HA16PRN-3SF-A(71)
HA16PRN-3SF-A(71)
    HRS(广濑)
    CONN 3 X 4 POS SILVER SOLDER CUP
HA16PRN-3SF-A(71) 数据手册
Circular Connectors for Audio Equipment HA Series Features Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.Circular connectors with lock mechanism for audio equipment Additional grounding feature prevents external noise. This series includes four different receptacle s i ze s a n d t wo t y p e s o f c a bl e c l a m p i n g mechanisms used on the plugs. Receptacle selection will depend on your particular design and available mounting space. Product Specifications No. of contacts Ratings Rated voltage 3 AC130V, DC180V 4 Rated current Operation temperature range Storage temperature range -25 to +70℃ -10 to +60℃ 15A 3 A (PCB dip type) 5A 5 4A Items Specifications Conditions 3 and 4 contacts: 5 mø max. 3 contacts (PCB dip type), 5 contacts: 10 mø min. Measured at DC 1 A 1,000 Mø min. Measured at DC 500 V No flashover or dielectric breakdown. AC 1,400 V for one minute 4. Vibration resistance No electrical discontinuity for 10 µs or greater 10 to 55 Hz/cycle, amplitude: 0.75 mm, in 3 axis directions, for 2 hours each direction 5.Shock resistance No electrical discontinuity for 10 µs or greater Acceleration: 490 m/s2, duration: 11 ms, 3 axis directions, 3 cycles each direction 6. Mating Cycles 3 and 4 contacts: a maximum of 10 mø 3 contacts (PCB dip style) 5 contacts: 20 mø max. 1,000 times 1. Contact resistance 2. Insulation resistance 3. Withstanding voltage 7. Temperature cycle Insulation resistance: 1,000 Mø max. 8. Moisture resistance -55°C: 30 minutes ➝ Normal temperature: 10 to 15 minutes ➝ 85°C: 30 minutes ➝ Normal temperature: 10 to 15 minutes, left for 5 cycles Insulation resistance: 10 Mø (at high humidity) min. Temperature: 40°C, relative humidity: 90 to 95%, 100 Mø (when dry) min. left for 96 hours Materials Parts Material Finish Remarks Shell Aluminum alloy or zinc alloy Matte finished, nickel plating ―――― Insulator Polyamide resin or PBT resin ―――― UL94V-0 Contact Copper alloy Silver plating ―――― In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2014.11w 1 HA Series●Circular Connectors for Audio Equipment Ordering information Plug and receptacle HA 16 PR N - 3 S F - A (**) q w e r t y u i o qModel name: HA Series wShell size: Shell size is the outer diameter of the mating interface of the plug. Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. eConnector shape: P: Plug R: Receptacle PR: Plug receptacle J: Jack rShell variation: A, B, C, etc. is used to note exterior shell changes. tNumber of contacts yContact form: P: Male contact S: Female contact uContact termination method or shape: A, B, C, etc. is used to note any changes to the termination method or type. iGang type: Notes a ganged arrangement of receptacles. oOther specifications: A two-digit number is added to indicate other specifications. 2 HA Series●Circular Connectors for Audio Equipment Plug B ØA Ø19 Ø16 Guide key (Representative example) HA16PA-3S(71) Part No. 104-0359-0 71 HA16PA-3S(71) 104-0426-6 71 HA16PK-4S(71) No. of ØA contacts 3 4.5 4 6 B 86 78 Weight Remarks 50g ------------------- A Ø19 Ø5.2 B (Representative example) HRS No. HA216P-4S(71) Part No. No. of contacts A B 104-0701-9 71 HA216P-3S(71) 3 78.5 53.5 104-0702-1 71 HA216P-4S(71) 4 77.7 52.7 104-0703-4 71 HA216P-5S(71) 5 78.5 53.5 Weight Remarks ---------40g ------------------- Jack 73 2 3 ØA 1 Ø19 Guide Notch (Representative example) HRS No. HA16JA-3P(76) 104-0358-8 76 Part No. HA16JA-3P(76) No. of contacts 3 ØA 4.5 Weight Remarks 40g ---------- 72 Ø5.2 47 Ø19 Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HRS No. (Representative example) HA216J-4P(76) HRS No. Part No. 104-0704-7 76 HA216J-3P(76) No. of contacts 3 104-0705-0 76 HA216J-4P(76) 4 104-0706-2 76 HA216J-5P(76) 5 Weight Remarks ---------- 40g ------------------- 3 HA Series●Circular Connectors for Audio Equipment Receptacle (Solder Type) (Large Flange Type) 22.5 Ground lug 26.95 37 1 27 19 Guide Notch 2 3 (Representative example) Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HA16R-3P(76) HRS No. Part No. 104-0349-7 76 HA16R-3P(76) No. of Weight contacts 3 13g Remarks ---------- (Medium Flange Type) Ground lug 3 25 18 1 2 2.5 21.5 27.1 23 30 (Representative example) HRS No. HA16RD-3P(76) Part No. No. of Weight contacts 104-0393-9 76 HA16RD-3P(76) 3 104-0402-8 76 HA16RD-4P(76) 4 Remarks ---------- 14g (Small Flange Type) ---------- Ground lug 3 22.2 16 1 2 2.5 18 21.5 27 24 (Representative example) HRS No. HA16RA-3P(76) Part No. No. of Weight contacts 3 104-0382-2 76 HA16RA-3P(76) 104-0408-4 76 HA16RA-4P(76) 4 104-0383-5 76 HA16RA-5P(76) 5 11g Remarks ---------------------------- Receptacle (Solder Type) (Inside Mount Type) HRS No. 104-0431-6 76 4 21.6 28 Part No. HA16RM-3P(76) 21.5 Ø21.5 15.6 2 HA16RM-3P(76) 3 2×M2.6×0.45 1 22.4 Ground lug 2 19.5 25.1 No. of Weight contacts 3 14g Remarks ---------- HA Series●Circular Connectors for Audio Equipment Receptacle (PCB Through Hole Type) (Inside Mount Type, Straight Dip) 2 21.5 Ø21.5 3 15.6 1 22.4 3×Ø0.8 Dip post dia. 1×0.8×0.6(Ground) Dip post dia. 2 21.6 2×M2.6×0.45 19.5 22.8 28 5 HA16RM-3PE(76) No. of Weight contacts HRS No. Part No. 104-0420-0 76 HA16RM-3PE(76) 3 Remarks 14g ---------- 2 21.5 22.4 15.6 3 28 3×Ø0.8 Dip post dia. 1×0.8×0.6(Ground) Dip post dia. 2 19.5 21.6 2×M2.6×0.45 2.54 Ø21.5 A 3.1 (Inside Mount Type, Right Angle Dip) 1 (The above shapes are examples. The left bend type is shown in this figure.) HRS No. HA16RM-3PB(76) No. of contacts Part No. 104-0416-2 76 HA16RM-3PB(76) 104-0418-8 76 HA16RM-3PD(76) A Weight 23.2 3 14g 25.8 Remarks Dip post down bent Dip post left bent Ground lug 18 PUSH 2 25 4 Plug-Receptacle (Solder Type) 1 (Small Flange Type) 3 2.4 23 30 27 32 37.2 42.7 4 (Representative example) HRS No. HA16PRH-3S HA16PRK-4S No. of Weight contacts Part No. 104-0395-4 HA16PRH-3S 3 104-0403-0 HA16PRH-4S 4 104-0404-3 HA16PRH-5S 5 104-0411-9 HA16PRK-3S 3 104-0427-9 HA16PRK-4S 4 Remarks Without ground lug 26g With ground lug Plug-Receptacle (Solder Type) (Inside Mount Type) 1 21.5 PUSH 3 21.6 28 31.5 Ø21.5 2 2×M2.6×0.45 15.6 29.6 22.4 Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (Representative example) 5.8 2 21.8 22.8 Ground lug (Representative example) HA16PRM-3S(05) HRS No. 104-0432-9 05 Part No. HA16PRM-3S(05) No. of Weight contacts 3 18g Remarks ---------- 5 HA Series●Circular Connectors for Audio Equipment Plug-Receptacle (PCB Through Hole Type) (Inside Mount Type, Straight Dip) HRS No. 2 21.8 22.8 5.8 Part No. 104-0421-2 71 21.5 1 Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PUSH 3 22.4 15.6 2 21.6 28 31.5 2×M2.6×0.45 HA16PRM-3SE(71) 21.5 1× 0.8×0.6(Ground) Dip post dia. HA16PRM-3SE(71) 3× 0.8×0.6 Dip post dia. 5 No. of contacts 3 Weight Remarks 18g ---------- (Inside Mount Type, Right Angle Dip) 5.8 22.8 21.8 1× 0.8×0.6(Ground) Dip post dia. 2 3× 0.8×0.6 Dip post dia. 1 3 3.1 28 21.6 PUSH 2 15.6 22.4 HA16PRM-3SB(71) 23.2 2.54 2×M2.6×0.45 No. of Weight Remarks contacts 104-0417-5 71 HA16PRM-3SB(71) 3 18g Dip post down bent HRS No. Part No. Gang Type (Plug-Receptacle Solder Type) 3×Ø3(Hole) 42 1 2 3 PUSH PUSH 1 2 1 2 3 3 PUSH 1 2 3 82 1×Ø2.6(Hole) 33.4 24.8 2.4 31.5 22 28 PUSH 4 1×2.6×3.2(Side face hole) 88 HA16PRN-3SF-A(71) 6 No. of contacts 104-0423-8 71 HA16PRN-3SF-A(71) 3 HRS No. Part No. Weight Remarks 80g 4 chain type HA Series●Circular Connectors for Audio Equipment (Plug-Receptacle PCB Through Hole Type) 42 3×Ø3(Hole) 4 1 2 22 28 PUSH 3 PUSH PUSH 1 2 1 2 3 PUSH 1 2 3 3 Convex Portion Height 0.5 82 1×Ø2.6(Hole) 33.8 24.8 2.4 1×2.6×3.2(Side face hole) 88 HRS No. No. of Weight contacts Part No. 104-0441-0 71 HA16PRN-3SE-A(71) 3 Remarks 68g r 4 chain type Dip post down bent type Panel Cutout Receptacle (Middle Flange Type) (Large Flange Type) 26.95 Ø1 Ø23 23 9.5 2×Ø2.8 2×Ø3.2 (Small Flange Type) 18 HA16RM 2×Ø2.8 Ø1 21.6 9.5 Ø21.7 2×Ø2.8 16 15.6 Plug Receptacle Type (Small Flange Type) (Inside Mount Type) 9 21.6 Ø22.2 12 14 5 23 Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HA16PRN-3SE-A(71) Ø21.7 2×Ø2.8 2×Ø2.8 18 15.6 HA16PRM 7 HA Series●Circular Connectors for Audio Equipment Panel Cutout Gang Type (Plug-Receptacle) 42 21 4× 4×8 Ø2 Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 11.5 22 12.5 13 3 63 82 Receptacle Dip Post Layout (The figure below shows the board surface in which connector terminal dip posts are to be inserted.) Dip post down bent type Dip post left bent type HA16RM-3PB(76) HA16RM-3PD(76) 3×Ø1 1×Ø1.3 (Ground) 1 3×Ø1 3 4.45 1 4.06 HA16RM-3PE(76) 2.54 3 (As viewed from the mating surface) 1×Ø1.3(Ground) 2.54 2 Dip post straight type 2 2×M2.6×0.45 1×Ø1.3(Ground) 4.06 3.96 2 1 4.45 3.96 3 3×Ø1 4.06 4.06 Plug-Receptacle Dip Post Layout (The figure below shows the board surface in which connector terminal dip posts are to be inserted.) Dip post down bent type 2.54 HA16PRM-3SB(71) 1 3 2 3×Ø1 4.06 4.06 1×Ø1.3 (Ground) Dip post straight type (As viewed from the mating surface) HA16PRN-3SE-A(71) HA16PRM-3SE(71) 63 4×Ø1.3 (Ground) 4.45 4.45 21 1×Ø1.3 (Ground) 2 1 3.96 3 3×Ø1 4.06 8 4.06 3.96 2×M2.6×0.45 Mounting hole (5 places) 12×Ø1 4.06 4.06 HA Series●Circular Connectors for Audio Equipment Coupling Combination Female Pin Male Pin Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (Plug) (Receptacle) (Jack) (Plug-Receptacle) Termination procedure Plug side (HA16 type, jack side connector follows the same assembly procedure) Screw Metal clamper 3mm approx. Plug shell unit Body Cable end(ref.) 3mm 11mm Operation procedure 1. Please choose a cable of which the outside diameter is 4-6mm. 2. Strip insulation of the cable end in the size as shown above. 3. Solder the cable to plug shell. 4. Crimp cable clamper, which holds cable, with a tool. 5. Fit the P shell unit to the cord tube, and tighten the locking screw with a Torque of 0.3-0.4N-m(3.5-4kg-cm) to complete the work. For details, contact our sales or engineering department before using the model HA16 plugs. Receptacle side Precautions If heat shrink tubing is applied to the solder terminating section for insulation purposes, overheating could reduce the torque of the screw tightness. Such overheating may result in loosening and possible loss of the screw. It is advised to confirm that a minimum torque of at least 0.1 N•m is obtained after termination. If a torque of at least 0.1 N•m is not realized, the screw should be tightened to between 0.3 and 0.4 N•m. Screw For details on usage, please contact our Sales or Engineering Department. 9 HA Series●Circular Connectors for Audio Equipment Terminal arrangement and major specifications Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2 1 Terminal arrangement 3 3 2 No. of contacts 3 4 Withstanding voltage AC1,400V a minute AC1,400V a minute Current rating 15A 3A(Board dip type) Insulation resistance Contact resistance Terminal arrangement 1,000Mø MIN. 5 mø MAX. 2 10 mø MAX. 5 1 3 4 No. of contacts 5 Withstanding voltage AC1,400V a minute Current rating 4A Insulation resistance 1,000 Mø MIN. Contact resistance 10 mø MAX. 5A 1,000 Mø MIN. Note 1. The above figures show the receptacle as viewed from the mating side. 2. The withstand voltages show test voltages. 3. The insulation resistances show the values at 500V DC. 4. The contact resistance show the values at 1A DC. 10 4 1 5 mø MAX. Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HA Series●Circular Connectors for Audio Equipment MEMO : 11 Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HA Series●Circular Connectors for Audio Equipment Powered by TCPDF (www.tcpdf.org) USA: HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS 2688 Westhills Court, Simi Valley, CA 93065-6235 Phone : +1-805-522-7958 Fax : +1-805-522-3217 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE 3255 Scott Boulevard, Building 7, Suite 101 Santa Clara, CA 95054 Phone : +1-408-253-9640 Fax : +1-408-253-9641 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. CHICAGO OFFICE 580 Waters Edge Lane, Suite 205 Lombard IL 60148 Phone : +1-630-282-6706 Mail : inquiries@hirose.com http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE) 37677 Professional Center Drive, Suite #100C Livonia, MI 48154 Phone : +1-734-542-9963 Fax : +1-734-542-9964 http://www.hirose.com/us/ THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : +31-20-6557460 Fax : +31-20-6557469 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH Herzog-Carl-Strasse 4 D-73760 Ostfildern (Scharnhauser Park) Phone : +49-711-4560-02-1 Fax : +49-711-4560-02-299 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. NUERNBERG OFFICE Muggenhofer Str. 136 90429 Nuernberg Phone : +49-911 32 68 89 63 Fax : +49-911 32 68 89 69 http://www.hirose.com/eu/ UNITED KINGDOM: HIROSE ELECTRIC EUROPE BV (UK BRANCH) 4 Newton Court, Kelvin Drive, Knowlhill, Milton Keynes, MK5 8NH Phone : +44-1908 202050 Fax : +44-1908 202058 http://www.hirose.com/eu/ CHINA: HIROSE ELECTRIC (SHANGHAI) CO., LTD. 1601, Henderson Metropolitan, NO.300, East Nanjing Road, Huangpu District, Shanghai, China 200001 Phone : +86-21-6391-3355 Fax : +86-21-6391-3335 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (SHANGHAI) CO.,LTD. BEIJING BRANCH A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, ChaoYang District, Beijing, 100025 Phone : +86-10-5165-9332 Fax : +86-10-5908-1381 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC TECHNOLOGIES (SHENZHEN) CO., LTD. Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre, 5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008 Phone : +86-755-8207-0851 Fax : +86-755-8207-0873 http://www.hirose.com/cn/ HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Room 1001, West Wing, Tsim Sha Tsui Centre, 66 Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong Phone : +852-2803-5338 Fax : +852-2591-6560 http://www.hirose.com/hk/ TAIWAN: HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : +886-2-2555-7377 Fax : +886-2-2555-7350 http://www.hirose.com/cn/ KOREA: SINGAPORE: HIROSE KOREA CO., LTD. HIROSE ELECTRIC SINGAPORE PTE. LTD. 1261-10, Jeoungwhang-Dong, Shihung-City, 10 Anson Road #26-1, International Plaza Kyunggi-Do 429-450 079903, Singapore Phone : +82-31-496-7000,7124 Phone : +65-6324-6113 Fax : +82-31-496-7100 Fax : +65-6324-6123 http://www.hirose.com/sg/ http://www.hirose.co.kr/ INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE Office NO.519, Regus-Green Boulevard, Level5, Tower C, Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India Phone : +91-12-660-8018 Fax : +91-120-4804949 http://www.hirose.com/sg/ INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE Unit No.03, Ground Floor, Explorer Building International Tech Park Whitefield Road, Bangalore 560066 Karnataka, India Phone : +91-80-4120 1907 Fax : +91-80-4120 9908 http://www.hirose.com/sg/ ® 12 MALAYSIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. (REPRESENTATIVE OFFICE) 1-10-07, Suntech @ Penang Cybercity (1164),Lintang Mayang Pasir 3,11950, Bayan Baru, Penang, Malaysia. Phone : +604-619-2564 Fax : +604-619-2574 http://www.hirose.com/sg/ 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 11/2014. Contents are subject to change without notice for the purpose of improvements.
HA16PRN-3SF-A(71) 价格&库存
很抱歉,暂时无法提供与“HA16PRN-3SF-A(71)”相匹配的价格&库存,您可以联系我们找货
