0.25
C Maxi
D
A 0.25
B 0.25
I
(male connector)
Shell size
0.15
SOCKET
7
INSERT
B
8
J
I
PIN
0.6 0.05 for contact #20
1 0.05 for contact #16
E 0.15
6
0.25
3,2 0.1
A
7
A
B
4 Holes
THREAD
SHELL SIZE
C
8
B 0.25
C MAXI
FEMALE CONNECTOR
MALE CONNECTOR
A 0.25
D 0.15
SHELL
D
E
F
G
H
B.2; Validé
F MAXI
ØE
0.15
F Maxi
8
G
0.25
H
0.10
5
8
21.00
15.10
21.50
2.30
11.90
11.70
15.10
12.50
10
23.80
18.30
21.50
2.30
14.90
11.70
18.30
15.10
12
26.20
20.60
21.50
2.30
18.95
11.70
20.60
18.20
14
28.60
23.00
21.50
2.30
22.15
11.70
23.00
21.40
Thread
7/16 28 UNEF
Class 2A
J
(female connector)
6
9.76/11.86 for layout 8-2/8-3/8-4
9.55/11.71 for layout 8-2/8-3/8-4
10.78/13.09 for layout 8-3A/8-98/8-33 10.82/12.79 for layout 8-3A/8-98/8-33
10
8.1/10.5
8.15/10.15
12
8.1/10.5
7.2/9.3 for layout 12-14
8.15/10.15
7.3/9.3 for layout 12-14
14
8.1/10.5
8.15/10.15
9/16 24 UNEF
Class 2A
11/16 24 UNEF
Class 2A
UTS0 14
D 19 P .
5
XX
Receptacle UTS0
13/16 20 UNEF
Class 2A
Shell size
4
4
D= Dipsolder contacts
Insert arrangement
(See table)
P = Male contact
S = Female contact
CUT PANEL
MATERIAL :
Orientations
Normal (no digit), W,X,Y,Z = different orientations
G 0.25
3
3
Specification
Shell:PBT UL94 V-0 Black color
Insert:Polychloroprene
Seal gasket :Sealing IP68/69K : Silicone
O'seal : Nitril
Contact: brass + gold plated
Country
FR
H 0.1
Front panel mounting
2
Operating temperature:-40 C up to 105 C
Insulation resistance:5000 M min
Test potential:1500Vrms for #20 layout
Corrosion salt spray:500 hours
Durability:250 matings and unmatings
Sealing in mated and unmated conditions:
-IP68 1 bar during 1 week : immersion under 10 m of water.
(IEC 60529)
-IP69K : exposure to high pressure water of cleaning
equipement(DIN 40050)
NOT LISTED
P/N : SEE TABLE
G 0.25
PERFORMANCE CHARACTERISTICS :
Jurisdiction & Control List
B
02/11/2017
ISS
DATE
Designed by:
3,2 0.1
TITLE
Scale
2/1
1
NOTE:
Updating shell material
21774A
Latest modification - by:
J. FEURPRIER
Date:
COURTOIS L.
11/05/11
CUSTOMER DRAWING
RECEPTACLE WITH DIPSOLDER CONTACTS
UTS HI SEAL
General linear
Tolerances:
0.1
WWW.SOURIAU.COM
Insert arrangements : refer to C144-UTS1-A
H
SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products
which does not comply with the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
G
F
E
D
FORMAT
A2
C
2
MOD N
NPRDS / PROJECT
UTS
This document is the property of
SOURIAU
It must not be reproduced or
communicated without permission
SOURIAU DRG N°
C143-UTS1-A
B
SHEET
1/1
A
1
很抱歉,暂时无法提供与“UTS012D14P”相匹配的价格&库存,您可以联系我们找货
