NOTES:
1. FINISHED ASSEMBLIES AND LOOSE PARTS BAGGED.
2. LABEL WITH CONXALL PART NUMBER, DATE CODE AND P/N BARCODE PLACED ON BAG
3. SEE DRAWING HPSFMISTD FOR HOLE PATTERNS
4. FOR FIELD INSTALLATION, SEE INSTRUCTION SHEET 2 OF 2.
5. ALL DIMENSIONS ARE REFERENCE EXCEPT THOSE WITH A TOLERANCE
ASSEMBLY P/N
NO. OF CONTACT
SF8382-2PG-5XX
(2) #16
SF8382-3PG-5XX
(3) #16
SF8382-4PG-5XX
(4) #16
SF8382-5PG-5XX
(5) #16
SF8382-6PG-5XX
(6) #16
520 = BACKSHELL WITH Ø.220 [5.6] GROMMET I.D.
530 = BACKSHELL WITH Ø.330 [8.4] GROMMET I.D.
(2) #4x3/8 IN
SELF TAPPING SCREWS
MAT'L: STAINLESS STEEL
CABLE STRAP
MAT'L: NYLON, BLACK
CUSTOMER PRINT
.770
19.6
5
.750
19.1
1.429
36.3
KEY
.375
9.5
.997
25.3
1
1.00
25.4
INSERT
MAT'L: PBT, BLACK
.174
4.4
KEY
5
1
2.300
58.4
2
4
2
6
3
BACKSHELL
MAT'L: NYLON, BLACK
WASHER
MAT'L: NYLON
SF8382-6PG-5XX SHOWN
WITHOUT HARDWARE
6
INSULATOR TUBE
MAT'L: MYLAR
GROMMET
MAT'L: RUBBER, BLACK
WIRE VIEW
2.515
63.9
3
FACE VIEW
HOUSING ADAPTER
MAT'L: NICKEL PLATED BRASS
HOUSING
(X) #20 PIN CONTACTS, SOLDER
MAT'L: GOLD PLATED COPPER ALLOY
SF8382-XPG-5XX
4
SF8382-6PG-5XX
SHOWN
O-RING
MAT'L: SILICONE, RED
COPPER TAPE
ASSEMBLED VIEW
FOR CUSTOMER REFERENCE ONLY
1
3
4
1
PART
NUMBER:
1
5
1
CUSTOMER APPROVAL
4
2
3
2
WIRE VIEW
SF8382-2PG-5XX
2
WIRE VIEW
SF8382-3PG-5XX
2
3
WIRE VIEW
SF8382-4PG-5XX
DIMENSIONS IN BRACKETS [ ] ARE IN MILLIMETERS
WIRE VIEW
SF8382-5PG-5XX
THIS DOCUMENT CONTAINS CONFIDENTIAL
INFORMATION PROPRIETARY TO CONXALL
CORPORATION. ANY REPRODUCTION,
DISCLOSURE, OR USE OF THIS
DOCUMENT /INFORMATION IS EXPRESSLY
PROHIBITED UNLESS AUTHORIZED IN
WRITING BY CONXALL CORPORATION.
APPROVED BY:
DATE:
RoHS COMPLIANT
01-29-19
RELEASED PER PDR 17011
PNK
12-20-18
O-RING 4290S REPLACES SF6290S-1.
PNK
1-30-18
MA
A
REV. INIT.
DATE
ALL INFORMATION ILLUSTRATED IS
THE PROPERTY OF "CONXALL
CORPORATION." UNAUTHORIZED
DUPLICATION OR DISTRIBUTION OF
THIS DOCUMENT IS PROHIBITED.
ALL UNITS ARE IN FEET,
INCHES, FRACTION OF INCHES
AND DECIMALS.
UNLESS OTHERWISE SPECIFIED
TOLERANCES:
3 PLACE DECIMALS ±.005
ANGLES ±1°
FRACTIONS ±1/16
= CRITICAL CHARACTERISTIC
FLAG PER SPEC. XXXX
DRAWING CREATED PER PDR17011
DESCRIPTION
ORIG. DRAWN BY:
DATE:
1-30-18
PNK
CHECKED BY:
601 E. WILDWOOD VILLA PARK, IL 60181
TITLE:
APPROVED BY:
SCALE
SIZE
SHEET
NTS
B
1 OF 2
FILE:
SF8382-XPG-5XX
DIRECTORY:
SLW
CABLE-TO-CABLE ASSEMBLY
(2-6) #16 PIN CONTACTS, SOLDER
SHIELDED MINI-CON-X
CUSTOMER:
STANDARD PRODUCT
PART
NUMBER:
SF8382-XPG-5XX
REV
A
CABLE SHIELD
CABLE CONDUCTORS
HOUSING ADAPTER
CABLE WIRING AND ASSEMBLY INSTRUCTIONS:
INSULATOR TUBE
CABLE
STEP 1. SLIDE HOUSING ADAPTER, INSULATOR TUBE, AND BACKSHELL KIT, ONTO CABLE IN THE ORDER SHOWN.
STEP 2. STRIP CABLE JACKET AND WIRES TO LENGTH. EXCESS CABLE SHIELD MUST BE TRIMMED OR
WRAPPED AROUND WIRES. IF PRESENT, USE THE DRAIN WIRE TO WRAP THE CABLE SHIELD IN PLACE.
STEP 3. SOLDER WIRES TO CONTACTS.
INLINE
CONNECTOR
.125
3.2
DRAIN WIRE (IF PRESENT)
.625
15.9
CUSTOMER PRINT
1.125
28.6
BACKSHELL KIT
CONDUCTIVE TAPE WRAPPED
ONTO INSULATOR TUBE
STEP 4. THREAD HOUSING ADAPTER ONTO CONNECTOR AND TIGHTEN TO 5 LB-IN [0.56 N-m] MINIMUM TORQUE.
STEP 5. PEEL-OFF THE BACKING OF THE CONDUCTIVE TAPE AND WRAP IT AROUND THE INSULATOR AS SHOWN.
.080
2
CONDUCTIVE TAPE WRAPPED TIGHTLY ONTO CABLE SHIELD
PART
NUMBER:
SF8382-XPG-5XX
STEP 6. SLIDE INSULATOR/CONDUCTIVE TAPE INTO THE BACK OF THE CONNECTOR.
FORM FREE END OF CONDUCTIVE TAPE TIGHTLY ONTO THE SHIELD OF THE CABLE.
STEP 7. SLIDE AND THREAD THE BACKSHELL KIT ONTO CONNECTOR. TIGHTEN TO 5 LB-IN [0.56 N-m] MINIMUM TORQUE.
STEP 8. TIGHTEN THE TWO BACKSHELL SCREWS TO SECURE THE CABLE IN THE BACKSHELL.
COMPLETED ASSEMBLY
A
MA
04-03-19
PNK
12-20-18
PNK
1-30-18
REV. INIT.
DATE
AND DECIMALS.
TOLERANCES:
ANGLES ±1°
FRACTIONS ±1/16
FLAG PER SPEC. XXXX
DRAWING CREATED PER PDR 17011
DESCRIPTION
ORIG. DRAWN BY:
DATE:
1-30-18
PNK
CHECKED BY:
TITLE:
APPROVED BY:
SCALE
SIZE
NTS
B
FILE:
FILE NAME
SHEET
2 OF 2
DIRECTORY:
SLW
SHIELDED MINI-CON-X
CUSTOMER:
STANDARD PRODUCT
PART
NUMBER:
SF8382-XPG-5XX
REV
A
很抱歉,暂时无法提供与“SF8382-4PG-530”相匹配的价格&库存,您可以联系我们找货
