Part Number PM103FRALSB PM104FRALSB PM106FRALSB PM108FRALSB Part Number PM103FRAOSB PM104FRAOSB PM106FRAOSB PM108FRAOSB Description 1x3 FEMALE 1x4 FEMALE 1x6 FEMALE 1x8 FEMALE Right Angle PCB Solder Right Angle PCB Solder Right Angle PCB Solder Right Angle PCB Solder Description 1x3 FEMALE 1x4 FEMALE 1x6 FEMALE 1x8 FEMALE Right Angle PCB Solder Right Angle PCB Solder Right Angle PCB Solder Right Angle PCB Solder Bracket With Hole & Latch Bracket With Hole & No Latch Part Number PM103FRALHB PM104FRALHB PM106FRALHB PM108FRALHB Part Number PM103FRAOHB PM104FRAOHB PM106FRAOHB PM108FRAOHB Description 1x3 FEMALE 1x4 FEMALE 1x6 FEMALE 1x8 FEMALE Right Angle PCB Solder Right Angle PCB Solder Right Angle PCB Solder Right Angle PCB Solder Description 1x3 FEMALE 1x4 FEMALE 1x6 FEMALE 1x8 FEMALE PCB contacts and mounting accessories are designed for a board thickness of 1.60mm (.063) with a contact protrusion of 2.10 (.083). Other contact lengths are available upon request. www.andersonpower.com 0.88 1.07 1.47 1.86 Right Angle PCB Solder Right Angle PCB Solder Right Angle PCB Solder Right Angle PCB Solder DIMENSIONS - mm(in.) 1 Row - PCB Hole Layout For Straight Solder Connector 1 Row - PCB Straight Solder Connector A 9.4 (0.37) 3.7 (0.15) 15.2 (0.60) 5.0 (0.20) 1.6 (0.06) ROWS CONTACTS 1 - 03 1 - 04 1 - 06 1 - 08 A mm in. 28.5 33.5 43.5 53.5 L1 mm in. 1.12 10 1.32 15 1.71 25 2.11 35 0.39 0.59 0.98 1.38 L2 mm in. 22.3 27.3 37.3 47.3 0.88 1.07 1.47 1.86 Finished hole 10.4 (0.41) ORDERING INFORMATION No Latch With Latch Part Number PM103FBALOO PM104FBALOO PM106FBALOO PM108FBALOO Description 1x3 FEMALE 1x4 FEMALE 1x6 FEMALE 1x8 FEMALE Part Number PM103FBAOOO PM104FBAOOO PM106FBAOOO PM108FBAOOO Straight PCB Solder Straight PCB Solder Straight PCB Solder Straight PCB Solder Description 1x3 FEMALE 1x4 FEMALE 1x6 FEMALE 1x8 FEMALE Straight PCB Solder Straight PCB Solder Straight PCB Solder Straight PCB Solder Push On PCB Fastener & Latch Push On PCB Fastener & No Latch Part Number PM103FBALSP PM104FBALSP PM106FBALSP PM108FBALSP Part Number PM103FBAOSP PM104FBAOSP PM106FBAOSP PM108FBAOSP Description 1x3 FEMALE 1x4 FEMALE 1x6 FEMALE 1x8 FEMALE Straight PCB Solder Straight PCB Solder Straight PCB Solder Straight PCB Solder Description 1x3 FEMALE 1x4 FEMALE 1x6 FEMALE 1x8 FEMALE Straight PCB Solder Straight PCB Solder Straight PCB Solder Straight PCB Solder Self-tapping Screws For PCB Mount & Latch Self-tapping Screws For PCB Mount & No Latch Part Number PM103FBALST PM104FBALST PM106FBALST PM108FBALST Part Number PM103FBAOST PM104FBAOST PM106FBAOST PM108FBAOST Description 1x3 FEMALE 1x4 FEMALE 1x6 FEMALE 1x8 FEMALE Straight PCB Solder Straight PCB Solder Straight PCB Solder Straight PCB Solder Description 1x3 FEMALE 1x4 FEMALE 1x6 FEMALE 1x8 FEMALE Straight PCB Solder Straight PCB Solder Straight PCB Solder Straight PCB Solder PCB contacts and mounting accessories are designed for a board thickness of 1.60mm (.063) with a contact protrusion of 2.10 (.083). Other contact lengths are available upon request. All Data Subject To Change Without Notice 15250 DS-PM1RF REV12 HEADQUARTERS: Anderson Power Products , 13 Pratts Junction Road, Sterling, MA 01564-2305 USA T:978-422-3600 F:978-422-0128 EUROPE: Anderson Power Products® Ltd., Unit 3, Europa Court, Europa Boulevard, Westbrook, Warrington, Cheshire, WA5 7TN United Kingdom T: +44 (0) 1925 428390 F: +44 (0) 1925 520203 ASIA / PACIFIC: IDEAL Anderson Asia Pacific Ltd., Unit 922-928 Topsail Plaza, 11 On Sum Street, Shatin N.T., Hong Kong T:+(852) 2636 0836 F:+(852) 2635 9036 CHINA: IDEAL Anderson Technologies (Shenzhen) Ltd., Block A8 Tantou Western Industrial Park, Songgang Baoan District, Shenzhen, PR. China 518105 T: +(86) 755 2768 2118 F: +(86) 755 2768 2218 TAIWAN: IDEAL Anderson Asia Pacific Ltd., Taiwan Branch, 4F.-2, No.116, Dadun 20th St., Situn District, Taichung City 407, Taiwan (R.O.C.) T: +(886) 4 2310 6451 F:+(886) 4 2310 6460 ® www.andersonpower.com
PM108FRAOHB 价格&库存
很抱歉,暂时无法提供与“PM108FRAOHB”相匹配的价格&库存,您可以联系我们找货
