DF51 Series
Aug.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
2mm Pitch, Positive Lock, Wire-to-Board Connector
(UL, C-UL Standard Certified Product)
Mar. 2021 ④
DF51 Series/2mm Pitch, Positive Lock, Wire-to-Board Connector (UL, C-UL Standard Certified Product)
Features
1. Positive lock provides clear
tactile click and secures
reliable connection.
Lock Insertion
Force Curb
The lock delivers a clear tactile click during peak
insertion force, preventing incomplete mating.
Contact Insertion
Force Curb
Clear click sound and tactile click
when the insertion force peak is matched.
Secure Mating
2. Wide variation
Each of the straight/ right angle/ in- line
configurations is available in single- row and
dual- row for flexible design.
Gold and Tin plating options support various
application needs.
3. Secure Side- locking design
No Extra
Space Required
for Release
The straight type with short depth and low profile
right angle type are well suited for compact/ thin
equipment.
Height
Small size
Short Depth
Reduces overall system size.
2
Low Profile
4. Prevents incorrect mating
Visually and mechanically polarized features
prevent reverse mating and incorrect mating
between different number of positions.
Mating Mark
Secure
Side-locking
Design
Incorrect
Mating
Prevention
5. Uses the same contacts
and crimping tools as DF11
Series
Wide applicable cable range: 22 to 30 AWG.
6. Suitable for potting
The straight header can be potted up to 3mm.
Resin
3mm Max.
7. UL, C- UL Certified
Applications
Office automation, Industrial machinery, Industrial robots, Amusement equipment, Medical equipment.
3
Product Specifications
Ratings
Rated
Current
(Note 1)
SingleRow
Dual-
Row
Pos.
22
AWG
24
AWG
2
3A
2.5A
3-6
2A
2A
4
3A
2.5A
6-30
2A
2A
Rated
Voltage
26
AWG
2A
28
AWG
1A
30
AWG
0.5A
Operating
Temperature
(Note 2)
-55 to
+105℃
Operating Humidity
Range (Note 3)
20 to 80%
Storage Temperature
Range (Note 4)
-10 to +60℃
Storage Humidity
Range (Note 4)
40 to 70%
1.5A
250V AC/DC
Rated Current
(Note 1)
UL, C-UL
Safety Standard Approved Specification
22 AWG
24 to 28 AWG
30 AWG
2A
1A
0.5A
Rated Voltage
30V AC/DC
UL/C-UL File No. and Recognition No.UL, C-UL: E52653
Note
Note
Note
Note
1
2
3
4
The rated current depends on the wire size used.
Includes temperature rise due to current flow.
Use without condensation on parts.
The storage condition refers to long-term storage of the product on the shelf before assembly. The operating temperature and humidity are applicable
after assembly when the product is not energized and during transportation.
Item
Specification
Condition
Insulation Resistance
1,000M Ω Min.
Measured at 500V DC
Withstand Voltage
No flashover or breakdown
650V AC is applied for 1 min.
Contact Resistance
30m Ω Max.
Measured at 1mA (DC or 1000Hz), 20mV Max.
Vibration Resistance
No electrical discontinuity of 1μ s or greater
Frequency 10 to 55 Hz, half amplitude 0.75mm,
10 times in each of the 3 directions
Shock Resistance
Accelerated velocity : 490 m/s2 for 11ms,
half-sine wave in 3 directions, 3 times for each direction
Moisture-resistance
Contact resistance : 30m Ω Max.
Insulation resistance : 500M Ω Min.
Temperature : 40 ± 2℃ ; humidity: 90 to 95%,
left as it is for 96 hours
Temperature cycles
Insulation resistance : 1,000M Ω Min.
-55℃ :30 minutes → 105℃ : 30 minutes
5 cycles
Durability
Tin plated : 30 mating cycles,
Gold plated: 50 mating cycles
Solder heat resistance
The resin parts should withstand
the temperature and resist melting.
Flow : 260℃ , 5 sec
Hand soldering : temperature of soldering iron
at 270℃ for 3 seconds
Materials / Finish
Product
Part
Material
Finish
Specification
Insulator
PBT (glass-reinforced)
Black
UL94V-0
Contact
Brass
Tin Plated or Gold Plated
Crimp Socket
Insulator
Black
UL94V-0
Socket Contact
Contact
Phosphor Copper
In-line Plug
Insulator
Black
UL94V-0
In-line Plug Contact
Contact
Phosphor Copper
Header
4
Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
■ Connector
DF51 # - # P - 2 DSA
❶
❷
❸ ❹
❺
❻
■ Crimp Contact
DF11 - EP 2428 PCF A
❶
❼
❽
❾
❶
Series name
DF51
❻
Housing Type
DSA : Straight Header
DS : Right Angle Header
C : Crimp Socket
❷
Form Type
Blank : Guide-boss Type
A : Without Guide-boss
❼
Contact Type
EP : In-line Plug
❸
Number of
Positions
Single-row : 2 to 6
Dual-row : 4 to 30
❽
Applicable
Conductor
22 : 22 AWG
2428 : 24 to 28 AWG
30 : 30 AWG
❹
Connector Type
P : Single-row Pin Header
S : Single-row Crimp Socket
DP : Dual-row Pin Header
DS : Dual-row Crimp Socket
EP : Single-row In-line Plug
DEP : Dual-row In-line Plug
❾
Packaging Style
SCF : Socket Contacts/Reel
SC : Socket Contacts/Bag
PCF : In-line Plug Contacts/Reel
PC : In-line Plug Contacts/Bag
❺
Contact Pitch
2mm
Plating
Specifications
Blank : Tin Plated
A : Gold Plated
5
Diagram of Connector Mating Combinations
Single-row
Crimp Socket
(Cable Side)
DF51-#S-2C
Socket Contact
DF11-22SC(F)(A)
Straight Header
DF51A-#P-2DSA
DF11-2428SC(F)(A)
DF11-30SC(F)(A)
Right Angle Header
DF51(A)-#P-2DS
In-line Plug (Cable Side)
DF51-#EP-2C
DF11-EP2428PC(F)(A)
Dual-row
Crimp Socket
(Cable Side)
Socket Contact
DF51-#DS-2C
DF11-2428SC(F)(A)
DF11-22SC(F)(A)
Straight Header
DF51A-#DP-2DSA
DF11-30SC(F)(A)
Right Angle Header
DF51(A)-#DP-2DS
DF51-#DEP-2C
DF11-EP2428PC(F)(A)
6
Single-row Straight Header
A
B
P=2.0
1.8
CAV No.
A
Contact
No.1
HRS Mark
HRS Mark
Polarity
Mark
No. of Pos. Indicator
Lot No.
5HS1
8.4
3.0
□0.5
+0
0 .1
Recommended PCB Layout (t=1.6mm)
8
B±0.1
P=2.0±0.05
Φ
0.
5.25
4.4
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
DF51A-2P-2DSA(##)
CL0543-5105-0-##
2
10.8
2.0
DF51A-3P-2DSA(##)
CL0543-5106-0-##
3
12.8
4.0
DF51A-4P-2DSA(##)
CL0543-5107-0-##
4
14.8
6.0
DF51A-5P-2DSA(##)
CL0543-5108-0-##
5
16.8
8.0
DF51A-6P-2DSA(##)
CL0543-5109-0-##
6
18.8
10.0
【Specification number】
Blank : Tin plated
(01) : Gold plated
7
Purchase Unit
100pcs
per bag
Dual-row Straight Header
2.65
P=2.0
A
B
Contact No.2
2.0
Cavity No.
A
HRS Mark
Contact No.1
A
Polarity
Mark
HRS Mark
7.3
5HS1
8.4
Lot No.
3.0
□0.5
B±0.1
P=2.0±0.05
.1
+0 0
8
0.
φ
2.0±0.05
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
DF51A-4DP-2DSA(##)
CL0543-5015-0-##
4
11.1
2.0
DF51A-6DP-2DSA(##)
CL0543-5044-0-##
6
13.1
4.0
DF51A-8DP-2DSA(##)
CL0543-5045-0-##
8
15.1
6.0
DF51A-10DP-2DSA(##)
CL0543-5046-0-##
10
17.1
8.0
DF51A-12DP-2DSA(##)
CL0543-5047-0-##
12
19.1
10.0
DF51A-14DP-2DSA(##)
CL0543-5048-0-##
14
21.1
12.0
DF51A-16DP-2DSA(##)
CL0543-5049-0-##
16
23.1
14.0
DF51A-18DP-2DSA(##)
CL0543-5050-0-##
18
25.1
16.0
DF51A-20DP-2DSA(##)
CL0543-5051-0-##
18.0
DF51A-22DP-2DSA(##)
CL0543-5052-0-##
22
29.1
20.0
DF51A-24DP-2DSA(##)
CL0543-5053-0-##
24
31.1
22.0
DF51A-26DP-2DSA(##)
CL0543-5054-0-##
26
33.1
24.0
DF51A-28DP-2DSA(##)
CL0543-5055-0-##
28
35.1
26.0
DF51A-30DP-2DSA(##)
CL0543-5056-0-##
30
37.1
28.0
Blank : Tin plated
(01) : Gold plated
8
Purchase Unit
100pcs
per bag
5HS1
Lot No.
No. of Pos.
Indicator
12.0
Single-row Right Angle Header
Polarity Mark
HRS Mark
A
B
P=2.0
Contact
No.1
Cavity No.
HRS Mark
4.5
3.0
1.9
1.6
9.45
C
Above drawing is guide-boss type.
B±0.1
P=2.0±0.05
.1
+0 0
.8
Ø0
Ø1.7
C±0.1
2.7±0.1
+0.1
2.7±0.1
A
□0.5
Unit : mm
Part No.
HRS No.
Guide-boss
No. of Pos.
A
B
C
Purchase Unit
DF51-2P-2DS(##)
CL0543-5110-0-##
With boss
2
10.8
2.0
6.0
243pcs per tray
DF51-3P-2DS(##)
CL0543-5111-0-##
With boss
3
12.8
4.0
8.0
207pcs per tray
DF51A-4P-2DS(##)
CL0543-5117-0-##
Without boss
4
14.8
6.0
171pcs per tray
DF51A-5P-2DS(##)
CL0543-5118-0-##
Without boss
5
16.8
8.0
153pcs per tray
DF51A-6P-2DS(##)
CL0543-5119-0-##
Without boss
6
18.8
10.0
135pcs per tray
(20) : Tin plated, tray packaging
(50) : Gold plated, tray packaging
9
Dual-row Right Angle Header
5HS1
No. of Pos.
Indicator
11.9
Lot No.
Polarity
Mark
HRS Mark
Contact
No.1
P=2.0
A
B
3.0
1 2.65 2
□0.5
9.45
C
A
2.0
B±0.1
P=2.0±0.05
+0.1
2.7±0.1
Ø1.7
.1
.8
Ø0
2.0±0.05
2.7±0.1
A
Contact
No.2
7.3
HRS Mark
Cavity No.
C±0.1
Unit : mm
Part No.
HRS No.
Guide-boss
No. of Pos.
A
B
C
Purchase Unit
DF51-4DP-2DS(##)
CL0543-5016-7-##
With boss
4
11.1
2.0
7.4
234pcs per tray
DF51-6DP-2DS(##)
CL0543-5017-0-##
With boss
6
13.1
4.0
9.4
198pcs per tray
DF51A-8DP-2DS(##)
CL0543-5059-0-##
Without boss
8
15.1
6.0
171pcs per tray
DF51A-10DP-2DS(##)
CL0543-5060-0-##
Without boss
10
17.1
8.0
153pcs per tray
DF51A-12DP-2DS(##)
CL0543-5061-0-##
Without boss
12
19.1
10.0
135pcs per tray
DF51A-14DP-2DS(##)
CL0543-5062-0-##
Without boss
14
21.1
12.0
126pcs per tray
DF51A-16DP-2DS(##)
CL0543-5063-0-##
Without boss
16
23.1
14.0
108pcs per tray
DF51A-18DP-2DS(##)
CL0543-5064-0-##
Without boss
18
25.1
16.0
99pcs per tray
DF51A-20DP-2DS(##)
CL0543-5065-0-##
Without boss
18.0
90pcs per tray
DF51A-22DP-2DS(##)
CL0543-5066-0-##
Without boss
22
29.1
20.0
90pcs per tray
DF51A-24DP-2DS(##)
CL0543-5067-0-##
Without boss
24
31.1
22.0
81pcs per tray
DF51A-26DP-2DS(##)
CL0543-5068-0-##
Without boss
26
33.1
24.0
72pcs per tray
DF51A-28DP-2DS(##)
CL0543-5069-0-##
Without boss
28
35.1
26.0
72pcs per tray
DF51A-30DP-2DS(##)
CL0543-5070-0-##
Without boss
30
37.1
28.0
72pcs per tray
10
P=2.0
A
B
C
A
HRS Mark
Cavity No.
10.15
4.4
1
Contact No.1
Contact No.
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
DF51-2S-2C
CL0543-5120-0-00
2
16.2
12.6
2.0
DF51-3S-2C
CL0543-5121-0-00
3
18.2
14.6
4.0
DF51-4S-2C
CL0543-5122-0-00
4
20.2
16.6
6.0
DF51-5S-2C
CL0543-5123-0-00
5
22.2
18.6
8.0
DF51-6S-2C
CL0543-5124-0-00
6
24.2
20.6
10.0
11
Purchase Unit
100pcs
per bag
A
B
C
P=2.0
2.0
A
HRS Mark
Cavity No.
Contact No.1
10.7
1
7.2
Contact No.
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
DF51-4DS-2C
CL0543-5030-8-00
4
15.0
11.1
2.0
DF51-6DS-2C
CL0543-5031-0-00
6
17.0
13.1
4.0
DF51-8DS-2C
CL0543-5032-3-00
8
19.0
15.1
6.0
DF51-10DS-2C
CL0543-5033-6-00
10
21.0
17.1
8.0
DF51-12DS-2C
CL0543-5034-9-00
12
23.0
19.1
10.0
DF51-14DS-2C
CL0543-5035-1-00
14
25.0
21.1
12.0
DF51-16DS-2C
CL0543-5036-4-00
16
27.0
23.1
14.0
DF51-18DS-2C
CL0543-5037-7-00
18
29.0
25.1
16.0
DF51-20DS-2C
CL0543-5038-0-00
27.1
18.0
DF51-22DS-2C
CL0543-5039-2-00
22
33.0
29.1
20.0
DF51-24DS-2C
CL0543-5040-1-00
24
35.0
31.1
22.0
DF51-26DS-2C
CL0543-5041-4-00
26
37.0
33.1
24.0
DF51-28DS-2C
CL0543-5042-7-00
28
39.0
35.1
26.0
DF51-30DS-2C
CL0543-5043-0-00
30
41.0
37.1
28.0
12
Purchase Unit
100pcs
per bag
Single-Row In-line Plug
A
B
C
P=2.0
5.4
4.5
Cavity No.
A
B
A
D
15.15
HRS Mark
1
Contact No.1
Contact No.
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
DF51-2EP-2C
CL0543-5125-0-00
2
15.5
10.8
2.0
17.5
DF51-3EP-2C
CL0543-5126-0-00
3
17.5
12.8
4.0
19.5
DF51-4EP-2C
CL0543-5127-0-00
4
19.5
14.8
6.0
21.5
DF51-5EP-2C
CL0543-5128-0-00
5
21.5
16.8
8.0
23.5
DF51-6EP-2C
CL0543-5129-0-00
6
23.5
18.8
10.0
25.5
13
Purchase Unit
100pcs
per bag
A
B
C
P=2.0
Cavity No.
2.0
8.4
7.3
A
B
A
HRS Mark
15.15
D
1
Contact No.1
Contact No.
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
D
DF51-4DEP-2C
CL0543-5071-0-00
4
14.4
11.1
2.0
16.4
DF51-6DEP-2C
CL0543-5072-0-00
6
16.4
13.1
4.0
18.4
DF51-8DEP-2C
CL0543-5073-0-00
8
18.4
15.1
6.0
20.4
DF51-10DEP-2C
CL0543-5074-0-00
10
20.4
17.1
8.0
22.4
DF51-12DEP-2C
CL0543-5075-0-00
12
22.4
19.1
10.0
24.4
DF51-14DEP-2C
CL0543-5076-0-00
14
24.4
21.1
12.0
26.4
DF51-16DEP-2C
CL0543-5077-0-00
16
26.4
23.1
14.0
28.4
DF51-18DEP-2C
CL0543-5078-0-00
18
28.4
25.1
16.0
30.4
DF51-20DEP-2C
CL0543-5079-0-00
27.1
18.0
32.4
DF51-22DEP-2C
CL0543-5080-0-00
22
32.4
29.1
20.0
34.4
DF51-24DEP-2C
CL0543-5081-0-00
24
34.4
31.1
22.0
36.4
DF51-26DEP-2C
CL0543-5082-0-00
26
36.4
33.1
24.0
38.4
DF51-28DEP-2C
CL0543-5083-0-00
28
38.4
35.1
26.0
40.4
DF51-30DEP-2C
CL0543-5084-0-00
30
40.4
37.1
28.0
42.4
14
Purchase Unit
100pcs
per bag
In-line Plug Panel Cutouts
● Single-row
4.65±0.05
1.05±0.05
5.7±0.05
4.8±0.05
A±0.05
B±0.05
C±0.05
B±0.05
Unit : mm
A
Part No.
HRS No.
No. of Pos.
Panel Board Thickness (Note 1)
B
C
0.5 to 0.8 0.9 to 1.3 1.4 to 1.8 1.9 to 2.3
DF51-2EP-2C
CL0543-5125-0-00
2
14.9
15.2
15.6
16.0
11.0
7.2
DF51-3EP-2C
CL0543-5126-0-00
3
16.9
17.2
17.6
18.0
13.0
9.2
DF51-4EP-2C
CL0543-5127-0-00
4
18.9
19.2
19.6
20.0
15.0
11.2
DF51-5EP-2C
CL0543-5128-0-00
5
20.9
21.2
21.6
22.0
17.0
13.2
DF51-6EP-2C
CL0543-5129-0-00
6
22.9
23.2
23.6
24.0
19.0
15.2
Note 1 : The A dimension of the mounting hole varies based on panel board thickness.
Note 2 : Do not use a rounded surface at the panel tab portion.
15
● Dual-row
A±0.05
B±0.05
2.3±0.05
8.6±0.05
7.5±0.05
6.7±0.05
C±0.05
B±0.05
Unit : mm
A
Part No.
HRS No.
No. of Pos.
B
C
DF51-4DEP-2C
CL0543-5071-0-00
4
13.6
14.1
14.5
14.9
11.3
7.5
DF51-6DEP-2C
CL0543-5072-0-00
6
15.6
16.1
16.5
16.9
13.3
9.5
DF51-8DEP-2C
CL0543-5073-0-00
8
17.6
18.1
18.5
18.9
15.3
11.5
DF51-10DEP-2C
CL0543-5074-0-00
10
19.6
20.1
20.5
20.9
17.3
13.5
DF51-12DEP-2C
CL0543-5075-0-00
12
21.6
22.1
22.5
22.9
19.3
15.5
DF51-14DEP-2C
CL0543-5076-0-00
14
23.6
24.1
24.5
24.9
21.3
17.5
DF51-16DEP-2C
CL0543-5077-0-00
16
25.6
26.1
26.5
26.9
23.3
19.5
DF51-18DEP-2C
CL0543-5078-0-00
18
27.6
28.1
28.5
28.9
25.3
21.5
DF51-20DEP-2C
CL0543-5079-0-00
30.1
30.5
30.9
27.3
23.5
DF51-22DEP-2C
CL0543-5080-0-00
22
31.6
32.1
32.5
32.9
29.3
25.5
DF51-24DEP-2C
CL0543-5081-0-00
24
33.6
34.1
34.5
34.9
31.3
27.5
DF51-26DEP-2C
CL0543-5082-0-00
26
35.6
36.1
36.5
36.9
33.3
29.5
DF51-28DEP-2C
CL0543-5083-0-00
28
37.6
38.1
38.5
38.9
35.3
31.5
DF51-30DEP-2C
CL0543-5084-0-00
30
39.6
40.1
40.5
40.9
37.3
33.5
16
Socket Contact
1.35
0.8
3.0
0.7
(9.9)
0.7 1.2
6.2
1
3.1
1.35
Part No.
HRS No.
Category
Purchase Unit
DF11-22SCF
CL0543-0601-0-00
Reel Contact
10,000pcs per reel
DF11-22SC
CL0543-0602-2-00
Loose Contact
100pcs per bag
DF11-2428SCF
CL0543-0500-2-00
Reel Contact
10,000pcs per reel
DF11-2428SC
CL0543-0501-5-00
Loose Contact
100pcs per bag
DF11A-2428SCF
CL0543-0634-9-00
Reel Contact
10,000pcs per reel
DF11A-2428SC
CL0543-0635-1-00
Loose Contact
100pcs per bag
DF11-30SCF
CL0543-0605-0-00
Reel Contact
10,000pcs per reel
DF11-30SC
CL0543-0606-3-00
Loose Contact
100pcs per bag
DF11-22SCFA(04)
CL0543-0603-5-04
Reel Contact
10,000pcs per reel
DF11-22SCA
CL0543-0604-8-00
Loose Contact
100pcs per bag
DF11-2428SCFA(04)
CL0543-0550-0-04
Reel Contact
10,000pcs per reel
DF11-2428SCA
CL0543-0551-3-00
Loose Contact
100pcs per bag
DF11-30SCFA(04)
CL0543-0607-6-04
Reel Contact
10,000pcs per reel
DF11-30SCA
CL0543-0608-9-00
Loose Contact
100pcs per bag
Note : DF11A-2428SCF/SC is the tin plated low insertion/extraction force type.
◆Applicable Wire (Tinned, Annealed Copper Wire)
● Recommended Wire
UL1061, UL1007 ( Note 2)
● Strip Length
1. 7 to 2. 3mm
Wire Size (Stranded Wire Conductor)
22 AWG(17/0.16)
Jacket Diameter
φ 1.2-1.45mm
24 AWG(11/0.16)
26 AWG(7/0.16)
φ 0.9-1.45mm
28 AWG(7/0.127)
30 AWG(7/0.1)
φ 0.75-1.2mm
Note 1 : Contact your Hirose representative when using a cable other than those specified.
Note 2 : DF11-22SCF/SC/SCFA/SCA is for UL1061.
17
Finish
Tin Plated
Gold Plated
0.9 1.3
14.1
0.9
0.7
3.0
1.7
0.5
10.4
1.58
Part No.
HRS No.
Category
Purchase Unit
DF11-EP2428PCF
CL0543-0615-4-00
Reel Contact
10,000pcs per reel
DF11-EP2428PC
CL0543-0616-7-00
Loose Contact
100pcs per bag
DF11-EP2428PCFA
CL0543-0617-0-00
Reel Contact
10,000pcs per reel
DF11-EP2428PCA
CL0543-0618-2-00
Loose Contact
100pcs per bag
● Recommended Wire
UL1061, UL1007
● Strip Length
1. 9 to 2. 3mm
Jacket Diameter
24 AWG(11/0.16)
26 AWG(7/0.16)
φ 0.9-1.45mm
28 AWG(7/0.127)
Note : Contact your Hirose representative when using a cable other than those specified.
18
Finish
Tin Plated
Gold Plated
Applicable Crimping Tool
Type
Applicator
Press Unit
Hand Tool
Contact Extraction Tool
Note
Note
Note
Note
Note
1
2
3
4
5
Part No.
HRS No.
Wire Type
AP105-DF11-22S
CL0901-4529-7-00
UL1061 (Note 3, 5)
DF11-22SCF/SCFA(04)
AP105-DF11-2428S
CL0901-4511-1-00
UL1007 (Note 3)
UL1061 (Note 3)
DF11-2428SCF/SCFA(04)
DF11A-2428SCF
AP105-DF11-30S
CL0901-4532-1-00
UL1007 (Note 3)
UL1061 (Note 3)
DF11-30SCF/SCFA(04)
AP105-DF11-EP2428P
CL0901-4528-4-00
UL1007 (Note 3)
UL1061 (Note 3)
DF11-EP2428PCF/PCFA
CM-105C
CL0901-0001-0-00
HT801/DF11-22S(A)
CL0550-0407-5-00
UL1061 (Note 4, 5)
DF11-22SC/SCA
HT801/DF11-2428S(A)
CL0550-0403-4-00
UL1007 (Note 4)
UL1061 (Note 4)
DF11-2428SC/SCA
DF11A-2428SC
HT801/DF11-30S(A)
CL0550-0408-8-00
UL1007 (Note 4)
UL1061 (Note 4)
DF11-30SC/SCA
HT801/DF11-EP2428P(A)
CL0550-0409-0-00
UL1007 (Note 4)
UL1061 (Note 4)
DF11-EP2428PC/PCA
DF-C-PO(B)
CL0550-0179-2-00
Please conduct crimping based on the "Crimp Quality Standard" and "Crimp Condition" table.
Any problems that occur from using tools other than those specified by Hirose are not covered by warranty.
Applicator dies can be switched to crimp other wire sizes and types. The additional dies are sold separately.
Hand tool dies cannot be switched.
The compatible wire is limited to UL1061, 22 AWG
19
Applicable Contacts
DF11-####SCF
DF11-EP####PCF
Mated Dimensions
●Wire-to-Board Connection (Straight Header)
【Dual-row】
【Single-row】
( 7.3 )
(5.25)
DF51-#S-2C
DF51A-#DP-2DSA
●Wire-to-Board Connection (Right Angle Header)
【Single-row】
【Dual-row】
(14.75)
(14.8)
DF51A-#DP-2DS
(7.3)
(4.5)
DF51-#S-2C
DF51-#DS-2C
DF51A-#P-2DS
●Wire-to-Wire Connection
【Single-row】
【Dual-row】
(18.05)
(17.9)
(3.4)
(8.4)
(3.4)
(5.4)
DF51A-#P-2DSA
(11.3)
(11.15)
DF51-#DS-2C
DF51-#DS-2C
DF51-#S-2C
DF51-#DEP-2C
DF51-#EP-2C
Precautions for Use
1. The connector could be damaged if it is pulled out forcibly. When it is hard to pull out, push it in slightly first and
then depress the lock and un- mate.
Please refer to the " DF51 Series Mating/ Unmating Operation Instruction Manual" ( ETAD- H0847- 00) for handling
precautions during mating.
2. When inserting a crimped contact into a socket, please refrain from inserting at a diagonal as doing so may affect
performance reliability.
Refer to the " DF51 Series Cable Assembly Procedure" ( ETAD- H0923- 00) for precautions during cable assembly.
Operating Environment
Please contact us if you are designing this connector into environmental conditions where high and low temperatures
are repeated.
While Taking into Consideration
Specifications mentioned in this catalog are reference values.
When considering to order or use this product, please confirm the Drawing and Product Specifications sheets.
Use an appropriate cable when using the connector in combination with cables.
If considering usage of a non- specified cable, please contact your sales representative.
If assembly process is done by jigs & tools which are not identified by Hirose, assurance will not be given.
If considering usage for below mentioned applications, please contact your sales representative.
In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public
infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given.
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
https://www.hirose.com https://www.hirose-connectors.com
※ The contents of this catalog are current as of date of 3/ 2021. Contents are subject to change without notice for the purpose of improvements.
21
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Hirose Electric:
DF5-1822SCF DF51-22DS-2C DF51-24DEP-2C DF51-30DS-2C DF51-24DS-2C DF51-2EP-2C DF51-4S-2C
DF51-3EP-2C DF51-4DS-2C DF51-20DEP-2C DF51-4DEP-2C DF51-14DEP-2C DF51-16DEP-2C DF51-30DEP-2C
DF51-6S-2C DF51-20DS-2C DF51-3S-2C DF51-12DS-2C DF51-2S-2C DF51-8DS-2C DF51-18DEP-2C DF5112DEP-2C DF51-26DEP-2C DF51-26DS-2C DF51-6EP-2C DF51-18DS-2C DF51-10DEP-2C DF51-10DS-2C
DF51-6DEP-2C DF51-6DS-2C DF51-8DEP-2C DF51-5S-2C DF51-14DS-2C DF51-22DEP-2C DF51-4EP-2C
DF51-5EP-2C DF51-28DS-2C DF51A-3P-2DSA(01) DF51A-6P-2DSA(01) DF51A-16DP-2DSA(01) DF51A-4P2DSA(01) DF51A-30DP-2DSA(01) DF51A-2P-2DSA(01) DF51A-5P-2DSA(01) DF51A-24DP-2DSA(01) DF51A16DP-2DSA DF51A-28DP-2DSA DF51A-5P-2DSA DF51A-4DP-2DSA(01) DF51A-18DP-2DSA(01) DF51A-4P-2DSA
DF51A-26DP-2DSA(01) DF51A-6DP-2DSA(01) DF51A-8DP-2DSA DF51A-10DP-2DSA DF51A-18DP-2DSA
DF51A-8DP-2DSA(01) DF51A-3P-2DSA DF51A-14DP-2DSA DF51A-26DP-2DSA DF51A-10DP-2DSA(01) DF51A30DP-2DSA DF51A-6P-2DSA DF51A-14DP-2DSA(01) DF51A-12DP-2DSA DF51A-6DP-2DSA DF51A-22DP-2DSA
DF51A-22DP-2DSA(01) DF51A-24DP-2DSA DF51A-4DP-2DSA DF51A-2P-2DSA DF51A-5P-2DS(50) DF51A-6P2DS(50) DF51A-4P-2DS(20) DF51-2P-2DS(20) DF51A-4P-2DS(50) DF51-4DP-2DS(50)
