8
7
4
5
6
1
2
3
REVISIONS
F
REV.
ECO. NO
DESCRIPTION
DATE
BY
A
648
INITIAL RELEASE
6/15/2005
TT
B
720
FROM 3.4 TO 3.15, 2.5 TO 2.4
9/26/2005
TT
C
1126
MV
D
1869
UPDATE SPECIFICATIONS
9/12/2005
ADD CONTACT DEPTH 6.4mm, UPDATE TOP VIEW & 12/23/2008
TOLERANCE, WIDTH 2.54 WAS 2.4
F
JH
E
E
.100±.008 2.54±0.20
A±.08 [ 0.20]
B±.014 [ 0.35]
D
D
02-20, 0.20mm MAX.
21-40, 0.30mm MAX.
.124±.012 3.15±0.30
.252±.008 6.40±0.20
C
C
.335±.010 8.50±0.25
.063±.010 1.60±0.25
.024(w) X .016(t)
[0.60 X 0.40]
B
A
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING.
2. CONTACT MATERIAL: PHOSPHOR BRONZE.
3. CONTACT PLATING: SEE PART NUMBER CODING.
4. CURRENT RATING: 3 AMPS
5. INSULATOR RESISTANCE: 5000 MEGOHMS MIN.
6. CONTACT RESISTANCE: 20 MILLIOHMS MAX.
7. DIELECTRIC WITHSTANDING: AC 500V.
8. OPERATING TEMPERATURE: -40° C TO +105° C.
7
6
A
.100 2.54
B
.040±.002 1.02±0.05
RECOMMENDED PCB LAYOUT
UNLESS OTHERWISE SPECIFIED:
Pb
*INDICATED TEMPERATURE AND TIME IS FOR COMPONENT
INSULATOR. HIGHER PROCESSING TEMPERATURES MAY BE USED,
PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB, AND INSULATOR
DOES NOT EXCEED INDICATED TEMPERATURE AND TIME.
8
.100±.004 2.54±0.10
DIMENSIONS ARE IN INCHES[MM]
TOLERANCES:
ANGULAR: 5
.XX= .014 [.35]
.XXX= .008 [.20]
SURFACE FINISH: 63 Ra
REMOVE ALL BURRS AND SHARP EDGES .010 MAX
RoHS COMPLIANT
5
4
DRAWN
NAME
12/15/08
JH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT DESCRIPTION
TO BE REPRODUCED, USED OR
HEADER FEMALE,
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
PART NUMBER
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
2.54mm CC, 1 ROW, RA
xPxCxx1LGBN-RC
SIZE DWG. NO.
C
INTERPRET DIMENSIONS AND GEOMETRIC
TOLERANCING
PER: ANSI Y14.5M-1994
3
DATE
REV
10493
SCALE: 12:1
2
D
SHEET 1 OF 1
1
FILE NAME: Z:\COMPONENTS\Taiwan\10493, P(N)PxCxx1LGBN-RC PRINT: 2/3/2009
A
很抱歉,暂时无法提供与“PPTC101LGBN”相匹配的价格&库存,您可以联系我们找货
