8
7
4
5
6
1
2
3
REVISIONS
F
REV.
ECO. NO
DESCRIPTION
DATE
BY
E
2673
9/14/2012
LH
F
2828
04/09/2015
LH
H
3714
UPDATE NOTE 4(WAS 1 AMP)
UPDATE PROCESSING TEMPERATURE FOR NYLON 6T
MATERIAL
ADD 01-POSITION ON DIMENSION TABLE
07/27/2017
LH
F
E
E
B .020[0.50]
.079±.008 2.00±0.20
A±.008[0.20]
D
D
.079±.002 2.00±0.05
.142±.008 3.60±0.20
.079 2.00
C
C
.110±.008 2.80±0.20
.020±.002 0.50±0.05
A±.004 [ .10]
02-20, .008[0.20] MAX.
21-30, .012[0.30] MAX.
31-40, .016[0.40] MAX.
.079±.002 2.00±0.05
.031±.002 0.80±0.05
B
A
B
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING.
2. CONTACT MATERIAL: BRASS.
3. CONTACT PLATING: .000030" MIN NICKEL UNDERPLATE, GOLD FLASH OVERALL.
4. CURRENT RATING: 2.0 AMPS.
5. VOLTAGE RATING: 150V AC/DC.
6. INSULATOR RESISTANCE: 5000 MEGOHMS MIN.
7. CONTACT RESISTANCE: 20 MILLIOHMS MAX.
8. DIELECTRIC WITHSTANDING: 500V AC.
9. OPERATING TEMPERATURE: -40° C TO +105° C.
10. PROCESSING TEMP.: WAVE/MANUAL SOLDERING ONLY.
8
7
6
5
RECOMMENDED PCB LAYOUT
Pb
RoHS COMPLIANT
4
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN INCHES [MM]
TOLERANCES:
ANGULAR:
1
DECIMALS
.X= .012 [.30]
.XX= .008 [.20]
.XXX= .006 [.15]
DRAWN
DATE
NAME
09/17/2009 JH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
HEADER MALE 2mm CC, 1 ROW, ST
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 16:1
3
A
2
NRPNxx1PAEN-RC
DWG. NO.
10531
SHEET 1 OF 1
1
REV
H
FILE NAME: 10531, NRPN_ _1PAEN-RC
很抱歉,暂时无法提供与“NRPN401PAEN-RC”相匹配的价格&库存,您可以联系我们找货
