MFG.
ENG.
APPROVED BY:
DATE:
QA
APPROVED BY:
DATE:
PART NUMBER
SF4281-2SG-3ES
SF4281-3SG-3ES
SF4281-4SG-3ES
SF4281-5SG-3ES
SF4281-6SG-3ES
SF4281-7SG-3ES
SF4281-8SG-3ES
SF4281-9SG-3ES
SF4281-10SG-3ES
SF4281-11SG-3ES
SF4281-12SG-3ES
SF4281-XXSG-3ES
NOTES:
1.
2.
CUSTOMER PRINT
3.
4.
5.
6.
FINISHED CONNECTOR ASSEMBLIES ARE PACKED INTO A PARTITION BOX, 25 PIECES PER BOX.
BOX IS LABELED WITH CONXALL PART NUMBER AND DATE CODE.
HEX NUT IS BULK PACKED IN POLY BAG. O-RING AND PROTECTIVE CAP ARE ASSEMBLED ONTO
THE CONNECTOR.
TERMINATING END OF CONNECTOR IS FILLED WITH BLACK EPOXY.
MASTER KEY IS AT 12 O'CLOCK.
PANEL MOUNT FLAT IS AT 9 O'CLOCK.
MATERIALS:
HEX NUT & PANEL HOUSING- COPPER ALLOY, NICKEL PLATED PER MIL-C-26074
PROTECTIVE CAP- ELASTOMER, BLACK
SOCKET INSERT- THERMOPLASTIC, BLACK
O-RING- ELASTOMER, BLACK
CONTACTS- COPPER ALLOY, GOLD PLATED PER MIL-G-45204 OVER NICKEL PER QQ-N-290
MASTER KEY
(SEE NOTE 4)
POS 3
--OPEN
OPEN
----OPEN
OPEN
OPEN
OPEN
OPEN
OPEN
2
3
.826
21
.621
15.8
SOCKET INSERT
"O" RING
HEX NUT
0B
1
POS 4
OPEN
----OPEN
OPEN
OPEN
OPEN
OPEN
OPEN
OPEN
OPEN
POS 7
------OPEN
OPEN
OPEN
OPEN
OPEN
OPEN
OPEN
OPEN
POS 8
----OPEN
--OPEN
--OPEN
OPEN
OPEN
OPEN
OPEN
POS 9 POS 10 POS 11 POS 12
OPEN
------------OPEN
--------OPEN
--------------OPEN
------OPEN
------OPEN
------OPEN
OPEN
----OPEN
OPEN
OPEN
--OPEN
OPEN
OPEN
OPEN
"---" HALF CLOSED FROM MATING END
3/4-20 UNEF-2A MOD. THREAD
1.00
25
ACROSS FLATS
.105
2.7
BLACK EPOXY FILLED RECESS
.209
5.3
#20 SOCKET CONTACTS, PC TAIL
QTY: (2-12)
9
PANEL MOUNT FLAT
(SEE NOTE 5)
1.13
28.6
ACROSS
CORNERS
11
.800
20.3
1.056
26.8
10
5
8
6
7
FACE VIEW
(SF4281-12SG-3ES SHOWN)
HEX NUT
(UNASSEMBLED)
0B
0B
HOLE PATTERN CHART
POS.
"X"
"Y"
1
0.108
0.125
2
0.000
0.125
3
-0.108
0.125
4
-0.162
0.031
5
-0.108
-0.062
6
-0.054
-0.156
7
0.054
-0.156
8
0.108
-0.062
9
0.162
0.031
10
0.054
0.031
11
-0.054
0.031
12
0.000
-0.062
ALL DIMS. SHOWN TOL. 0.001
PROTECTIVE CAP
.153
3.9
12
SF4281-XXSG-3ES
POS 2
------OPEN
OPEN
OPEN
--OPEN
OPEN
OPEN
OPEN
NUMBER OF CONTACTS
(2 THROUGH 12)
.720
18
D FLAT
4
PART
NUMBER:
POS 1
--OPEN
OPEN
--OPEN
OPEN
OPEN
OPEN
OPEN
OPEN
OPEN
POSITIONS
POS 5 POS 6
--------OPEN
----OPEN
OPEN
----OPEN
OPEN
OPEN
OPEN
OPEN
OPEN
OPEN
OPEN
OPEN
OPEN
OPEN
.730
18.5
1
.040
1
TYPICAL
PANEL THICKNESS
0.06-0.18 [1.5-4.5]
MASTER
KEY
2
PANEL HOUSING
3
4
9
ASSEMBLED VIEW
(SCALE 1:1)
WITHOUT PROTECTIVE CAP)
CL
.770
19.6
10
11
5
8
0C
0B
JGK
JGK
12/20/18
03/23/18
0A
JGK
11/30/17
REV. INIT.
7
RECOMMENDED PANEL CUT-OUT
CL
ALL INFORMATION ILLUSTRATED IS
THE PROPERTY OF "CONXALL
CORPORATION." UNAUTHORIZED
DUPLICATION OR DISTRIBUTION OF
THIS DOCUMENT IS PROHIBITED.
6
12
ALL UNITS ARE IN FEET,
INCHES, FRACTION OF INCHES
AND DECIMALS.
WIRE VIEW
DIMENSIONS IN BRACKETS [] ARE METRIC, mm.
DATE
RoHS COMPLIANT
UNLESS OTHERWISE SPECIFIED
TOLERANCES:
3 PLACE DECIMALS ±.005
ANGLES ±1°
FRACTIONS ±1/16
= CRITICAL CHARACTERISTIC
FLAG PER SPEC. XXXX
REMOVED "E" DESIGNATION FROM ALL P/N'S.
UPDATED HOLE PIN-OUT PATTERN TO MATCH PANEL PIN-OUT.
DRAWING CREATED FOR PROJECT #15019.
DESCRIPTION
ORIG. DRAWN BY:
JGK
DATE:
11/30/17
CHECKED BY:
601 E. WILDWOOD VILLA PARK, IL 60181
TITLE:
APPROVED BY:
SCALE
2:1
FILE:
SIZE
B
SAME AS P/N
SHEET
1 OF 1
DIRECTORY:
SLW
SHIELDED PANEL ASSEMBLY
(2-12) #20 PC TAIL, SOCKET CONTACTS
SHIELDED MULTI-CON-X
CUSTOMER:
STANDARD PRODUCT
PART
NUMBER:
SF4281-XXSG-3ES
REV
0C
很抱歉,暂时无法提供与“SF4282-3SG-3ES”相匹配的价格&库存,您可以联系我们找货
