6282-2PG-3DC
6282-2PG-3DC
    SWITCHCRAFT
    6282-2PG-3DC
6282-2PG-3DC 数据手册
INSTRUCTION SHEET MINI-CON-X SERIES CABLE CONNECTOR ASSEMBLY 0.69 BACKSHELL (SHORT) 0.43 0.43 GROMMET (SHORT) 0.89 0.69 CONNECTOR SOCKET CONTACTS O-RING COUPLING RING OR WINGED COUPLING RING PIN CONTACTS 0.44 0.25 0.19 NOTES: 1. ALL DIMENSIONS ARE FOR REFERENCE ONLY. A BZ 04-21-09 REV. INIT. DATE DRAWING CREATED PER DOR 09-1367KL DESCRIPTION CHECKED BY: APPROVED BY: RECOMMENDED STRIPPING LENGTH FILE: LAB-0012 SHEET 1 OF 3 601 E. WILDWOOD VILLA PARK, IL 60181 INSTRUCTION SHEET MINI-CON-X SERIES CABLE CONNECTOR ASSEMBLY 1.03 1.06 BACKSHELL (LONG) 0.43 0.69 0.89 SOCKET CONTACTS GROMMET (LONG) CONNECTOR CABLE GRIP O-RING COUPLING RING OR WINGED COUPLING RING PIN CONTACTS 0.44 0.25 0.19 NOTES: 1. ALL DIMENSIONS ARE FOR REFERENCE ONLY. A BZ 04-21-09 REV. INIT. DATE DRAWING CREATED PER DOR 09-1367KL DESCRIPTION CHECKED BY: RECOMMENDED STRIPPING LENGTH APPROVED BY: FILE: LAB-0012 SHEET 2 OF 3 601 E. WILDWOOD VILLA PARK, IL 60181 INSTRUCTION SHEET MINI-CON-X SERIES CABLE CONNECTOR ASSEMBLY 0.43 0.43 0.69 0.69 BACKSHELL (SHORT) 0.89 O-RING SOCKET CONTACTS CONNECTOR DAISY-CHAIN GROMMET COUPLING RING OR WINGED COUPLING RING PIN CONTACTS 0.44 0.25 0.19 NOTES: 1. ALL DIMENSIONS ARE FOR REFERENCE ONLY. A BZ 04-21-09 REV. INIT. DATE DRAWING CREATED PER DOR 09-1367KL DESCRIPTION CHECKED BY: APPROVED BY: RECOMMENDED STRIPPING LENGTH FILE: LAB-0012 SHEET 3 OF 3 601 E. WILDWOOD VILLA PARK, IL 60181
6282-2PG-3DC 价格&库存
很抱歉,暂时无法提供与“6282-2PG-3DC”相匹配的价格&库存,您可以联系我们找货
6282-2PG-3DC
  • 1+101.368761+13.11476
  • 10+86.1645110+11.14768
  • 25+80.7665125+10.44931
  • 50+76.9086950+9.95020
  • 100+73.23829100+9.47533
  • 300+67.77838300+8.76895
  • 500+65.38116500+8.45880
  • 1000+62.264381000+8.05556
库存:416
