8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
D
2668
E
2828
F
3542
F
DESCRIPTION
DATE
ADD 'LCP' MATERIAL AND REMOVE 'NYLON 9T'
09/06/2012
UPDATE LCP OPERATING TEMP TO -40 C TO +125 C
(WAS -40 C TO +105 C), UPDATE PROCESSING
TEMPERATURE FOR NYLON 6T MATERIAL (OBSOLETE 04/09/2015
DWG 11252)
ADD 001-POSITION ON DIMENSION TABLE
10/21/2016
BY
LH
LH
F
LH
B .012[ 0.30]
E
E
.197 5.00
A
.100 2.54
D
D
HEAD DIM.
.098 2.50
TAIL DIM.
.100 2.54
.025 0.64
C
C
A
.039 1.00
.100 2.54
.100 2.54
B
A
B
RECOMMENDER PCB LAYOUT
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING, UL 94V-0, BLACK.
2. CONTACT MATERIAL: SEE PART NUMBER CODING.
3. CONTACT PLATING: SEE PART NUMBER CODING.
4. CURRENT RATING: 3 AMPS.
5. INSULATOR RESISTANCE: 5000 MEGOHMS MIN.
6. CONTACT RESISTANCE: 20 MILLIOHMS MAX.
7. DIELECTRIC WITHSTANDING: 1000 VAC.
8. OPERATING TEMPERATURE: SEE PART NUMBER CODING.
8
7
6
Pb
RoHS COMPLIANT
5
4
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN INCHES [MM]
TOLERANCES:
ANGULAR:
DECIMALS
.XX= .012 [.3]
.XXX= .008 [.20]
.XXXX= .0040 [.100]
DRAWN
DATE
NAME
03/22/2011 LH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
HEADER .100" PITCH, 2 ROWS, STRAIGHT
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 4:1
3
2
_ R _C_ _ _D_ _N-RC
DWG. NO.
11636
SHEET 1 OF 1
1
REV
F
FILE NAME: 11636, _R_C_ _ _D(AA,AB,AC,AD,AE,AF,AG,AH,AI,AJ,AK,FA,FB,FC,FD,FE,FF,FG,FH,FI,FJ,ZA,ZB,ZC,ZD,ZI,ZJ,ZO,ZQ,ZR)N-RC
A
很抱歉,暂时无法提供与“PREC021DFBN-RC”相匹配的价格&库存,您可以联系我们找货
