FGG.0B.302.CLAD42Z
www.lemo.com
SUMMARY
# Wires
Low voltage
2
Image is for illustrative purpose only
Series
0B
Termination type
Male solder
IP rating
50
AWG wire size
28.00 - 20.00
Catalog
Cable Ø
3.30 - 4.20 mm
See video assembly instructions
Status
active
Matching parts
EGG.0B.302.CLL
Download
Request a quote
Eplan
PHG.0B.302.CLLD42Z
TECHNICAL DETAILS
Mechanics
Shell Style/Model
FG*: Straight plug, cable collet and nut for fitting a bend relief
Keying
1 key (alpha=0, plug: male contacts, receptacle: female contacts)
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Variant
Z : Nut for fitting a bend relief
Weight
8.50 g
Performance
Configuration
0B.302 : 2 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
10 Amps
Specifications
Contact Type: Solder
Contact Dia.: 0.9 mm (0.035in)
Bucket Dia.: 1.0 mm (0.039in)
Max. Solid Conductor: 0.56 mm^2 (AWG 20)
Max. Stranded Conductor: 0.56 mm^2 (AWG 20)
R (max): 4.8 mOhm
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Vtest (contact-shell): 1050 V (AC), 1490 V (DC)
Vtest (contact-contact): 1000 V (AC), 1400 V (DC)
Others
Endurance (Shell): 5000
Temp (min / max): -55°C / +250°C
Humidity (max): 1000 hr
DRAWINGS
Dimensions
A
L
M
S1
S2
mm.
9.5
35
25
8
7
in.
0,37
1,38
0,98
0,31
0,28
RECOMMENDED BY LEMO
Tools
2/3
Spanner wrench:
DCD.0B.005.PA070
Caps:
BFG.0B.100.PCSG
Cables
20140
PVC
Grey
20140
PVC
Grey
20141
PVC
Grey
20142
PVC
Red
20143
PVC
Green
20144
PVC
Black
20145
PVC
Yellow
20146
PVC
Black
20240
PTFE
White
20260
PVC
Black
20264
PVC
Black
20266
PVC
Violet
2080
PVC
Grey
2280
PVC
Black
3/3
很抱歉,暂时无法提供与“FGG.0B.302.CLAD42Z”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+241.775881+30.97952
- 10+233.2940810+29.89272
- 25+217.9943825+27.93232
- 50+204.5777250+26.21320
- 100+192.71943100+24.69376
