PM324MBAOSP
PM324MBAOSP
    ANDERSON
    POWERMOD 3X24 PIN STRAIGHT PCB
PM324MBAOSP 数据手册
PowerMod® Three Row -Male The PowerMod® connector family offers minimum size and high power. The high performance contacts and insulator are rated for 30 amps continuous. Applications requiring lower operating temperatures can be de-rated using our current-temperature chart. FEATURES • Mechanically polarized housings Only mate one-way, ensuring proper mating • High reliability positive retention latches Are made from stainless steel to provide optimum performance The three row male PowerMod connectors are offered in 9, 12, 18, 24 and 30 circuit sizes. The connectors are available with straight crimp, straight PCB or right angle PCB contacts. • PCB, panel or cable mounting A wide variety of contact styles with optional mounting brackets, panel clips and back-shell hoods provide broad design flexibility APP connectors are manufactured using the finest materials and world-class manufacturing processes. They embody the highest quality in the industry and meet all applicable industry standards. • Optional sequential contact mating 4 pin contact lengths can be custom specified for make-first/break-last or make-last/break-first circuits SPECIFICATIONS Electrical Mechanical Current Rating Mating Cycles No Load per IEC 512-5 1,000 30 Mating / Unmating Force per IEC 512-13 10 oz (3N) avg. UL / CSA Voltage Rating (AC/DC) 600 Contact Retention per IEC 512-8 Creepage / Clearance Distance 3.2 mm (.125") Min 18 lb (80N) Crimp 9 lb (40N) PCB Connector Contact Resistance per IEC 512-2 3 milliohms Materials Dielectric Withstanding Voltage (AC) Contact Wire Range (AWG) (mm²) * 2,200 #24 to #12 0.25 to 4.0 Insulator Pins Tail Solder (PCB contacts) PPS UL94 V-0, material group IIIa Copper alloy, 10 µ inch Au over Ni Sn/Ag/Cu (lead free) Operating Temperature (°C) (°F) -55° to 180° -67° to 356° Retention Clips Stainless steel Hoods PBT UL94 V-0 IEC 512-3, UL 1977 (Amperes) * Stranding, IEC class 5 or lower ORDERING INFORMATION Tooling PowerMod Part Number Plan - Three Row Male Series PM Rows # Poles Gender Contact Latch Mounting 3 09 M BA L CH 3 09, 12, 18, 24, 30 Poles M - Male OO - None (Crimp contacts ordered separately) BA - Straight PCB Solder Standard Length-RoHS RA - R/A PCB Solder Standard Length-RoHS Customized Connector - X X X Consult factory for options OO - None SB - R/A PCB Snap Bracket HB - R/A PCB Bracket with Hole ST - Self-tapping screws for straight PCB mount SP - Push in fastener for straight PCB mount CH - With clam-shell hood PC - Panel Clip MC - Mounting Clip SC - Screw for 1.6mm panel mount L - Connector with latch (standard for contact type OO) O - No latch www.andersonpower.com Part Number TM0001 TP0001 Mil-Standard M22520/1-01 N/A Description AF8 hand tool WA27F pneumatic crimp tool Turret & Locator for TM0001 & TP0001 TL0001 N/A For pin contacts TL0002 N/A For socket contacts PM1000G1 N/A PM1002G1 N/A PM1003G1 N/A Four indent hand tool with locator Contact insertion tool Contact extraction tool 200 180 160 140 120 100 80 60 40 20 0 3 Row Current vs Temperature Rise Temperature (°C) Temperature (°C) TEMPERATURE CHARTS 0 5 10 4mm² 15 Amps 12AWG 20 25 30 200 180 160 140 120 100 80 60 40 20 0 3 Row Ambient Temperature De-rating 0 5 30 circuits all energized 10 4mm² 15 Amps 12AWG 20 25 30 30 circuits all energized DIMENSIONS - mm(in.) Cable Connector ROWS A CONTACTS mm in. 3 - 09 3 - 12 3 - 18 3 - 24 3 - 30 28.5 33.5 43.5 53.5 63.5 1.12 1.32 1.71 2.11 2.50 A 20.4 (0.80) 22.1 (0.87) 9.4 (0.37) 7.9 (0.31) See accessory section for panel clip and mounting clip cut-out dimensions. ORDERING INFORMATION Crimp Contacts Part Number Description Standard Length 7.7mm PM16P2024S30 Pin PM16P1620S30 Pin PM16P1416S30 Pin PM16P12S30 Pin #24 / 20 #20 / 16 #16 / 14 #12 0.50 / 0.75 0.50 / 1.5 1.5 / 2.5 2.5 / 4.0 Pre-Mate 9.3mm PM16P2024A30 PM16P1620A30 PM16P1416A30 PM16P12A30 Pin Pin Pin Pin #24 / 20 #20 / 16 #16 / 14 #12 0.50 / 0.75 0.50 / 1.5 1.5 / 2.5 2.5 / 4.0 Pre-Mate 8.5mm PM16P2024B30 PM16P1620B30 PM16P1416B30 PM16P12B30 Pin Pin Pin Pin #24 / 20 #20 / 16 #16 / 14 #12 0.50 / 0.75 0.50 / 1.5 1.5 / 2.5 2.5 / 4.0 Post-Mate 6.4mm PM16P2024C30 PM16P1620C30 PM16P1416C30 PM16P12C30 Pin Pin Pin Pin #24 / 20 #20 / 16 #16 / 14 #12 0.50 / 0.75 0.50 / 1.5 1.5 / 2.5 2.5 / 4.0 AWG Wire sq. mm Cable Connector With Snap-in Panel Clip Part Number PM309MOOLOO PM312MOOLOO PM318MOOLOO PM324MOOLOO PM330MOOLOO Part Number PM309MOOLPC PM312MOOLPC PM318MOOLPC PM324MOOLPC PM330MOOLPC Description 3x3 MALE Cable Connector 3x4 MALE Cable Connector 3x6 MALE Cable Connector 3x8 MALE Cable Connector 3x10 MALE Cable Connector Panel Mount With Mounting Clip Part Number PM309MOOLMC PM312MOOLMC PM318MOOLMC PM324MOOLMC PM330MOOLMC Description 3x3 MALE Cable Connector 3x4 MALE Cable Connector 3x6 MALE Cable Connector 3x8 MALE Cable Connector 3x10 MALE Cable Connector Panel Mount With Screws Part Number PM309MOOLSC PM312MOOLSC PM318MOOLSC PM324MOOLSC PM330MOOLSC Description 3x3 MALE Cable Connector 3x4 MALE Cable Connector 3x6 MALE Cable Connector 3x8 MALE Cable Connector 3x10 MALE Cable Connector With Clam Shell Hood & Strain Relief Part Number PM309MOOLCH PM312MOOLCH PM318MOOLCH PM324MOOLCH PM330MOOLCH Description 3x3 MALE Cable Connector 3x4 MALE Cable Connector 3x6 MALE Cable Connector 3x8 MALE Cable Connector 3x10 MALE Cable Connectorr Description 3x3 MALE Cable Connector 3x4 MALE Cable Connector 3x6 MALE Cable Connector 3x8 MALE Cable Connector 3x10 MALE Cable Connector www.andersonpower.com DIMENSIONS - mm(in.) 3 Row - PCB Right Angle Connector 3 Row - PCB Hole Layout For Right Angle Connector A 9.4 (0.37) 3.7 (0.15) 15.2 (0.60) ROWS A CONTACTS mm in. L1 mm in. L2 mm in. 3 - 09 3 - 12 3 - 18 3 - 24 3 - 30 10 15 25 35 45 22.3 27.3 37.3 47.3 57.3 28.5 33.5 43.5 53.5 63.5 1.12 1.32 1.71 2.11 2.50 0.39 0.59 0.98 1.38 1.77 20.4 (0.80) 2.5 (0.10) 0.88 1.07 1.47 1.86 2.26 Finished hole 1.6 (0.06) 5.0 (0.20) 5.0 (0.20) ORDERING INFORMATION No Latch With Latch Part Number PM309MRALOO PM312MRALOO PM318MRALOO PM324MRALOO PM330MRALOO Description 3x3 MALE Right Angle PCB Solder 3x4 MALE Right Angle PCB Solder 3x6 MALE Right Angle PCB Solder 3x8 MALE Right Angle PCB Solder 3x10 MALE Right Angle PCB Solder Part Number PM309MRAOOO PM312MRAOOO PM318MRAOOO PM324MRAOOO PM330MRAOOO Description 3x3 MALE Right Angle PCB Solder 3x4 MALE Right Angle PCB Solder 3x6 MALE Right Angle PCB Solder 3x8 MALE Right Angle PCB Solder 3x10 MALE Right Angle PCB Solder Right Angle PCB Snap Bracket & Latch Right Angle PCB Snap Bracket & No Latch Part Number PM309MRALSB PM312MRALSB PM318MRALSB PM324MRALSB PM330MRALSB Part Number PM309MRAOSB PM312MRAOSB PM318MRAOSB PM324MRAOSB PM330MRAOSB Description 3x3 MALE Right Angle PCB Solder 3x4 MALE Right Angle PCB Solder 3x6 MALE Right Angle PCB Solder 3x8 MALE Right Angle PCB Solder 3x10 MALE Right Angle PCB Solder Description 3x3 MALE Right Angle PCB Solder 3x4 MALE Right Angle PCB Solder 3x6 MALE Right Angle PCB Solder 3x8 MALE Right Angle PCB Solder 3x10 MALE Right Angle PCB Solder Right Angle PCB Bracket With Hole & Latch Right Angle PCB Bracket With Hole & No Latch Part Number PM309MRALHB PM312MRALHB PM318MRALHB PM324MRALHB PM330MRALHB Part Number PM309MRAOHB PM312MRAOHB PM318MRAOHB PM324MRAOHB PM330MRAOHB Description 3x3 MALE Right Angle PCB Solder 3x4 MALE Right Angle PCB Solder 3x6 MALE Right Angle PCB Solder 3x8 MALE Right Angle PCB Solder 3x10 MALE Right Angle PCB Solder Description 3x3 MALE Right Angle PCB Solder 3x4 MALE Right Angle PCB Solder 3x6 MALE Right Angle PCB Solder 3x8 MALE Right Angle PCB Solder 3x10 MALE Right Angle PCB Solder PCB contacts and mounting accessories are designed for a board thickness of 1.60mm (.063) with a contact protrusion of 2.10 (.083). Other contact lengths are available upon request. www.andersonpower.com DIMENSIONS - mm(in.) 3 Row - PCB Straight Solder Connector 3 Row - PCB Hole Layout For Straight Solder Connector A 9.4 (0.37) 15.2 (0.60) 3.7 (0.15) 5.0 (0.20) 1.6 (0.06) 5.0 (0.20) ROWS A CONTACTS mm in. L1 mm in. L2 mm in. 3 - 09 3 - 12 3 - 18 3 - 24 3 - 30 10 15 25 35 45 22.3 27.3 37.3 47.3 57.3 28.5 33.5 43.5 53.5 63.5 1.12 1.32 1.71 2.11 2.50 0.39 0.59 0.98 1.38 1.77 0.88 1.07 1.47 1.86 2.26 Finished hole 20.4 (0.80) ORDERING INFORMATION With Latch Part Number PM309MBALOO PM312MBALOO PM318MBALOO PM324MBALOO PM330MBALOO No Latch Part Number PM309MBAOOO PM312MBAOOO PM318MBAOOO PM324MBAOOO PM330MBAOOO Description 3x3 MALE Straight PCB Solder 3x4 MALE Straight PCB Solder 3x6 MALE Straight PCB Solder 3x8 MALE Straight PCB Solder 3x10 MALE Straight PCB Solder Description 3x3 MALE Straight PCB Solder 3x4 MALE Straight PCB Solder 3x6 MALE Straight PCB Solder 3x8 MALE Straight PCB Solder 3x10 MALE Straight PCB Solder Push On PCB Fastener & Latch Push On PCB Fastener & No Latch Part Number PM309MBALSP PM312MBALSP PM318MBALSP PM324MBALSP PM330MBALSP Part Number PM309MBAOSP PM312MBAOSP PM318MBAOSP PM324MBAOSP PM330MBAOSP Description 3x3 MALE Straight PCB Solder 3x4 MALE Straight PCB Solder 3x6 MALE Straight PCB Solder 3x8 MALE Straight PCB Solder 3x10 MALE Straight PCB Solder Description 3x3 MALE Straight PCB Solder 3x4 MALE Straight PCB Solder 3x6 MALE Straight PCB Solder 3x8 MALE Straight PCB Solder 3x10 MALE Straight PCB Solder Self-tapping Screws For PCB Mount & Latch Self-tapping Screws For PCB Mount & No Latch Part Number PM309MBALST PM312MBALST PM318MBALST PM324MBALST PM330MBALST Part Number PM309MBAOST PM312MBAOST PM318MBAOST PM324MBAOST PM330MBAOST Description 3x3 MALE Straight PCB Solder 3x4 MALE Straight PCB Solder 3x6 MALE Straight PCB Solder 3x8 MALE Straight PCB Solder 3x10 MALE Straight PCB Solder Description 3x3 MALE Straight PCB Solder 3x4 MALE Straight PCB Solder 3x6 MALE Straight PCB Solder 3x8 MALE Straight PCB Solder 3x10 MALE Straight PCB Solder PCB contacts and mounting accessories are designed for a board thickness of 1.60mm (.063) with a contact protrusion of 2.10 (.083). Other contact lengths are available upon request. All Data Subject To Change Without Notice 15250 DS-PM3RM REV13 HEADQUARTERS: Anderson Power Products , 13 Pratts Junction Road, Sterling, MA 01564-2305 USA T:978-422-3600 F:978-422-0128 EUROPE: Anderson Power Products® Ltd., Unit 3, Europa Court, Europa Boulevard, Westbrook, Warrington, Cheshire, WA5 7TN United Kingdom T: +44 (0) 1925 428390 F: +44 (0) 1925 520203 ASIA / PACIFIC: IDEAL Anderson Asia Pacific Ltd., Unit 922-928 Topsail Plaza, 11 On Sum Street, Shatin N.T., Hong Kong T:+(852) 2636 0836 F:+(852) 2635 9036 CHINA: IDEAL Anderson Technologies (Shenzhen) Ltd., Block A8 Tantou Western Industrial Park, Songgang Baoan District, Shenzhen, PR. China 518105 T: +(86) 755 2768 2118 F: +(86) 755 2768 2218 TAIWAN: IDEAL Anderson Asia Pacific Ltd., Taiwan Branch, 4F.-2, No.116, Dadun 20th St., Situn District, Taichung City 407, Taiwan (R.O.C.) T: +(886) 4 2310 6451 F:+(886) 4 2310 6460 ® www.andersonpower.com
PM324MBAOSP 价格&库存
很抱歉,暂时无法提供与“PM324MBAOSP”相匹配的价格&库存,您可以联系我们找货
