ECG.0B.309.CLN
www.lemo.com
SUMMARY
# Wires
Low voltage
9
Image is for illustrative purpose only
Series
0B
Termination type
Female print PCB
IP rating
50
AWG wire size
34.00 - 28.00
PCB Altium Pattern
Cable Ø
0.00 - 0.00 mm
PCB KiCad Pattern
Status
active
Catalog
Matching parts
FGG.0B.309.CLAD42
Download
Request a quote
PCB Eagle Pattern
TECHNICAL DETAILS
Mechanics
Shell Style/Model
EC*: Fixed receptacle with two nuts and straight contacts for printed circuit (back panel
mounting)
Keying
1 key (alpha=0, plug: male contacts, receptacle: female contacts)
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
5.12 g
Performance
Configuration
0B.309 : 9 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
2 Amps
Specifications
Contact Type: Print (straight)
Contact Dia.: 0.5 mm (0.02in)
R (max): 8.7 mOhm
Vtest (contact-shell): 500 V (AC), 710 V (DC)
Vtest (contact-contact): 600 V (AC), 850 V (DC)
Others
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Endurance (Shell): 5000
Temp (min / max): -55°C / +250°C
Humidity (max): 1000 hr
DRAWINGS
Dimensions
A
B
E
Lmax
M
Nmax
S1
S3
e
mm.
12
12.4
5.5
19.55
2.5
16.3
8.2
11
M9x0.6
in.
0,47
0,49
0,22
0,77
0,10
0,64
0,32
0,43
RECOMMENDED BY LEMO
Tools
Spanner 2:
DCH.91.121.PA
2/3
3/3
很抱歉,暂时无法提供与“ECG.0B.309.CLN”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+369.915141+47.85417
- 10+314.4273410+40.67598
- 30+290.9829230+37.64309
- 50+280.6875650+36.31122
- 100+267.30312100+34.57974
- 250+250.59175250+32.41787
