EPG.0B.306.HLN
www.lemo.com
SUMMARY
# Wires
Low voltage
6
Image is for illustrative purpose only
Series
0B
Termination type
Female print PCB
IP rating
50
AWG wire size
34.00 - 28.00
PCB Altium Pattern
Cable Ø
0.00 - 0.00 mm
PCB KiCad Pattern
Status
active
Catalog
Matching parts
FGG.0B.306.CLAD52Z
Download
Request a quote
PCB Eagle Pattern
TECHNICAL DETAILS
Mechanics
Shell Style/Model
EP*: Elbow receptacle for printed circuit (solder or screw fixing)
Keying
1 key (alpha=0, plug: male contacts, receptacle: female contacts)
Housing Material
PPS (Polyphenylene) shell, other pieces nickel plated [SAE AMS QQ N 290] brass
Weight
9.69 g
Performance
Configuration
0B.306/EPG : 6 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
2.5 Amps
Specifications
Contact Type: Print (straight)
Contact Dia.: 0.5 mm (0.02in)
R (max): 8.7 mOhm
Test voltage contact-contact : 1.25 kV rms
Test voltage contact-body shell : 1.2 kV rms
Others
Endurance (Shell): 5000
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/2
Temp (min / max): -55°C / +250°C
Humidity (max): 144 hr
DRAWINGS
RECOMMENDED BY LEMO
Tools
2/2
很抱歉,暂时无法提供与“EPG.0B.306.HLN”相匹配的价格&库存,您可以联系我们找货
