FFA.1S.303.CLAC52
FFA.1S.303.CLAC52
    LEMO(雷莫)
    CONN CIRC PLUG 3P GOLD SLDR CUP
FFA.1S.303.CLAC52 数据手册
FFA.1S.303.CLAC52 www.lemo.com SUMMARY # Wires Low voltage 3 Image is for illustrative purpose only Series 1S Termination type Male solder IP rating 50 AWG wire size 30.00 - 22.00 Cable Ø 4.20 - 5.20 mm Status active Matching parts ERA.1S.303.CLL Download Request a quote Eplan Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FFA*: Straight plug, cable collet Keying Hermaphroditic keying (half moon insert) with male pin 1 Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 17.22 g Performance Configuration 1S.303 : 3 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 10 Amps Specifications Contact Type: Solder Contact Dia.: 0.9 mm (0.0354in) Bucket Dia.: 0.8 mm (0.031in) Max. Solid Conductor: 0.34 mm^2 (AWG 22) R (max): 4.8 mOhm Vtest: 1200 V (AC), 1800 V (DC) Others LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 144 hr DRAWINGS Dimensions A L M S2 mm. 12 42.5 31.5 8.5 in. 0,47 1,67 1,24 0,33 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.1S.015.PA085 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables 130240 PVC Black 130250 PVC Grey 30260 PVC Black 3220 PVC Black 60080 PVC Grey LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FFA.1S.303.CLAC52 价格&库存
很抱歉,暂时无法提供与“FFA.1S.303.CLAC52”相匹配的价格&库存,您可以联系我们找货
FFA.1S.303.CLAC52
  • 1+404.363491+52.31059
