7331051
7331051
    GES(GES)
    HB30 PTFE
7331051 数据手册
MOD Series M Series MC Series MCS Series VP Series 100 Series S Series Series Operating voltages up to 40 kVDC  Operating current up to 30 Amps  Advanced contact technology  Silver plated and gold plated contacts available  High performance insulation material  General characteristics and technical data Series S S Series Housing Locking system threaded coupling Mounting type (panel mount connector) round flange / 4-hole flange Housing material brass (CuZn) Surface plating nickel (Ni) Protection class (mated connector) IP50 Operating temperature -30°C to +80°C Contacts Termination method solder / screw Rated current 30 A Max. operating current 40 A Pulse current 3000 A Contact resistance 300 µΩ Contact diameter 2.5 mm [.098"] Max. wire size AWG 14 / 2.5 mm² Contact material brass (CuZn) Contact plating silver (Ag) / gold (Au) Insertion / Withdrawal force 5.5 N / 4.0 N Mating cycles 100 k Rated temperature +120°C Insulation inserts Number of contacts 1 Insulation material PTFE or POM Flammability class PTFE UL94 V-0 Flammability class POM UL94 HB CTI value 600 Operating temperature PTFE -50°C to +200°C Operating temperature POM -30°C to +120°C Insulating material group PTFE / POM I (DIN IEC 60664) Suitable cable dimensions max. Ø 6.5 mm [.256"] max. Ø 5.0 mm [.197"] max. AWG14 12 © GES Electronic & Service GmbH www.ges-electronic.de Series Type HSB30 30 Series kVDC Electrical values Operating voltage (DC) 30 kV Test voltage (DC) 45 kV Rated current 30 A Maximum operating current 40 A Pulse current 3000 A Insulation material PTFE Mounting type receptacle 4-hole flange Contact plating silver (Ag) or gold (Au) S Series Characteristics HB30 receptacle, panel mount HB30 receptacle, panel mount HS30 plug, cable mount HS30 plug, cable mount screwed cable gland mounting hole drawing - dimensions in mm [inch] Part No. Description Plug, cable mount 7331050 HS30 PTFE — 7331051 HB30 PTFE 7331150 HS30/Au PTFE 7331151 HB30/Au PTFE Receptacle, panel mount Contact silver plated Contact gold plated — — — — — — — Suitable HV cable, shielded Part No. Operating Voltage Wire size Outer diameter Min. bend radius Temperature range 3330007 30 kVDC AWG22 (0.35 mm²) 5.40 mm [.213"] 54 mm [2.126"] -25 °C / +90 °C For more information please see page 26 © GES Electronic & Service GmbH www.ges-electronic.de 17 Assembly instructions HS (plug, cable mount) 1. Series 6. S Series Part as supplied Fold back shield braid over jacket 2. 7. Parts included Screw joint (1), screw (2), washer (3), clamping rubber (4), outer cone (5), basic part (6), snap ring (7), male contact (8). Prepare shield braid for cutting Completely widen braid. Push outer cone (5) completely under shield braid. 3. 8. Remove male contact Loose snap ring (7) and take out male contact (8). 4. Cut overlapping shield ! Carefully remove shield parts. Loose shield parts can cause electrical break down. Place screw joint (1), screw (2), washer (3), clamping rubber (4), outer cone (5) on cable ! Respect correct order of parts (see picture) 9. 5. Remove dielectric insulation (L2 = 5mm [.197"]) Remove cable jacket Type L1 mm [inch] HS 10/11 31 [1.220"] HS 20/21 56 [2.205"] HS 30/31 69 [2.717"] HS 40 104 [4.094"] 10. Do not damage metal shield. Do not damage dielectric insulation. Respect correct order of parts (see picture) ! 22 © GES Electronic & Service GmbH Solder contact (8) on conductor ! Tin-solder must not remain on contact surface www.ges-electronic.de Assembly instructions HS (plug, cable mount) Series 11. S Series Completely insert cable in basic part (6) 12. Completely slide clamping rubber (4) and washer (3) into basic part (6). Close housing with screw (2) (tightening torque = 3 Nm) 13. Fix male contact (8) with snap ring (7) 14. ! Put screw joint (1) on basic part (6) Note – important! 1. Please carefully read assembly instructions before cable assembly. 2. Cable assembly must only be done by trained and qualified personnel. 15. Assembly finished © GES Electronic & Service GmbH www.ges-electronic.de 23 Assembly instructions GB (plug, cable mount) 1. Series 5. S Series Part as supplied Solder contact (8) on conductor ! Tin-solder must not remain on contact surface 2. 6. ... It is recommended to protect solder point with a shrinking tube (shrinking tube not included). Panel cut out 3. ! For shielded cables: Fold back shield and make sure shield is insulated from solder point (conductor to contact - see step 5.) ! Note – important! 4. 1. Please carefully read assembly instructions before cable assembly. Remove dielectric insulation 24 © GES Electronic & Service GmbH 2. Cable assembly must only be done by trained and qualified personnel. www.ges-electronic.de
7331051 价格&库存
很抱歉,暂时无法提供与“7331051”相匹配的价格&库存,您可以联系我们找货
