H
A ±0.25
Ø0.80
G
2.00
2.00
Recommended PCB Layout
F
4.30
2.40
C
Specifications
Ordering Grid
Material
Insulator:
Standard: Polyamide, Nylon 6T, UL94V-0
Options: Polymer, LCP, UL94V-0
Contact : Phosphor Bronze
B
A
2.40±0.20
B ±0.38
Max. insertion
depth 3.60 ref.
Pin 0.50x0.2
2.00
D
Min. insertion
depth 1.51 ref.
E
Plating
See Ordering Grid
Electrical
Current Rating: 2 Amp per pin
Contact Resistance: 20 mΩ max.
Insulation Resistance: 1000 MΩ min.
Dielectric Withstand Voltage: 500 V AC
Mechanical & Environmental
Operating Temperature: -40°C to +105°C
Soldering Process
Nylon 6T (Standard)
IR Reflow: 260°C for 10 sec.
Wave: 230°C for 5-10 sec.
Manual Solder: 350°C for 3-5sec
LCP (Option)
Wave: 250°C for 5-10 sec
Manual Solder: 350°C for 3-5 sec
Mates with(Subject to Pin Length )
BF020
BF021
BF025 BF035
BF036
BF040
BF130
BF085
X
XX
No. of Contacts
02 to 40
Contact Plating
A = Gold Flash All Over (Standard)
B = Selective Gold Flash Contact Area/
Tin On Tail
C = Tin All Over
G = 10µ" Gold Contact Area/Tin On Tail
I = 30µ" Gold Contact Area/Tin On Tail
2
3
4
X
X
Request samples
and quotation
Insulator Material
N = Nylon 6T (Standard)
L = LCP
Tail Length (1/100mm)
0240 = 2.40mm
Packing Options
D = Tube (Standard)
B = Tape & Reel with Cap
E = Tube with Cap
F = Tube with Film
G = Plastic Box
For 2 and 3 contacts option G only.
Part Number
Product Description
BF085
2.0mm Pitch Socket, Single Row,
Through Hole, Vertical
Drawing Date
31st October 2007
By
Detail
1
0240
Revision
Date
5
CC
Tolerances (Except as Noted)
BF085
G PCN
G3
19/06/18
X.° ± 5°
X. ± 0.30
X.X° ± 2°
X.X ± 0.20
X.XX ± 0.15 X.XX° ± 1°
X.XXX ± 0.10 X.XXX° ± 0.5°
Length
Angle
6
Units:
Metric (mm)
C
3rd Angle Projection
7
No. of
Contacts
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
This drawing is confidential and
copyright of Global Connector
Technology, Ltd (GCT).
This drawing must not be copied
or disclosed without written
consent. E & OE
Dimension
A
B
2.0
4.6
4.0
6.6
6.0
8.6
8.0
10.6
10.0
12.6
12.0
14.6
14.0
16.6
16.0
18.6
18.0
20.6
20.0
22.6
22.0
24.6
24.0
26.6
26.0
28.6
28.0
30.6
30.0
32.6
32.0
34.6
34.0
36.6
36.0
38.6
38.0
40.6
40.0
42.6
42.0
44.6
44.0
46.6
46.0
48.6
48.0
50.6
50.0
52.6
52.0
54.6
54.0
56.6
56.0
58.6
58.0
60.6
60.0
62.6
62.0
64.6
64.0
66.6
66.0
68.6
68.0
70.6
70.0
72.6
72.0
74.6
74.0
76.6
76.0
78.6
78.0
80.6
www.gct.co
Not to
Scale
Drawn By
LYH
8
Sheet No.
1/1
BF085-06-A-0240-N-D 价格&库存
很抱歉,暂时无法提供与“BF085-06-A-0240-N-D”相匹配的价格&库存,您可以联系我们找货
