XLR CHASSIS CONNECTORS
3 PIN JL SERIES
Locking 3 pin connectors with
rugged metal shells for audio and
lighting control.
IO-XLR3-M-JL
SPECIFICATIONS
IO-XLR3-F-JL
MECHANICAL
PRODUCT
Gender: Male (IO-XLR3-M-JL)
Female (IO-XLR3-F-JL)
Lifetime: > 1000 Mating Cycles
Wiresize (Male): 2.0mm Max O.D.
Wiresize (Female): 2.5mm Max O.D.
Contacts: 3
Wiring: Solder Contacts
ELECTRICAL
Locking Device: Latch Lock
Capacitance Between Contacts: ≤ 2 pF
Capacitance Between Contact and Ground: ≤ 2.1 pF
Mounting Direction: Front
Contact Resistance: < 3 mΩ
Solderability: Complies with IEC
60068-2-20
Insulation Resistance: ≥ 5000 MΩ
MATERIAL
Dielectric Strength: 1500V @ 60s
Pins: Brass (IO-XLR3-M-JL)
Current Rating: 15 A / 125 V AC
Phosphor Bronze (IO-XLR3-F-JL)
Grounding: Separate ground contact to shell of
mating connector and panel
Pin Plating: Silver
Grounding Terminal: Brass
ENVIRONMENTAL
Grounding Terminal Plating: Tin
Standard Compliance: IEC 61076-2-103
Shell: Die Cast Zinc
UL Flammability: Meets UL 94 HB
Shell Finish: Nickel
Temperature Range: -40°C ~ +70° C (-40°F ~ +158°F)
Push Button: Die Cast Zinc
Push Button Finish: Nickel
Product specifications may change without prior notification
Io Audio Technologies® is a registered trademark of Knight Electronics, Inc.
10557 Metric Dr. Dallas
, TX 75243 | 214-340-0265 | 800-323-2439 | Fax: 214-340-5870 |
DRAWINGS
IO-XLR3-M-JL
IO-XLR3-F-JL
FEATURES & APPLICATIONS
JL Series XLR chassis connectors offer a sleek and robust
connection in a standard "J" Size shell. This series is perfect for
high-noise environments like permanent installations or
design-in applications where the termination method is solder
cups. The connectors have nickel plated Die cast zinc housing
which allows for great RF protection. They have precision
machined, one piece, silver plated contacts and a separate tin
plated ground pin which grounds to the connector housing and
panel. Available in either black or nickel housing and in 3 or 5
pin variations. The JL Series XLR chassis connectors help
prevent local RF interference from assisted listening, WiFi, and
other radio transmitters close to the connectors. When coupled
with quality shielded cables, a robust system for preventing the
intrusion of unwanted noises is created.
PART NUMBER BREAKDOWN:
Panel Cutout
STANDARDS & CLASSIFICATIONS
IO-XLR3-M-JL
Series Identifier
IO-XLR3-M-JL
Number of Pins
IO-XLR3-M-JL
Gender
IO-XLR3-M-JL
Series Identifier
10557 Metric Dr. Dallas, TX 75243 | 214-340-0265 | 800-323-2439 | Fax: 214-340-5870 |
www.ioaudiotechnologies.com
很抱歉,暂时无法提供与“IO-XLR3-F-JL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+50.946581+6.62182
- 10+43.2854110+5.62605
- 30+40.0502730+5.20556
- 50+38.6311550+5.02111
- 100+36.78652100+4.78135
- 250+34.48346250+4.48201
- 500+32.83825500+4.26817
- 1000+31.271931000+4.06459
- 2500+29.316492500+3.81043
