XLR CABLE CONNECTORS
5 PIN XLR - Gold Plated
5 pin, gold plated XLR style
connectors perfect for use in audio
cables and also in DMX cables.
IO-XLR5-M-BKAU
IO-XLR5-F-BKAU
SPECIFICATIONS
PRODUCT
MECHANICAL
Gender: Male (IO-XLR5-M-BKAU)
Lifetime: > 1000 Mating Cycles
Female (IO-XLR5-F-BKAU)
Cable O.D.: 3.5 - 8.0mm
Contacts: 5
Wiresize: 1.25mm O.D. Max
ELECTRICAL
Wiring: Solder Contacts
Capacitance Between Contacts: ≤ 2 pF
Capacitance Between Contact and Ground: ≤ 2 pF
Solderability: Complies with IEC
60068-2-20
Contact Resistance: < 7 mΩ
MATERIAL
Insulation Resistance: ≥ 1000 mΩ
Pins: Brass (IO-XLR5-M-BKAU)
Dielectric Strength: 1500V @ 60s
Phosphor Bronze (IO-XLR5-F-BKAU)
Current Rating: 7.5 A / 125 V AC
Pin Plating: .05μm Au
Push Button: Die Cast Zinc
ENVIRONMENTAL
Locking Mechanism: Stainless Steel
UL Flammability Rating: UL 94 HB
Locking Mechanism Finish: Tin
Standard Compliance: IEC 61076-2-103
Shell: Die Cast Zinc
Temperature Range: -40°C ~ +70° C (-40°F ~ +158°F)
Shell Finish: Black
Insert: POM
Bushing: PVC
Product specifications may change without prior notification
Io Audio Technologies® is a registered trademark of Knight Electronics, Inc.
10557 Metric Dr. Dallas, TX 75243 | 214-340-0265 | 800-323-2439 | Fax: 214-340-5870 |
www.ioaudiotechnologies.com
DRAWINGS
IO-XLR5-M-BKAU
IO-XLR5-F-BKAU
FEATURES & APPLICATIONS
The IO-XLR5-M-BKAU and IO-XLR5-F-BKAU connectors feature durable die cast zinc
shells with built in latch locks which provide a reliable connection when mated with the
opposite gender. They also feature a sturdy plastic insert that tightens onto the cable to
provide strain relief while an additional rubber boot delivers extended support from
excessive bending. The gold plated contacts increase the useful life of the cable.
5 pin XLR connectors are a perfect solution for applications requiring a rugged and
dependable locking connection. Because the housing construction is threaded, the
connectors require no tools for assembly, making them ideal for onsite termination and
allow the user to be able to troubleshoot connection issues quickly. This connector is
perfect for use in balanced audio, DMX, low voltage power, and control applications where
the termination method is solder cups.
These connectors are also available with silver plated contacts (IO-XLR5-M-BK &
IO-XLR5-F-BK).
PART NUMBER BREAKDOWN:
STANDARDS & CLASSIFICATIONS
IO-XLR5-M-BKAU
Series Identifier
IO-XLR5-M-BKAU
Number of Pins
IO-XLR5-M-BKAU
Gender
IO-XLR5-M-BKAU
BK = Black Housing Color
IO-XLR5-M-BKAU
Gold Contacts
很抱歉,暂时无法提供与“IO-XLR5-M-BKAU”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 500+36.51899500+4.74735
