HGP.0E.304.CLLPV
HGP.0E.304.CLLPV
    LEMO(雷莫)
    HGP.0E.304.CLLPV
HGP.0E.304.CLLPV 数据手册
HGP.0E.304.CLLPV www.lemo.com SUMMARY # Wires Low voltage 4 Image is for illustrative purpose only Series 0E Termination type Female solder IP rating 68 AWG wire size 32.00 - 24.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts FFA.0E.304.CLAC40 Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model HGP*: Fixed receptacle, nut fixing, watertight or vacuum-tight Keying Hermaphroditic keying (half moon insert) with female pin 1 Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant PV : Watertight / Vacuum-tested Weight 13.80 g Performance Configuration 0E.304 : 4 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 7 Amps Specifications Contact Type: Solder Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.6 mm (0.024in) Max. Solid Conductor: 0.25 mm^2 (AWG 24) Max. Stranded Conductor: 0.14 mm^2 (AWG 26) R (max): 6.1 mOhm LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Vtest: 1060 V (AC), 1500 V (DC) Others Endurance (Shell): 5000 mating cycles Temp (min / max): -20°C / +100°C Humidity (max): 1000 hr Pressure: 60 bars DRAWINGS Dimensions A B E L M S1 S3 e mm. 18 19.5 5.5 23.5 4 12.5 17 M14x1.0 in. 0,71 0,77 0,22 0,93 0,16 0,49 0,67 RECOMMENDED BY LEMO LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Tools Cables CMN.04.T28.031PGCE PVC CMN.04.T28.031PGZE CMN.04.T28.031PNCE GREY Grey PVC Black CMN.04.T28.031QGC TPR Grey 140250 PVC Grey 40080 PVC Black 40086 PVC Blue 40140 PVC Black 40240 PTFE White 40260 PVC Black 4041 PVC Grey 4050 PVC Black 4080 PVC Grey 417920 PVC Grey 4260 PTFE White 4280 PVC Black 80080 PVC Grey 80082 PVC Red 80084 PVC Black CTR.75.030.121870G PVC Grey CMN.04.T28.031PNZE LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
HGP.0E.304.CLLPV
物料型号:HGP.0E.304.CLLPV
器件简介: - 系列:0E - 描述:低电压连接器,图像仅供参考 - 端接类型:女性焊锡 - IP等级:68(防水防尘) - 状态:活跃 - 匹配部件:FFA.0E.304.CLAC40
引脚分配: - 配置:0E.304,4个低压引脚
参数特性: - 壳体样式/型号:HGP:固定插座,螺母固定,防水或真空密封 - 键合:雌雄同体键合(半月形插入件)带女性引脚1 - 外壳材料:黄铜(镀铬[SAE AMS 2460])外壳和螺母,镍镀[SAE AMS QQ N 290]黄铜锁套和中间件 - 变体:PV:防水/真空测试 - 重量:13.80克 - 额定电流:7安培 - 接触类型:焊锡 - 接触直径:0.7毫米(0.028英寸) - 桶直径:0.6毫米(0.024英寸) - 最大实心导体:0.25平方毫米(AWG 24) - 最大绞合导体:0.14平方毫米(AWG 26) - 最大电阻:6.1毫欧姆 - 耐压测试:1060伏交流,1500伏直流
功能详解: - 耐久性(壳体):5000次配对循环 - 温度范围:-20°C至+100°C - 湿度:≤95%(在60°C/140°F时) - 振动:15克[10 Hz - 2000 Hz] - 抗冲击性:100克[6毫秒] - 气候类别:20/80/21 - 屏蔽效果(最小):95分贝(10 MHz),80分贝(1 GHz) - 氦气泄漏率(最大):0.0000001 mbarl/s(如果经过真空测试) - 盐雾腐蚀:>1000小时 - 压力:60巴
应用信息: - 推荐电缆:CMN.04.T28.031PGCE(PVC,灰色),CMN.04.T28.031PGZE(灰色),CMN.04.T28.031PNCE(PVC,黑色),CMN.04.T28.031PNZE(黑色),140250(PVC,灰色),40080(PVC,黑色),40086(PVC,蓝色),40140(PVC,黑色),40240(PTFE,白色),40260(PVC,黑色),4041(PVC,灰色),4050(PVC,黑色),4080(PVC,灰色),417920(PVC,灰色),4260(PTFE,白色),4280(PVC,黑色),80080(PVC,灰色),80082(PVC,红色),80084(PVC,黑色),CTR.75.030.121870G(PVC,灰色)
封装信息: - 尺寸:A 18毫米,B 19.5毫米,E 5.5毫米,L 23.5毫米,M 4毫米,S1 12.5毫米,S3 17毫米,M14x1.0
HGP.0E.304.CLLPV 价格&库存
很抱歉,暂时无法提供与“HGP.0E.304.CLLPV”相匹配的价格&库存,您可以联系我们找货
