EGG.3B.302.CLL
EGG.3B.302.CLL
    LEMO(雷莫)
    EGG.3B.302.CLL
EGG.3B.302.CLL 数据手册
EGG.3B.302.CLL www.lemo.com SUMMARY # Wires Low voltage 2 Image is for illustrative purpose only Series 3B Termination type Female solder IP rating 50 AWG wire size 18.00 - 10.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts FGG.3B.302.CLAD11 Download Request a quote Eplan Catalog TECHNICAL DETAILS Mechanics Shell Style/Model EG*: Fixed receptacle, nut fixing Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 25.81 g Performance Configuration 3B.302 : 2 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 35 Amps Specifications Contact Type: Solder Contact Dia.: 3 mm (0.118in) Bucket Dia.: 2.7 mm (0.106in) Max. Solid Conductor: 4 mm^2 (AWG 10) Max. Stranded Conductor: 4 mm^2 (AWG 12) R (max): 3.1 mOhm Vtest (contact-shell): 1500 V (AC), 2120 V (DC) Vtest (contact-contact): 2100 V (AC), 2970 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/4 Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A B E L M N S1 S3 e mm. 22 25 11.5 30.7 2 28.1 16.5 22 M18x1.0 in. 0,87 0,98 0,45 1,21 0,08 1,11 0,65 0,87 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/4 Cables CMN.02.T12.078PGZE Grey CMN.02.T12.078PNZE Black CMN.02.T14.072PGZE Grey CMN.02.T14.072PNZE Black CMN.02.T14.072QGZE TPR (medical) CMN.02.T14.078PGZE Grey Grey CMN.02.T14.078PNZE CMN.02.T18.064UNCU CMN.02.T20.047PGZE Grey CMN.02.T20.047PNZE CMN.02.T20.048QGZE TPR (medical) Grey CMN.02.T28.030PGCE PVC GREY CMN.02.T28.030PGZE CMN.02.T28.030PNCE Grey PVC Black 102080 PVC Grey 120184 PVC Black 120240 PVC Black 120250 PVC Grey 120500 PVC Grey 120501 PVC Grey 120751 PVC Grey 20140 PVC Grey 20140 PVC Grey 20141 PVC Grey 20142 PVC Red 20143 PVC Green 20144 PVC Black 20145 PVC Yellow 20146 PVC Black 20240 PTFE White 20260 PVC Black 20264 PVC Black 20266 PVC Violet 2050 PVC Black 20550 PUR Black CMN.02.T28.030PNZE LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/4 20560 PUR White 2080 PVC Grey 220151 PVC Grey 220750 PVC Grey 2221 PVC Black 2260 PTFE White 2280 PVC Black 320150 PVC Grey 4082 PVC Grey CMB.02.210.635 PUR Black LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 4/4
EGG.3B.302.CLL 价格&库存
很抱歉,暂时无法提供与“EGG.3B.302.CLL”相匹配的价格&库存,您可以联系我们找货
