DESCRIPTION: QUIK-LOQ - FEMALE - SOLDER CUP - PANEL MOUNT - FIXED FRONT NUT
UNITS = MM [INCHES]
CHARACTERISSTICS
MATERIALS
SHELL : BRASS
SHELL PLATING : NICKEL
NUT : BRASS
NUT PLATING : NICKEL
LATCH SLEEVE : BRASS
LATCH SLEEVE PLATING : NICKEL
CONTACTS : COPPER ALLOY
CONTACT PLATING : 7µ" GOLD PLATED OVER 196µ" NICKEL MIN.
INSULATOR : PPS (HIGH TEMPERATURE)
820B YYY - 2 0 3 R F0 1
1 = GOLD FLASH
SERIES
9.50 [0.374]
FIXED FRONT NUT
# OF POSITIONS
(Ex. 002)
**SEE CHART A**
2= FEMALE
RoHS COMPLIANT
SOLDER CUP (PANEL MOUNT)
MECHANICAL
DURABILITY: 5000 CYCLES
OPERATING TEMP. RANGE: -40 C ~ +200 C
PROCESS TEMPERATURE : 260 C FOR 5 SECONDS
MAX. TORQUE VALUE : 2.5 Nm [22.1 IN/lbs]
SHIELDING: 75dB @ 10MHz
40dB @ 1GHz
NICKEL/CHROME PLATED SHELL
0.780
19.81
0.655
16.64
0.052
1.32
8]
35
[0.
0.323
8.20
(ACROSS FLATS)
0.327
8.30
0.425
10.80
M9*0.5
0.392
9.94
IP RATING: 50
CHART A
PANEL CUTOUT
TOLERANCE = +0.10, -0.0
[+0.004, -0.00]
**VIEW FROM TERMINATION END**
= KEY LOCATION
MAX PANEL THICKNESS = 5.50 [0.217]
1
1
1
2 POSITION
22 AWG MAX.
10 AMP MAX.
PIN
= 0.90 [0.035]
CONTACT
RESISTANCE = 6 mΩ
TEST VOLTAGE = 1000V
WORKING VOLTAGE = 330V
3 POSITION
22 AWG MAX.
8 AMP MAX.
PIN
= 0.90 [0.035]
CONTACT
RESISTANCE = 6 mΩ
TEST VOLTAGE = 1200V
WORKING VOLTAGE = 400V
4 POSITION
24 AWG MAX.
7 AMP MAX.
PIN
= 0.70 [0.028]
CONTACT
RESISTANCE = 7.5 mΩ
TEST VOLTAGE = 850V
WORKING VOLTAGE = 280V
RoHS COMPLIANT
N
C
THESE DRAWINGS AND SPECIFICATIONS
ARE THE PROPERTY OF NorComp AND
SHALL NOT BE REPRODUCED, COPIED
OR USED AS THE BASIS FOR THE
MANUFACTURE OR SALE OF APPARATUS
WITHOUT WRITTEN PERMISSION.
1
1
1
1
5 POSITION
24 AWG MAX.
6.5 AMP MAX.
PIN
= 0.70 [0.028]
6 POSITION
28 AWG MAX.
2.5 AMP MAX.
PIN
= 0.50 [0.020]
7 POSITION
28 AWG MAX.
2.5 AMP MAX.
PIN
= 0.50 [0.020]
9 POSITION
28 AWG MAX.
2 AMP MAX.
PIN
= 0.50 [0.020]
CONTACT
RESISTANCE = 7.5 mΩ
TEST VOLTAGE = 850V
CONTACT
RESISTANCE = 10 mΩ
TEST VOLTAGE = 850V
CONTACT
RESISTANCE = 10 mΩ
TEST VOLTAGE = 800V
WORKING VOLTAGE = 260V
CONTACT
RESISTANCE = 10 mΩ
TEST VOLTAGE = 600V
WORKING VOLTAGE = 200V
NorComp
DRAWN:
B. BRIDGES
DATE:
01-12-18
SCALE:
N.T.S.
SHEET
1
DWG NO.
OF
1
820BYYY-203RF01
REV:
2
很抱歉,暂时无法提供与“820B005-203RF01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 36+134.3393136+17.38422
