W17982-7PG-P-3ES
W17982-7PG-P-3ES
    SWITCHCRAFT
    CONN RCPT MALE 7POS GOLD SOLDER
W17982-7PG-P-3ES 数据手册
NOTES: 1. ALL PARTS TO BE BULK PACKED 2. CONTACTS INSERTED INTO CONNECTOR WITH SOLDER CUPS FACING OUTWARD RADIALLY. THE CENTER CONTACT SHOULD BE FACING BETWEEN POSITION 1 AND 6 3. ALL DIMENSIONS ARE REFERENCE EXCEPT THOSE WITH A TOLERANCE ASS'Y P/N NO. OF CONTACTS KEY STYLE W17982-5PG-P-300 5 #26 A-KEY W17982-6PG-P-300 6 #26 B-KEY W17982-7PG-P-300 7 #26 A-KEY .401±.003 10.2±0.1 1 5 2 .430±.003 10.9±0.1 4 FACE VIEW CUSTOMER PRINT WIRE VIEW RECCOMENDED PANEL CUT-OUT W17982-5PG-P-300 5 POSITION A-KEY 3 W17982-5PG-P-300 6 1 5 2 4 FACE VIEW PART NUMBER: W17982-XPG-P-300 W17982-6PG-P-300 6 POSITION B-KEY .393 10 FLAT WIRE VIEW .640 16.3 .140 3.6 .050 1.3 .545 13.8 W17982-6PG-P-300 .143±.015 3.6±0.4 6 FACE VIEW W17982-7PG-P-300 7 POSITION A-KEY HEX NUT MAT'L: UV PBT, BLACK 1 7 .620 15.7 ACROSS FLATS .625 15.9 3 5 7/16-28 UNEF-2A MOD. THREAD (5-7) #26 PIN CONTACTS, SOLDER MAT'L: GOLD PLATED COPPER ALLOY 2 3 4 WIRE VIEW W17982-7PG-P-300 GASKET MAT'L: NEOPRENE, BLACK PANEL CONNECTOR, MALE MAT'L: UV PBT, BLACK CUSTOMER APPROVAL THIS DOCUMENT CONTAINS CONFIDENTIAL INFORMATION PROPRIETARY TO CONXALL CORPORATION. ANY REPRODUCTION, DISCLOSURE, OR USE OF THIS DOCUMENT /INFORMATION IS EXPRESSLY PROHIBITED UNLESS AUTHORIZED IN WRITING BY CONXALL CORPORATION. APPROVED BY: DATE: DIMENSIONS IN BRACKETS [ ] ARE IN MILLIMETERS UNLESS INDICATED RoHS COMPLIANT A MA 08-10-20 JGK 8/14/19 REV. INIT. DATE ALL INFORMATION ILLUSTRATED IS THE PROPERTY OF "CONXALL CORPORATION." UNAUTHORIZED DUPLICATION OR DISTRIBUTION OF THIS DOCUMENT IS PROHIBITED. ALL UNITS ARE IN FEET, INCHES, FRACTION OF INCHES AND DECIMALS. = CRITICAL CHARACTERISTIC FLAG PER SPEC. XXXX RELEASED PER PDR 18004-2 DRAWING CREATED FOR PDR #18004 DESCRIPTION ORIG. DRAWN BY: DATE: 8/14/19 JGK CHECKED BY: 601 E. WILDWOOD VILLA PARK, IL 60181 TITLE: APPROVED BY: SCALE SIZE NTS B FILE: W17982-XPG-P-300 SHEET 1 OF 1 DIRECTORY: SLW PANEL MOUNT ASSEMBLY (5-7) #26 PIN CONTACTS, SOLDER INSTA-CLICK™ MICRO-CON-X CUSTOMER: STANDARD PRODUCT PART NUMBER: W17982-XPG-P-300 REV A
W17982-7PG-P-3ES 价格&库存
很抱歉,暂时无法提供与“W17982-7PG-P-3ES”相匹配的价格&库存,您可以联系我们找货
