Crimp
2.0mm
PHD CONNECTOR
Disconnectable Crimp style connectors
(.079") pitch
Features ––––––––––––––––––––––––
• Compact
2.0mm (.079") pitch connector, 8.8mm (.346") in height after
mounting and 5.0mm (.197") in width. This compact design
meets the demand for high-density connection.
• Reliable contacts
The box contact supplies stable contact performance even
under conditions of vibration, distortion, low voltage or low
current.
• Fully shrouded header
The header is fully shrouded, having walls on all four sides to
prevent improper mating and the intrusion of flux and other
contaminants.
This is a 2.0mm (.079") pitch, crimp style,
double-row, wire-to-board connector. It is
designed to meet the demand for highdensity and low-profile connection.
Specifications –––––––––––––––––––
• Current rating: 3A AC, DC (AWG#22)
• Voltage rating: 250V AC, DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/10m Ω max.
After environmental testing/20m Ω max.
• Insulation resistance:
1,000M Ω min.
• Withstanding voltage: 800V AC/minute
• Applicable wire: AWG #28 to #22
• Applicable PC board thickness: 1.6mm(.063")
* Contact JST if Lead-Free product is required.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
Standards ––––––––––––––––––––––
Recognized E60389
Certified LR20812
57
PHD
CONNECTOR
Contact –––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––
Applicable wire
1.5(.059)
Model No.
mm2
AWG #
Insulation O.D. mm(in.)
SPHD-002T-P0.5
0.08 to 0.21
28 to 24
0.9 to 1.5(.035 to .059)
SPHD-001T-P0.5
0.13 to 0.33
26 to 22
1.0 to 1.5(.039 to .059)
Q'ty /
reel
8,000
Material and Finish
Phosphor bronze, tin-plated
6.5(.256)
2.85(.112)
1.3
(.051)
Housing –––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––
Circuit
No.1
Circuit
No.1
B
Q'ty /
bag
PHDR-08VS
6.0( .236)
9.9( .390)
1,000
PHDR-10VS
8.0( .315)
11.9( .469)
1,000
12
PHDR-12VS
10.0( .394)
13.9( .547)
1,000
14
PHDR-14VS
12.0( .472)
15.9( .626)
1,000
16
PHDR-16VS
14.0( .551)
17.9( .705)
1,000
18
PHDR-18VS
16.0( .630)
19.9( .783)
1,000
PHDR-20VS
18.0( .709)
21.9( .862)
1,000
22
PHDR-22VS
20.0( .787)
23.9( .941)
1,000
24
PHDR-24VS
22.0( .866)
25.9(1.020)
1,000
26
PHDR-26VS
24.0( .945)
27.9(1.098)
1,000
4.2(.165)
28
PHDR-28VS
26.0(1.024)
29.9(1.177)
1,000
5.0(.197)
30
PHDR-30VS
28.0(1.102)
31.9(1.256)
1,000
32
PHDR-32VS
30.0(1.181)
33.9(1.335)
1,000
34
PHDR-34VS
32.0(1.260)
35.9(1.413)
1,000
2.0
(.079)
A
B
Dimensions mm(in.)
A
8
7.3(.287)
1.95
(.077)
Model No.
10
Circuit
No.2
H JST
2.0
(.079)
Circuits
Material
Nylon 66, UL94V-0, natural (white)
As the color identification,
the following alphabet shall be put in the underlined part.
For availability, delivery and minimum order quantity, contact JST.
ex.
58
PHDR-10VSS…natural (white)
K…black Y…yellow E…blue R…red
PHD
CONNECTOR
Shrouded header –––––––––––––––––––––––––––––––––––––––––––––––––––––––––
Side entry type
2.0
1.95 (.079)
(.077)
Circuit
No.2
Circuit
No.1
2.0(.079)
1.95
(.077)
5.0(.197)
Glass-filled nylon
Top entry
Side entry
type
type
7.0(.276)
5.0(.197)
1.5 2.0
(.059) (.079)
A
B
A
B
Model No.
Circuits
JST
H
6.5(.256)
9.5(.374)
[3.0(.118)] 6.5(.256)
JST
H
Circuit
No.2
Circuit No.1
Circuit No.1
Circuit No.1
Q'ty / box
Dimensions mm(in.)
Nylon
Top entry
type
[3.0
(.118)]
2.0
(.079)
Top entry type
Side entry
type
A
B
Top
entry
type
Side
entry
type
8
B 8B-PHDSS
S 8B-PHDSS
6.0( .236)
9.9( .390)
500
10
B10B-PHDSS
S10B-PHDSS
B10B-PHDSS-B
S10B-PHDSS-B
8.0( .315)
11.9( .469)
500
500
12
B12B-PHDSS
S12B-PHDSS
B12B-PHDSS-B
S12B-PHDSS-B
10.0( .394)
13.9( .547)
500
500
14
B14B-PHDSS
S14B-PHDSS
B14B-PHDSS-B
S14B-PHDSS-B
12.0( .472)
15.9( .626)
500
250
16
B16B-PHDSS
S16B-PHDSS
B16B-PHDSS-B
S16B-PHDSS-B
14.0( .551)
17.9( .705)
500
250
18
B18B-PHDSS
S18B-PHDSS
B18B-PHDSS-B
S18B-PHDSS-B
16.0( .630)
19.9( .783)
500
250
B20B-PHDSS
S20B-PHDSS
B20B-PHDSS-B
S20B-PHDSS-B
18.0( .709)
21.9( .862)
250
250
22
B22B-PHDSS
S22B-PHDSS
B22B-PHDSS-B
S22B-PHDSS-B
20.0( .787)
23.9( .941)
250
250
24
B24B-PHDSS
S24B-PHDSS
B24B-PHDSS-B
S24B-PHDSS-B
22.0( .866)
25.9(1.020)
250
200
26
B26B-PHDSS
S26B-PHDSS
B26B-PHDSS-B
S26B-PHDSS-B
24.0( .945)
27.9(1.098)
250
200
28
B28B-PHDSS
S28B-PHDSS
B28B-PHDSS-B
S28B-PHDSS-B
26.0(1.024)
29.9(1.177)
250
200
30
B30B-PHDSS
S30B-PHDSS
B30B-PHDSS-B
S30B-PHDSS-B
28.0(1.102)
31.9(1.256)
250
200
32
B32B-PHDSS
S32B-PHDSS
B32B-PHDSS-B
S32B-PHDSS-B
30.0(1.181)
33.9(1.335)
250
200
34
B34B-PHDSS
S34B-PHDSS
B34B-PHDSS-B
S34B-PHDSS-B
32.0(1.260)
35.9(1.413)
250
200
Material and Finish
Post: Copper alloy, copper-undercoated, tin/lead-plated
Wafer: Glass-filled nylon 66, UL94V-0, natural (ivory)
ex.
B10B-PHDSS-
ex.
B10B-PHDSS-B-
S…natural (ivory)
S…natural (white)
59
PHD
CONNECTOR
PC board layout (viewed from soldering side) and Assembly layout –––––––––––––––––––
Top entry type
Side entry type
11.8(.465)
5.0(.197)
7.0(.276) min.
0.7 + 00.1
(.028 + 0.004)dia.
Odd number
circuits
Circuit No.1
[3.0(.118)]
Even number
circuits
2.0±0.05
(.079±.002)
8.8(.346)
2.0±0.05
(.079±.002)
)dia.
2.0±0.05
1.95
(.079±.002) (.077)min.
5.0(.197)
[3.0(.118)]
0.7
(.028
1.95
(.077)min.
1.5
(.059)min.
2.0±0.05
(.079±.002)
+ 0.1
Note:
1. Tolerances are non-cumulative: ±0.05mm(±.002") for all centers.
2. Hole dimensions differ according to the kind of PC board and piercing method. If printed circuit boards made of hard material are used, the hole
dimensions should be larger. The dimensions above should serve as a guideline. Contact JST for details.
Applicator for the semi-automatic press AP-K2N –––––––––––––––––––––––––––––––
Contact
SPHD-001T-P0.5
SPHD-002T-P0.5
60
Crimp applicator MKS-L-10
with safety cover
without safety cover
Compact crimp applicator MKS-LS-10
with safety cover
Strip-crimp applicator MKS-SC-10
with safety cover
APLMK SPHD001-05
APLNC SPHD001-05
APLMKLS SPHD001-05
APLLSNC SPHD001-05
APLSC SPHD001-05
APLMK SPHD002-05
APLNC SPHD002-05
APLMKLS SPHD002-05
APLLSNC SPHD002-05
APLSC SPHD002-05
很抱歉,暂时无法提供与“S22B-PHDSS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+8.110751+1.05131
- 10+6.8658910+0.88995
- 250+5.46803250+0.70876
- 500+5.20697500+0.67493
- 1000+4.958261000+0.64269
- 5000+4.426085000+0.57371
- 10000+4.2149810000+0.54635
