V1-G-BK
V1-G-BK
    PEPPERL+FUCHS(倍加福)
    CONN PLUG FMALE 4P COPPER SCREW
V1-G-BK 数据手册
Female connector, field-attachable V1-G-BK < < < < Screw terminal connection Metal locking Knurled nut suitable for tool assembly cURus approval Female connector M12 straight A-coded 4-pin, for cable diameter 4 - 6 mm, field-attachable Dimensions M12 x 1 Ø20.2 ~54 18 Technical Data Release date: 2021-12-08 Date of issue: 2021-12-08 Filename: 224883_eng.pdf General specifications Connector 1 Connection socket Construction type M12 Style straight Locking screw connection Number of pins 4 Coding A-coded UL File Number E363587 Electrical specifications Operating voltage UB max. 250 V AC/DC Operating current IB max. 4 A Insulation resistance min. 100 MΩ Conformity Degree of protection EN 60529 Plug connection connector M12 x 1 : IEC 61076-2-101 Ambient conditions Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Female connector, field-attachable V1-G-BK Technical Data Ambient temperature -40 ... 85 °C (-40 ... 185 °F) Pollution degree 3 Mechanical specifications Plug connector Tightening torque 0.6 Nm Tool installation straight knurling , hexagon nut SW = 18 mm Mating cycles min. 50 Degree of protection IP67 Connection screw terminals for max. 0.75 mm2 / AWG 18 Cable Sheath diameter 4 ... 6 mm Mass 23.04 g Material Plug connector Screw connection CuZn, nickel-plated Body PA, black Contact surface CuSnZn Connection Assignment 1 2 4 Release date: 2021-12-08 Date of issue: 2021-12-08 Filename: 224883_eng.pdf 3 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2
V1-G-BK 价格&库存
很抱歉,暂时无法提供与“V1-G-BK”相匹配的价格&库存,您可以联系我们找货
