FGG.2B.303.CLAD62
FGG.2B.303.CLAD62
    LEMO(雷莫)
    CONN PLUG MALE 3P GOLD SLDR CUP
FGG.2B.303.CLAD62 数据手册
FGG.2B.303.CLAD62 www.lemo.com SUMMARY # Wires Low voltage 3 Image is for illustrative purpose only Series 2B Termination type Male solder IP rating 50 AWG wire size 24.00 - 16.00 Catalog Cable Ø 5.30 - 6.20 mm See video assembly instructions Status active Matching parts EGG.2B.303.CLL Download Request a quote Eplan PHG.2B.303.CLLD62 TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 29.05 g Performance Configuration 2B.303 : 3 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 17 Amps Specifications Contact Type: Solder Contact Dia.: 1.6 mm (0.063in) Bucket Dia.: 1.4 mm (0.055in) Max. Solid Conductor: 1 mm^2 (AWG 16) Max. Stranded Conductor: 1 mm^2 (AWG 18) R (max): 3.5 mOhm Vtest (contact-shell): 1850 V (AC), 2600 V (DC) Vtest (contact-contact): 2400 V (AC), 3390 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A L M S1 S2 mm. 15 50 38 13 12 in. 0,59 1,97 1,50 0,51 0,47 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.2B.025.PA120 Caps: BFG.2B.100.PCSG LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables CMN.03.T18.055PGZE Grey CMN.03.T18.055PNZE CMN.03.T18.055QGZE TPR (medical) Grey 230500 PVC Grey 230750 PVC Grey LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.2B.303.CLAD62 价格&库存
很抱歉,暂时无法提供与“FGG.2B.303.CLAD62”相匹配的价格&库存,您可以联系我们找货
