FR20C06VBNN
FR20C06VBNN
    METZCONNECT
    插件,P=2mm
    排母 间距:2mm 1x6P 插件
FR20C06VBNN 数据手册
Page 1/4 Data sheet P/N FR20CXXVBNN xx=number of poles FR20CxxVBNN 2020/10/20 Version: O Illustrations Dimensional drawing Drill pattern See enlarged drawings at the end of document Product specification • female connector, THR solderable • centerline 2.00 mm, direction of connection vertical 0° • closed ends • color black • Tape & Reel packaging possible • single row Data sheet Page 2/4 FR20CxxVBNN P/N FR20CXXVBNN xx=number of poles 2020/10/20 Version: O Technical Data General Data Solder pin length Min. number of poles 2.2 mm Max. number of poles 40 clearance/creepage dist. 0.65 mm Protection category IP00 Rated current 1A 2 Material Insulating material PE-HT Contact material CuSn Contact surface Ni + Au Contact pin material CuSn Contact pin surface Ni + Au Flash Glow-Wire Flammability GWFI - Glow-Wire Flammability GWIT - Climatic Data Upper limit temperature 105 °C Lower limit temperature -40 °C general Tolerance ISO 2768 -mH Solderability Acc. to IPC/JEDEC J-STD-020D-MSL 1 Data sheet FR20CxxVBNN Page 3/4 P/N FR20CXXVBNN xx=number of poles 2020/10/20 Version: O Illustrations Dimensional drawing L=(pole size - 1) x centerline + 2 mm [0.079] Data sheet FR20CxxVBNN Page 4/4 P/N FR20CXXVBNN xx=number of poles 2020/10/20 Version: O Illustrations Drill pattern Powered by TCPDF (www.tcpdf.org)
FR20C06VBNN 价格&库存
很抱歉,暂时无法提供与“FR20C06VBNN”相匹配的价格&库存,您可以联系我们找货
FR20C06VBNN
  • 1+5.827601+0.75396
  • 40+4.4750340+0.57897
  • 120+4.14034120+0.53567
  • 520+3.73311520+0.48298
  • 1000+3.564591000+0.46118
  • 5000+3.181895000+0.41167
  • 10000+3.0300910000+0.39203
库存:423
FR20C06VBNN
