BH015-04-C-E
BH015-04-C-E
    GCT
    SMD,P=3.96mm
    排母 间距:3.96mm 1x4P SMT
BH015-04-C-E 数据手册
5.08 G 3.96 1.40 3.70 8.10 3.96±0.15 Pin 1.14X0.40 3.96 Recommended PCB Layout Top Entry General Tolerance ±0.05 Recommended PCB Layout Bottom Entry General Tolerance ±0.05 B±0.25 Solder Area Solder Area F 6.10 7.10 A 2.80 Ref. 9.35±0.10 8.89 Cap 3.00 E Dimensions Number of Contacts 1.40 Ø1.70 3.70 A±0.20 8.10 H A B 2 3.96 7.92 3 7.92 11.88 4 11.88 15.84 5 15.84 19.80 6 19.80 23.76 7 23.76 27.72 8 27.72 31.68 9 31.68 35.64 10 35.64 39.60 43.56 11 39.60 12 43.56 47.52 13 47.52 51.48 14 51.48 55.44 15 55.44 59.40 16 59.40 63.36 17 63.36 67.32 18 67.32 71.28 0.15 D A 7.10±0.30 Section A-A Ordering Grid C Specifications 规格 Material 物料 Insulator 绝缘体: LCP, UL94V-0 Contact 端子:Phosphor Bronze B A Plating 电镀 Contact 接触:Tin All Over Underplating底层电镀: Nickel all over Electrical 电气 Current Rating 电流额定值: 7.9 Amp Per Pin Contact Resistance 接触电阻值: 30 mΩ max. Insulation Resistance 绝缘电阻值: 1000 MΩ min. Dielectric Withstand Voltage 耐电压: 1000 V AC Mechanical & Environmental 机械 & 环境 Operating Temperature 工作温度: -40°C to +105°C Soldering Process 可焊性 IR Reflow 回流焊: 260°C for 10 sec. Manual Solder 人工焊接: 350°C for 3-5 sec 2 3 4 X Request Samples and Quotation Packing Options E = Tube with Cap (Standard) D = Tube Contact Plating C= Tin All Over Mates with 配套之公头 (Subject to Pin Length 在端子长度适合的条件下) BH010 For bottom entry applications, stringent soldering control & pin alignment are required as lead to pad misalignment could cause incorrect mating. C No. of Contacts 02 to 18 Part Number Product Description BH015 3.96mm Pitch Socket, Single Row, Surface Mount, Vertical,Dual Entry Drawing Date 26th May 2017 By Detail 1 XX BH015 Revision Date 5 CC Tolerances (Except as Noted) Drawing Release A 05/07/17 X. ± 0.30 X.° ± 5° X.X° ± 3° X.X ± 0.25 X.XX ± 0.15 X.XX° ± 2° X.XXX ± 0.10 X.XXX° ± 1° Length Angle 6 Units: Metric (mm) C 3rd Angle Projection 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By CC 8 Sheet No. 1/1
BH015-04-C-E
- 物料型号: BH015 - 器件简介: 提供了一种3.96mm间距的插座,单排,表面贴装,垂直,双入口。 - 引脚分配: 引脚数量从2到18不等,每个引脚之间的间隔为3.96mm。 - 参数特性: - 工作温度:-40°C 至 +105°C - 可焊性:IR Reflow 回流焊 260°C 持续10秒;人工焊接 350°C 持续3-5秒 - 电镀:接触部位为锡电镀,底层电镀为镍电镀 - 电流额定值:每引脚7.9安培 - 接触电阻值:最大30毫欧姆 - 绝缘电阻值:最小1000兆欧姆 - 耐电压:1000伏交流电 - 功能详解: 针对底端入口应用,需要严格的焊接控制和引脚对齐,以避免引脚与焊盘不对齐导致的不正确配合。 - 应用信息: 配套的公头型号为BH010(在端子长度适合的条件下)。 - 封装信息: 提供了详细的尺寸信息和推荐PCB布局指南,包括顶部和底部入口的一般公差±0.05mm,以及焊接区的尺寸。
BH015-04-C-E 价格&库存
很抱歉,暂时无法提供与“BH015-04-C-E”相匹配的价格&库存,您可以联系我们找货
