SF3282-12PG-540
SF3282-12PG-540
    SWITCHCRAFT
    SF3282-12PG-540
SF3282-12PG-540 数据手册
NOTES: 1. PLACE (1) ONE OF EACH KIT, IN A BAG WITH INSTRUCTION SHEET AND SEAL. 2. LABEL WITH CONXALL, PART NUMBER, DATE CODE, AND PART NUMBER BARCODE IS PLACED ON BAG. ASS'Y P/N SF3282-XPG-520 SF3282-XPG-530 SF3282-XPG-540 10 2 3 1 4 I.D. FOR CABLE 0.200 0.300 0.400 NO. OF CONTACTS: 2 to 12 9 11 CUSTOMER PRINT SF3282-2PG-5XX FACE VIEW 2 POSITION POS 1, 2, 3, 5, 6, 7, 8, 10, 11 & 12 MOLDED HALF CLOSED SF3282-3PG-5XX FACE VIEW 3 POSITION POS 2, 4, 5, 6, 7, 8, 9, 10 & 11 MOLDED HALF CLOSED SF3282-4PG-5XX FACE VIEW 4 POSITION POS 2, 4, 6, 7, 9, 10, 11 & 12 MOLDED HALF CLOSED SF3282-5PG-5XX FACE VIEW 5 POSITION POS 1, 3, 5, 8, 10, 11 & 12 MOLDED HALF CLOSED SF3282-6PG-5XX SF3282-7PG-5XX FACE VIEW FACE VIEW 6 POSITION 7 POSITION POS 3, 6, 9, 10, POS 5, 8,10, 11 & 12 MOLDED 11 & 12 MOLDED HALF CLOSED HALF CLOSED 8 5 6 7 12 WIRE VIEW SF3282-10PG-5XX SF3282-11PG-5XX SF3282-12PG-5XX SF3282-8PG-5XX SF3282-9PG-5XX FACE VIEW FACE VIEW FACE VIEW FACE VIEW FACE VIEW 12 POSITION 10 POSITION 11 POSITION 8 POSITION 9 POSITION POS 11 & 12 MOLDED POS 12 MOLDED POS 2,10, 11 & 12 POS 10, 11 & 12 HALF CLOSED HALF CLOSED MOLDED HALF CLOSED MOLDED HALF CLOSED BACKSHELL KIT (2) #4 X 3/8 IN. SELF TAPPING SCREW MAT'L: STAINLESS STEEL SF3282-XPG-5XX_CD PART NUMBER: (2-12) POS. INSERT MAT'L: UV PBT, BLACK STRAP MAT'L: SUPER TOUGH NYLON, BLACK HOUSING KIT 2-12 POSITION INSERT KIT O-RING MAT'L: NEOPRENE, BLACK HOUSING MAT'L: BRASS, NICKEL PLATED COUPLING RING MAT'L: BRASS, NICKEL PLATED .168±.015 GROMMET MAT'L: RUBBER, BLACK FRICTION WASHER MAT'L: NYLON, CLEAR INSULATOR MAT'L: PET (2-12) #20 PIN SOLDER CUP CONTACTS MAT'L: BRASS ALLOY, GOLD PLATE CUSTOMER APPROVAL 0A THIS DOCUMENT CONTAINS CONFIDENTIAL INFORMATION PROPRIETARY TO CONXALL CORPORATION. ANY REPRODUCTION, DISCLOSURE, OR USE OF THIS DOCUMENT /INFORMATION IS EXPRESSLY PROHIBITED UNLESS AUTHORIZED IN WRITING BY CONXALL CORPORATION. APPROVED BY: DATE: JGK REV. INIT. 03/31/20 DATE ALL INFORMATION ILLUSTRATED IS THE PROPERTY OF "CONXALL CORPORATION." UNAUTHORIZED DUPLICATION OR DISTRIBUTION OF THIS DOCUMENT IS PROHIBITED. ALL UNITS ARE IN FEET, INCHES, FRACTION OF INCHES AND DECIMALS. COPPER TAPE SUPPLIED LOOSE RoHS COMPLIANT UNLESS OTHERWISE SPECIFIED TOLERANCES: 3 PLACE DECIMALS ±.005 ANGLES ±1° FRACTIONS ±1/16 = CRITICAL CHARACTERISTIC FLAG PER SPEC. XXXX BACKSHELL MAT'L: UV PBT, BLACK CREATED FOR PDR#15019. DESCRIPTION ORIG. DRAWN BY: JGK DATE: 03/31/20 CHECKED BY: 601 E. WILDWOOD VILLA PARK, IL 60181 TITLE: APPROVED BY: SCALE NTS SIZE B FILE: SF3282-XPG-5XX_CD CONNECTOR ASSEMBLY KIT SHEET 1 OF 1 CUSTOMER: DIRECTORY: PART NUMBER: SLW (2-12) #20 PIN CONTACTS SHIELDED MULTI-CON-X STANDARD PRODUCT SF3282-XPG-5XX_CD REV 0A
SF3282-12PG-540 价格&库存
很抱歉,暂时无法提供与“SF3282-12PG-540”相匹配的价格&库存,您可以联系我们找货
