Additional Resources:
Product Page
3D Model
date
02/19/2020
page
1 of 4
SERIES: MD-SN │ DESCRIPTION: MINI DIN CONNECTOR
FEATURES
• vertical
• panel mount
• thin metal mounting ears
RoHS
PART NUMBER KEY
MD - XX SN
Base Number
Pin Options
30 = 3 pins
40 = 4 pins
50 = 5 pins
60 = 6 pins
70 = 7 pins
80 = 8 pins
90 = 9 pins
SPECIFICATIONS
parameter
conditions/description
min
rated input voltage
rated input current
typ
max
100
12
at 100 Vac
at 12 Vdc
contact resistance
insulation resistance
at 250 Vdc
voltage withstand
for 1 minute
0.9
operating temperature
-20
life
UL94V-0
yes
A
A
30
mΩ
250
Vac
4.5
kg
3
kg
105
4,000
RoHS
1
2
MΩ
insertion force
flammability rating
Vac
Vdc
50
withdrawal force
cuidevices.com
units
°C
cycles
Product Page
3D Model
CUI Devices │ SERIES: MD-SN │ DESCRIPTION: MINI DIN CONNECTOR
date 02/19/2020 │ page 2 of 4
MECHANICAL DRAWINGS
units: mm[inches]
TOLERANCE: ±0.1mm
15.25 0.600
1.8 0.071
MATERIAL
PLATING
shell (30~80)
iron
nickel
shell (90)
brass
nickel
contact terminals (1~9)
phosphor bronze
silver
plastic
nylon + fiber
9.0 0.354
3.3 0.130
38.5 1.516
5
2
30.0 1.181
1
4
3
8
7
10.0 0.394
6
10.0 0.394
3.05 0.120
0.05 (2 PLCS)
17.6 0.693
0.2
MD-30SN
MD-40SN
2
2
4
1
1
3
MD-60SN
MD-70SN
3
4
2
1
3
6
5
4
2
1
3
7
6
5
cuidevices.com
MD-50SN
5
4
2
3
1
MD-80SN
5
2
1
4
3
8
7
6
Product Page
3D Model
date 02/19/2020 │ page 3 of 4
MECHANICAL DRAWINGS (CONTINUED)
MD-90SN
15.25 0.600
1.55 0.061
8.85 0.348
3.2 0.126
38.55 1.518
6
30.0 1.181
2
5
1
4
3
9
8
10.9 0.429
7
10.25 0.404
3.05 0.120
0.05 (2 PLCS)
17.6 0.693
0.2
cuidevices.com
Product Page
3D Model
date 02/19/2020 │ page 4 of 4
REVISION HISTORY
rev.
description
date
1.0
initial release
04/07/2006
1.01
new template applied
05/02/2012
1.02
housing updates
05/04/2012
1.03
updated datasheet
09/08/2017
brand update
02/19/2020
1.04
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“MD-30SN”相匹配的价格&库存,您可以联系我们找货
