H
0.75 x 0.25 Pin
3.70
8.00
8.00
3.70
2.54
Ø1.4
G
2.54
1.02
A±0.25
1.55 (ref.)
F
E
5.00
0.50 (ref.)
2.54
2.54
1.40
D
C
B
A
1
2
2.54
10.66
5.08
10
10.16
13.20
7.62
12
12.70
15.74
10.16
14
15.24
18.28
12.70
16
17.78
20.82
15.24
18
20.32
23.36
17.78
25.90
20.32
22
25.40
28.44
22.86
30.98
25.40
30.48
33.52
27.94
28
33.02
36.06
30.48
30
35.56
38.60
33.02
32
38.10
41.14
35.56
34
40.64
43.68
38.10
36
43.18
46.22
40.64
38
45.72
48.76
43.18
40
48.26
51.30
45.72
42
50.80
53.84
48.26
44
53.34
56.38
50.80
46
55.88
58.92
53.34
48
58.42
61.46
55.88
50
60.96
64.00
58.42
52
63.50
66.54
60.96
54
66.04
69.08
63.50
56
68.58
71.62
66.04
58
71.12
74.16
68.58
60
73.66
76.70
71.12
62
76.20
79.24
73.66
64
78.74
81.78
76.20
66
81.28
84.32
78.74
68
83.82
86.86
81.28
70
86.36
89.40
83.82
72
88.90
91.94
86.36
74
91.44
94.48
88.90
76
93.98
97.02
91.44
78
96.52
99.56
93.98
80
99.06
102.10
96.52
Solder Area
Solder Area
5.08
7.00
XX
X
X
X
X
No. of Contacts
04 to 80
Contact Plating
A = Gold Flash (Standard)
B = Selective Gold Flash
C = Tin
G = 10u" Selective Gold
I = 30u" Selective Gold
Request Samples
and Quotation
Packing Options
C = Tape and Reel with Film (Standard)
B = Tape and Reel with Cap
D = Tube
E = Tube with Cap
F = Tube with Film
Insulator Material
N = Nylon 6T (Standard)
L = LCP
Locating Peg
0 = No Peg
1 = With Peg (6 - 80 Pins Only)
Mates with 配套之公头 (subject to pin length 在端子长度适合的条件下)
BG025
BG040
BG041
BG045 BG050
BG065
BG066
BG070
BG085
For bottom entry applications, stringent soldering
control & pin alignment are required as lead to pad
misalignment could cause incorrect mating.
Part Number
Product Description
BG120
2.54mm Pitch Socket
Dual Row, Surface Mount, Vertical, Dual Entry
Drawing Date
30th October 2006
By
Detail
3
8.12
7.62
27.94
Ordering Grid
Environmental & Mechanical 机械 & 环境
Operating Temperature 工作温度: -40° to +105°C
Soldering Process 可焊性:
Nylon 6T (Standard 标准物料) IR Reflow 回流焊: 260°C for 10 sec.
Wave 波峰焊: 230°C for 5-10 sec
Manual Solder 人工焊接: 350°C for 3-5 sec
LCP (Option 可选物料) IR Reflow 回流焊: 260°C for 10 sec.
Wave 波峰焊: 250°C for 5-10 sec
5.08
8
26
BG120
Electrical 电气
Current Rating 电流额定值: 3 Amp Per Pin
Insulator Resistance 绝缘电阻值: 1000 MΩ min.
Contact Resistance 接触电阻值: 20 mΩ max.
Dielectric Withstanding 耐电压: AC 600 V
6
24
(6 - 80 Contacts only)
Material 物料
Contact端子: Phosphor Bronze
Insulator Material 绝缘体:
Standard 标准: Polyamide, Nylon 6T, UL 94V-0
Options 可选: Polymer, LCP, UL 94V-0
N/A
Top Entry
Optional peg
Specifications 规格
5.58
Recommended PCB Layout
1.10
C±0.25
C
2.54
Bottom Entry
0.15
1.10
B
4
(Minimum Insertion Depth)
B±0.25
A
1.02
Ø1
.02
Ø1 .
40
Dimensions
Number of
Contacts
4
Revision
Date
5
CC
Tolerances (Except as Noted)
BG120
D PCN
D1
21/06/17
X.° ± 5°
X. ± 0.30
X.X° ± 2°
X.X ± 0.20
X.XX° ± 1°
X.XX ± 0.15
X.XXX ± 0.10 X.XXX° ± 0.5°
Length
Angle
6
Units:
Metric (mm)
C
3rd Angle Projection
7
This drawing is confidential and
copyright of Global Connector
Technology, Ltd (GCT).
This drawing must not be copied
or disclosed without written
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
AJO
8
Sheet No.
1/1
很抱歉,暂时无法提供与“BG120-10-A-0-N-D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+9.701911+1.26079
