BG120-08-A-0-N-D
BG120-08-A-0-N-D
    GCT
    SMD,P=2.54mm
    排母 间距:2.54mm 2x4P 立贴
BG120-08-A-0-N-D 数据手册
H 0.75 x 0.25 Pin 3.70 8.00 8.00 3.70 2.54 0 Ø1.4 G 2.54 1.02 A±0.25 1.55 (ref.) F E 5.00 0.50 (ref.) 2.54 2.54 1.40 D C B A 1 2 2.54 10.66 5.08 10 10.16 13.20 7.62 12 12.70 15.74 10.16 14 15.24 18.28 12.70 16 17.78 20.82 15.24 18 20.32 23.36 17.78 20 22.86 25.90 20.32 22 25.40 28.44 22.86 30.98 25.40 30.48 33.52 27.94 28 33.02 36.06 30.48 30 35.56 38.60 33.02 32 38.10 41.14 35.56 34 40.64 43.68 38.10 36 43.18 46.22 40.64 38 45.72 48.76 43.18 40 48.26 51.30 45.72 42 50.80 53.84 48.26 44 53.34 56.38 50.80 46 55.88 58.92 53.34 48 58.42 61.46 55.88 50 60.96 64.00 58.42 52 63.50 66.54 60.96 54 66.04 69.08 63.50 56 68.58 71.62 66.04 58 71.12 74.16 68.58 60 73.66 76.70 71.12 62 76.20 79.24 73.66 64 78.74 81.78 76.20 66 81.28 84.32 78.74 68 83.82 86.86 81.28 70 86.36 89.40 83.82 72 88.90 91.94 86.36 74 91.44 94.48 88.90 76 93.98 97.02 91.44 78 96.52 99.56 93.98 80 99.06 102.10 96.52 Solder Area Solder Area 5.08 7.00 XX X X X X No. of Contacts 04 to 80 Contact Plating A = Gold Flash (Standard) B = Selective Gold Flash C = Tin G = 10u" Selective Gold I = 30u" Selective Gold Request Samples and Quotation Packing Options C = Tape and Reel with Film (Standard) B = Tape and Reel with Cap D = Tube E = Tube with Cap F = Tube with Film Insulator Material N = Nylon 6T (Standard) L = LCP Locating Peg 0 = No Peg 1 = With Peg (6 - 80 Pins Only) Mates with 配套之公头 (subject to pin length 在端子长度适合的条件下) BG025 BG040 BG041 BG045 BG050 BG065 BG066 BG070 BG085 For bottom entry applications, stringent soldering control & pin alignment are required as lead to pad misalignment could cause incorrect mating. Part Number Product Description BG120 2.54mm Pitch Socket Dual Row, Surface Mount, Vertical, Dual Entry Drawing Date 30th October 2006 By Detail 3 8.12 7.62 27.94 Ordering Grid Environmental & Mechanical 机械 & 环境 Operating Temperature 工作温度: -40° to +105°C Soldering Process 可焊性: Nylon 6T (Standard 标准物料) IR Reflow 回流焊: 260°C for 10 sec. Wave 波峰焊: 230°C for 5-10 sec Manual Solder 人工焊接: 350°C for 3-5 sec LCP (Option 可选物料) IR Reflow 回流焊: 260°C for 10 sec. Wave 波峰焊: 250°C for 5-10 sec Manual Solder 人工焊接: 350°C for 3-5 sec 5.08 8 26 BG120 Electrical 电气 Current Rating 电流额定值: 3 Amp Per Pin Insulator Resistance 绝缘电阻值: 1000 MΩ min. Contact Resistance 接触电阻值: 20 mΩ max. Dielectric Withstanding 耐电压: AC 600 V 6 24 (6 - 80 Contacts only) Material 物料 Contact端子: Phosphor Bronze Insulator Material 绝缘体: Standard 标准: Polyamide, Nylon 6T, UL 94V-0 Options 可选: Polymer, LCP, UL 94V-0 N/A Top Entry Optional peg Specifications 规格 5.58 Recommended PCB Layout 1.10 C±0.25 C 2.54 Bottom Entry 0.15 1.10 B 4 Recommended PCB Layout (Minimum Insertion Depth) B±0.25 A 1.02 Ø1 .02 Ø1 . 40 Dimensions Number of Contacts 4 Revision Date 5 CC Tolerances (Except as Noted) BG120 D PCN D1 21/06/17 X.° ± 5° X. ± 0.30 X.X° ± 2° X.X ± 0.20 X.XX° ± 1° X.XX ± 0.15 X.XXX ± 0.10 X.XXX° ± 0.5° Length Angle 6 Units: Metric (mm) C 3rd Angle Projection 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By AJO 8 Sheet No. 1/1
BG120-08-A-0-N-D 价格&库存
很抱歉,暂时无法提供与“BG120-08-A-0-N-D”相匹配的价格&库存,您可以联系我们找货
BG120-08-A-0-N-D
  • 1+7.874771+1.01931
  • 56+5.9314956+0.76777
  • 112+5.64776112+0.73105
  • 504+5.07856504+0.65737
  • 1008+4.835941008+0.62597
  • 5040+4.316925040+0.55878
  • 10024+4.1126310024+0.53234
库存:1246
