FGG.2B.308.CLAD52
FGG.2B.308.CLAD52
    LEMO(雷莫)
    FGG.2B.308.CLAD52
FGG.2B.308.CLAD52 数据手册
FGG.2B.308.CLAD52 www.lemo.com SUMMARY # Wires Low voltage 8 Image is for illustrative purpose only Series 2B Termination type Male solder IP rating 50 AWG wire size 30.00 - 22.00 Catalog Cable Ø 4.30 - 5.20 mm See video assembly instructions Status active Matching parts EGG.2B.308.CLL Download Request a quote Eplan PHG.2B.308.CLLD52 TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 28.91 g Performance Configuration 2B.308 : 8 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 10 Amps Specifications Contact Type: Solder Contact Dia.: 0.9 mm (0.035in) Bucket Dia.: 0.8 mm (0.031in) Max. Solid Conductor: 0.34 mm^2 (AWG 22) Max. Stranded Conductor: 0.34 mm^2 (AWG 22) R (max): 4.8 mOhm Vtest (contact-shell): 1250 V (AC), 1770 V (DC) Vtest (contact-contact): 1500 V (AC), 2120 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A L M S1 S2 mm. 15 50 38 13 12 in. 0,59 1,97 1,50 0,51 0,47 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.2B.025.PA120 Caps: BFG.2B.100.PCSG LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables 108240 PTFE White 108260 PTFE White 8280 PVC Black LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.2B.308.CLAD52 价格&库存
很抱歉,暂时无法提供与“FGG.2B.308.CLAD52”相匹配的价格&库存,您可以联系我们找货
