W5282-12PG-535
W5282-12PG-535
    SWITCHCRAFT
    W5282-12PG-535
W5282-12PG-535 数据手册
KIT PART NO. NOTES: 1. PARTS TO BE BULK PACKED. 2. SOLDER CONTACTS ARE PRESSED INTO CONNECTOR. ALL SOLDER CUPS ARE FACING TOP KEY. 3. ALL DIMENSIONS ARE REFERENCE ONLY. 4. DIMENSIONS IN BRACKETS [ ] ARE METRIC. W5282-1XPG-518 W5282-1XPG-521 W5282-1XPG-524 W5282-1XPG-528 W5282-1XPG-530 W5282-1XPG-535 1.77 [44.9mm] GROMMET SIZE TO FIT CABLE O.D. 0.18 - 0.20 [4.6-5.1mm] 0.21 - 0.23 [5.3-5.8mm] 0.24 - 0.27 [6.1-6.8mm] 0.28 - 0.29 [7.1-7.4mm] 0.30 - 0.32 [7.6-8.1mm] 0.35 - 0.40 [8.9-10.2mm] KIT P/N NO. OF CONTACTS W5282-10PG-5XX W5282-11PG-5XX W5282-12PG-5XX W5282-1XPG-5XX (10) - #20 (11) - #20 (12) - #20 DIA. "D" 0.77 0.77 0.77 0.77 0.77 0.83 [19.6mm] [19.6mm] [19.6mm] [19.6mm] [19.6mm] [21.1mm] GROMMET SIZE SEE P/N LIST NO. OF CONTACTS NO. OF CONTACTS .75 [18.9mm] #4 HI/LO SCREW MAT'L: STAINLESS STEEL BACKSHELL STRAP MAT'L: UV THERMOPLASTIC, BLACK CUSTOMER PRINT ASSEMBLED REFERENCE VIEW 1.00 [25.4mm] .43 [10.9mm] .38 [9.6mm] 1.03 [26.1mm] .052 REF. [1.3mm] 2 2 1 3 11 1 10 10 D 4 4 8 8 6 11 9 9 5 5 7 7 MATING FACE CABLE IN-LINE INSERT, MALE MAT'L: UV THERMOPLASTIC, BLACK W5282-1XPG-5XX W5282-12PG-5XX PART NUMBER: 6 12 12 2 4 8 MATING FACE W5282-10PG-5XX BACKSHELL MAT'L: UV THERMOPLASTIC, BLACK 10 11 9 7 GROMMET, MAT'L: RUBBER, BLACK FOR CABLE O.D. SEE TABLE 1 3 10 5 #20 PIN CONTACTS SOLDER, GOLD PLATED SEE NOTE 2 WIRE VIEW SLEEVE MAT'L: THERMOPLASTIC, BLACK 2 1 3 6 3 4 9 8 5 6 7 MATING FACE W5282-11PG-5XX CUSTOMER APPROVAL THIS DOCUMENT CONTAINS CONFIDENTIAL INFORMATION PROPRIETARY TO CONXALL CORPORATION. ANY REPRODUCTION, DISCLOSURE, OR USE OF THIS DOCUMENT /INFORMATION IS EXPRESSLY PROHIBITED UNLESS AUTHORIZED IN WRITING BY CONXALL CORPORATION. APPROVED BY: DATE: A PAK REV. INIT. 08/19/19 DATE ALL INFORMATION ILLUSTRATED IS THE PROPERTY OF "CONXALL CORPORATION." UNAUTHORIZED DUPLICATION OR DISTRIBUTION OF THIS DOCUMENT IS PROHIBITED. ALL UNITS ARE IN FEET, INCHES, FRACTION OF INCHES AND DECIMALS. UNLESS OTHERWISE SPECIFIED TOLERANCES: 3 PLACE DECIMALS ±.005 ANGLES ±1° FRACTIONS ±1/16 = CRITICAL CHARACTERISTIC FLAG PER SPEC. XXXX DRAWING CREATED AND RELEASED PER DOR 10-2523JS-1 DESCRIPTION ORIG. DRAWN BY: DATE: 09/29/14 PAK CHECKED BY: 601 E. WILDWOOD VILLA PARK, IL 60181 TITLE: APPROVED BY: CABLE TO CABLE CONNECTOR KIT SCALE SIZE NTS B FILE: W5282-1XPG-5XX SHEET 1 OF 1 DIRECTORY: SLW #20 PIN CONTACTS (SOLDER), BACKSHELL CLAMP MULTI-CON-X, E-KEY, WEATHER RESISTANT CUSTOMER: STANDARD PRODUCT PART NUMBER: W5282-1XPG-5XX REV A
W5282-12PG-535 价格&库存
很抱歉,暂时无法提供与“W5282-12PG-535”相匹配的价格&库存,您可以联系我们找货
