JMXFH1G04MCUDSA
JMXFH1G04MCUDSA
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    CONN PLUG MALE 4POS GOLD CRIMP
JMXFH1G04MCUDSA 数据手册
XX X X U D X X X Shell type : FH Plug IP68 Shell size Keying : G, A, B, C, D, E Contact layout : SEE INSULATOR DRAWING PROTECTION INDEX: Contact style: S (solder), C (Crimp) 20 [0.79] 2000 MATING CYCLES AS PER IEC 60512-5 test 9a Dropping height 750 mm [29.53] per IEC 60512 test 7b Contact style DURING 1 WEEK) 7 term +134°C / 273.2°F) Connector color coding (ASSEMBLED VIEW FOR INFORMATION ONLY) Packaging :Nothing : single packaging, B(Bulk) : 100pcs 6 REFERENCE PPP1-0036B PPP1-0037B 5 PPP1-0038B PPP1-0039B PPP1-0040B POSITION Color G No color A Blue A B Red R C Green V D Orange O E Yellow J - Optional color coding Color Code U Max tightening torque : 1.5 N.m 0.5 - 2 [0.079] 04, 05 0.9 - 3 [0.118] - 1.3 04, 05 0.9 02, 03 1.3 14 on flats - 1.35 [0.053] 5.5 [0.217] 1.60 [0.063] 5.5 [0.217] 2.10 [0.083] 5.5 [0.217] Mark Mark 7.5 [0.295] A 6.15 [0.242] B 4.8 [0.189] C 3.5 [0.138] D CABLE GLAND AND COLLET SHOULD BE USED IN ACCORDANCE WITH THE CABLE JACKET MATERIAL 5 FRONT VIEW 55 around [2.16] REFERENCE MAIN KEY POSITION PPP1-0029B 4 PPP1-0030B AR PPP1-0031B BR 7 PPP1-0032B SCALE 1/1 PPP1-0033B VARIABLE KEYS 3 PPP1-0034B 3 5 AR BR A 45 $ 180 $ B 135 $225 $ C 45 $ 225 $ D 135 $315 $ E 180 $315 $ G 165 $195 $ 4 3 G : Default key CountryJurisdiction & Control List FR NOT LISTED INSULATOR KEY (ALIGN WITH HALF BUSH WINDOW) P/N : SEE TABLE : CONNECTOR CODING 6 4 MASS 2 1 ITEM NO. 1 2 3 1 VISUAL KEY SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) H 3.5 [0.138] 6 40 around [1.57] HALF BUSH KEY (ALIGN WITH INTERNAL SLEEVE GROOVE) 3 [0.118] BACK VIEW 18,5 0,5 [ n 0.71 - n 0.75] Connector color coding C 10, 12 06, 07, 08 0.7 C (Crimp) SIDE VIEW Contact size 02, 03 Back nut : S (standard, cable gland), M (boot), O (overmolded) See color/keying table Layout 06, 07, 08 0.7 S (Solder) -40°C +125°C (-40°F +257°F) AUTOCLAVING 200 CYCLES AS ISO 17665-1 (Short BIOCOMPATIBILITY: ALL SHELL PEI_ULTEM PARTS to USP Class VI / ISO 10993 Standard collet C 8 IP 50 In unmated condition ROHS & REACH COMPLIANT OPERATING TEMPERATURE: Material : (U) PEI_ULTEM Stripping dimensions METHOD 21 SEE INSULATOR DRAWING 3.5mm MIN. TO 7.5mm MAX. IP 68 AS PER IEC 60529 (1BAR In mated condition Contact type : M (Male), F (Female) A X >500M ^ PER ANSI-EIA-364-D SEE INSULATOR DRAWING SEE INSULATOR DRAWING SEE INSULATOR DRAWING B 1 ELECTRICAL: INSULATION RESISTANCE : MAX. CURRENT RATING : CONNECTOR TESTING VOLTAGE : CONNECTOR WORKING VOLTAGE : PHYSICAL: MAXIMUM WIRE SIZE USED : CABLE DIAMETER ENVIRONMENTAL: ENDURANCE: SHOCK: C FH D JMX E F G H Basic type 8 E.15; Validé Connector coding G 4 2 5 SCALE 1/1 6 7 F E # 10% 12 g PART LIST MATERIAL SLEEVE PEI_ULTEM HALF BUSH WITHOUT WINDOW INSULATOR (CHOOSE PER CABLE SIZE) RUBBER WASHER (CHOOSE PER CABLE SIZE) STANDARD BACK NUT D 17/05/18 ISS DATE Designed by: DESCRIPTION HALF BUSH WITH WINDOW E TITLE PEI_ULTEM Scale PEI_ULTEM 2/1 PEEK Adding color/keying table and cable/claw table -- Latest modification - by: 25108 J.GAMBIER Q.LEBRETON Date:20/01/17 CUSTOMER DRAWING MOD N $ PLUG - STANDARD VERSION SIZE 1 WITH CABLE GLAND - TYPE FH (IP68) GAMME JMX General linear Tolerances: SEE TABLE NPRDS / PROJECT BE150710A This document is the property of SOURIAU www.esterline-connection-technologies.com It must not be reproduced or communicated without permission PEI_ULTEM SILICONE FORMAT PEI_ULTEM C A2 2 SOURIAU DRG N° C0002-PPP1-A B SHEET 1 / 1 A 1
JMXFH1G04MCUDSA
1. 物料型号:文档中没有明确指出具体的物料型号,但提到了“GE MX PLUG-STANDARD VERSION SIZE1WITCABL LANO-TRE IPI”,这可能是一个型号或部件编号。
2. 器件简介:文档描述了一种连接器,具有不同的壳体类型、尺寸和接触布局。它还提到了连接器的防护等级为IP68,能够在极端温度下工作(-40°C至+125°C)。
3. 引脚分配:文档中提到了接触类型(M为公,F为母)和接触风格(S为焊接,C为压接)。接触布局详见绝缘体图纸。
4. 参数特性:连接器的物理测试电压和工作电压详见绝缘体图纸。最大线缆尺寸为3.5mm至7.5mm。环境耐久性为2000次插拔循环,符合IEC标准。
5. 功能详解:连接器具有视觉键和保险丝键,以确保正确连接。还提到了自动灭菌200个周期,符合ISO 17665-1标准。
6. 应用信息:连接器适用于极端环境,包括高温和化学兼容性,所有壳体PEI_ULTEM部件符合USP Class VI / ISO 10993标准。
7. 封装信息:连接器的颜色编码、包装方式(单包装或100个包装)以及最大紧固扭矩为1.5 N.m。
JMXFH1G04MCUDSA 价格&库存
很抱歉,暂时无法提供与“JMXFH1G04MCUDSA”相匹配的价格&库存,您可以联系我们找货
