HIF3BA-50PA-2.54DS(71) 数据手册
Ribbon Cable connector Compliant with MIL Standard
HIF3B Series
■Features
1. Product Compliant with MIL Standard
HIF3B series has been developed as a product compliant with MIL
standard, and used for wide applications.
2. UL Approval Product
HIF3B series connectors are UL approved.
Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
3. Mechanism to Prevent Mis-insertion
This connector is equipped with the mechanism to prevent Misinsertion as follows.
1 The system provides the convex area to insert the guide-key on the
pin header side, and to guide it in combination with the socket
convex area (MIL standard).
2 The system embeds and guides the polarizing key in the socket holes.
4. Applicable Cable 28 AWG (IDC type)
The applicable cable is UL2651 28 AWG flat cable
(7cores./0.127mm, jacket dia. 0.9±0.1mm).
■Product Specifications
Rating
Current rating :
Operating Temperature Range :
Storage Temperature Range :
IDC : 1A 28 AWG Crimp : 32, 36 AWG : 1A Other : 3A
–55 to +85ç (Note 1)
–10 to +60ç (Note 2)
Voltage rating :
Operating Moisture Range :
Storage Humidity Range :
200V
40 to 80%
40 to 70% (Note 2)
Item
1. Insulation Resistance
Specification
Condition
1000Mø min.
500V DC
2. Withstanding voltage
No flashover or insulation breakdown.
650V AC/1 minute
3. Contact Resistance
15mø max.
0.1A
4. Vibration
No electrical discontinuity of 1μs or more
Frequency : 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions.
5. Humidity (Steady state) Insulation resistance : 1000Mø min.
6. Temperature Cycle
96 hours at temperature of 40ç and humidity of 90% to 95%
(-55ç : 30 minutes ➝ 15 to 35ç : 5 minutes max.
No damage, cracks, or parts looseness.
125ç : 30 minutes ➝ 15 to 35ç : 5 minutes max.) 5 cycles
7. Durability (Mating/un-mating) Contact resistance : 15mø max.
500 cycles
Solder bath : 260ç for 10 seconds
8. Resistance to Soldering heat No deformation of components affecting performance.
Manual soldering : 360ç for 5 seconds
Note 1 : Includes temperature rise caused by current flow.
Note 2 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and
Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation.
Note 3 : Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a
specific part number shown.
Note 4 : Please note that there is a risk of deforming the lock when an excessive load is applied to the inside.
■Material / Finish
Part
Material
Finish
Remarks
Insulator
PBT
Black
UL94V-0
Socket Contact
Beryllium copper
Pin header contact
Brass
Connection area
Gold plated
Selective Gold plated
B15
HIF3B Series●Ribbon Cable connector Compliant with MIL Standard
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
●Socket
HIF 3B - * D - 2.54 R
q
w
e
r
t
y
q Series Name
: HIF
w Series No.
: 3B, 3BA, 3BB (50, 60, 64 contacts only)
e Number of contacts : 6,10,14,16, 20, 26, 30, 34, 40, 50, 60, 64
r Contact alignment : D : Double
t Contact pitch
: 2.54mm
y Connection type
R : ID type
●Pin Header
HIF 3B - * P A - 2.54 DS
q
w
e
q Series Name
: HIF
w Series No.
r
t
y
u
: (14 contacts not included) 3BC : (10 contacts only)
3B
3BA, 3BB : (50, 60, 64 contacts only) 3BD : (10 contacts only)
r
P
: Pin header
t
A
: Selective gold plated
y Contact pitch
: 2.54mm
u Contact style
B16
DS
: Right angle type
DSA
: Straight type
■Socket (With guide to prevent mis-insertion)
Body
Protector
Clamp
Note1, Note2 : The number of polarizing keys and polarizing keyways changes according to products. Refer to the list as shown below.
Note3 : The 50, 60 and 64 contact connector contain two types of polarizing guides. Use the products, referring to Notes 1 and 2.
Note4 : The 6 contact has no polarizing mark.
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
C
D
Polarizing Guide
(Note 1)
HIF3BA- 6D-2.54R(63) 610-0032-3 63
6
12.19 5.08 6.35 7.72
HIF3BA-10D-2.54R(63) 610-0021-7 63
10
17.27 10.16 11.43 12.8
★ HIF3BA-14D-2.54R(63) 610-0022-0 63
14
22.35 15.24 16.51 17.88
★ HIF3BA-16D-2.54R(63) 610-0023-2 63
16
24.89 17.78 19.05 20.42
★ HIF3BA-20D-2.54R(63) 610-0024-5 63
29.97 22.86 24.13 25.5
★ HIF3BA-26D-2.54R(63) 610-0025-8 63
26
37.59 30.48 31.75 33.12
★ HIF3BA-30D-2.54R(63) 610-0026-0 63
30
42.67 35.56 36.83 38.2
★ HIF3BA-34D-2.54R(63) 610-0027-3 63
34
47.75 40.64 41.91 43.28
★ HIF3BA-40D-2.54R(63) 610-0028-6 63
40
55.37 48.26 49.53 50.9
★ HIF3BA-50D-2.54R(63) 610-0029-9 63
50
68.07 60.96 62.23 63.6 One on right and left sides, resp.
★ HIF3BB-50D-2.54R(63) 610-0041-4 63
50
★ HIF3BA-60D-2.54R(63) 610-0030-8 63
60
80.77 73.66 74.93 76.3 One on right and left sides, resp.
★ HIF3BB-60D-2.54R(63) 610-0042-7 63
60
★ HIF3BA-64D-2.54R(63) 610-0031-0 63
64
85.85 78.74 80.01 81.38 One on right and left sides, resp.
★ HIF3BB-64D-2.54R(63) 610-0043-0 63
64
Polarizing Keyway
(Note 2)
RoHS
None
One on left side
One at center
YES
One on right and
left sides, resp.
One at center
One at center
One at center
The products marked with ★ comply with MIL standard.
B17
■Socket
Body
Protector
Clamp
Note1 : The number of polarizing keys and polarizing keyways changes according to products. For details, refer to the list as shown below.
Note2 : The 6 contact has no polarizing mark.
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
C
D
HIF3B- 6D-2.54R(63) 610-0012-6 63
6
★ HIF3B-10D-2.54R(63) 610-0001-0 63
★ HIF3B-14D-2.54R(63) 610-0002-2 63
10
17.27 10.16 11.43 12.80
14
★ HIF3B-16D-2.54R(63) 610-0003-5 63
★ HIF3B-20D-2.54R(63) 610-0004-8 63
16
29.97 22.86 24.13 25.50
★ HIF3B-26D-2.54R(63) 610-0005-0 63
★ HIF3B-30D-2.54R(63) 610-0006-3 63
26
30
★ HIF3B-34D-2.54R(63) 610-0007-6 63
★ HIF3B-40D-2.54R(63) 610-0008-9 63
34
40
55.37 48.26 49.53 50.90
★ HIF3B-50D-2.54R(63) 610-0009-1 63
★ HIF3B-60D-2.54R(63) 610-0010-0 63
50
60
★ HIF3B-64D-2.54R(63) 610-0011-3 63
64
Polarizing Guide
(Note 1)
RoHS
None
One on left side
YES
One on right and
left sides, resp.
B18
■Four Wall Angle Through hole
BPCB mounting pattern
Note 1, Note 2 : The number of polarizing slot and key installed positions
Note 3 : The spacer moves to the right according to the number of
contacts.
Note 4 : The 10, 50, 60 and 64 contact connectors contain two types of
polarizing slots.
Use products, referring to (Note 1) (Note 2).
■n=number of contacts
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
C
★ HIF3BA-10PA-2.54DS(63) 610-0091-2 63
10
32.0 17.5 10.16
HIF3BD-10PA-2.54DS(63) 610-0171-0 63
10
32.0 17.5 10.16
★ HIF3BA-14PA-2.54DS(63) 610-0092-5 63
14
37.1 22.6 15.24
★ HIF3BA-16PA-2.54DS(63) 610-0093-8 63
16
39.6 25.1 17.78
★ HIF3BA-20PA-2.54DS(63) 610-0094-0 63
★ HIF3BA-26PA-2.54DS(63) 610-0095-3 63
26
52.3 37.8 30.48
★ HIF3BA-30PA-2.54DS(63) 610-0096-6 63
30
57.4 42.9 35.56
★ HIF3BA-34PA-2.54DS(63) 610-0097-9 63
34
62.5 48.0 40.64
★ HIF3BA-40PA-2.54DS(63) 610-0098-1 63
40
70.1 55.6 48.26
★ HIF3BA-50PA-2.54DS(63) 610-0099-4 63
50
82.8 68.3 60.96
★ HIF3BB-50PA-2.54DS(63) 610-0131-5 63
50
82.8 68.3 60.96
★ HIF3BA-60PA-2.54DS(63) 610-0100-1 63
60
95.5 81.0 73.66
★ HIF3BB-60PA-2.54DS(63) 610-0132-8 63
60
95.5 81.0 73.66
★ HIF3BA-64PA-2.54DS(63) 610-0101-4 63
64
100.6 86.1 78.74
★ HIF3BB-64PA-2.54DS(63) 610-0133-0 63
64
100.6 86.1 78.74
D
28.14
MAX51.1
28.14
MAX51.1
33.24
MAX56.2
35.74
MAX58.7
40.84
MAX63.8
48.44
MAX71.4
53.54
MAX76.5
58.64
MAX81.6
66.24
MAX89.2
78.94
MAX101.9
78.94
MAX101.9
91.64
MAX114.6
91.64
MAX114.6
96.74
MAX119.7
96.74
MAX119.7
E
F
21.8 27.9
Polarizing Slot
(Note 1)
None
Polarizing Key Install
RoHS
(Note 2)
One on right side
21.8 27.9
None
26.9 33.0
One on right side
29.5 35.5
34.5 40.6
42.2 48.3
One at center
47.2 53.3
YES
52.3 58.4
59.9 66.0
72.6 78.7 One on right and left sides, resp.
72.6 78.7
One on right and
left sides, resp.
One at center
85.3 91.4 One on right and left sides, resp.
85.3 91.4
One at center
90.4 96.5 One on right and left sides, resp.
90.4 96.5
One at center
B19
■Four-Wall Straight Through hole
contacts.
polarizing slots.
Use products, confirming (Note 1) (Note 2).
Note 5 : The 6 contact has no polarity mark.
Unit : mm
Part No.
HRS No.
No. of Contacts
562-0503-9 71
6
26.92 12.42 05.08
HIF3BA-10PA-2.54DSA(63) 610-0111-8 63
10
32.0 17.5 10.16
★ HIF3BD-10PA-2.54DSA(63) 610-0181-3 63
★ HIF3BA-14PA-2.54DSA(63) 610-0112-0 63
10
32.0 17.5 10.16
14
37.1 22.6 15.24
★ HIF3BA-16PA-2.54DSA(63) 610-0113-3 63
★ HIF3BA-20PA-2.54DSA(63) 610-0114-6 63
16
39.6 25.1 17.78
★ HIF3BA-26PA-2.54DSA(63) 610-0115-9 63
★ HIF3BA-30PA-2.54DSA(63) 610-0116-1 63
26
52.3 37.8 30.48
30
57.4 42.9 35.56
★ HIF3BA-34PA-2.54DSA(63) 610-0117-4 63
★ HIF3BA-40PA-2.54DSA(63) 610-0118-7 63
34
62.5 48.0 40.64
40
70.1 55.6 48.26
★ HIF3BA-50PA-2.54DSA(63) 610-0119-0 63
★ HIF3BB-50PA-2.54DSA(63) 610-0141-9 63
50
82.8 68.3 60.96
50
82.8 68.3 60.96
★ HIF3BA-60PA-2.54DSA(63) 610-0120-9 63
★ HIF3BB-60PA-2.54DSA(63) 610-0142-1 63
60
95.5 81.0 73.66
★ HIF3-6PA-2.54DSA(71)
★ HIF3BA-64PA-2.54DSA(63) 610-0121-1 63
★ HIF3BB-64PA-2.54DSA(63) 610-0143-4 63
A
B
C
60
95.5 81.0 73.66
64
100.6 86.1 78.74
64
100.6 86.1 78.74
D
23.06
MAX46.02
28.14
MAX51.1
28.14
MAX51.1
33.24
MAX56.2
35.74
MAX58.7
40.84
MAX63.8
48.44
MAX71.4
53.54
MAX76.5
58.64
MAX81.6
66.24
MAX89.2
78.94
MAX101.9
78.94
MAX101.9
91.64
MAX114.6
91.64
MAX114.6
96.74
MAX119.7
96.74
MAX119.7
E
F
Polarizing Slot
(Note 1)
RoHS
(Note 2)
16.7 22.82
One at center
None
21.8 27.9
None
One on right side
21.8 27.9
None
26.9 33.0
One on right side
29.5 35.5
34.5 40.6
42.2 48.3
One at center
47.2 53.3
YES
52.3 58.4
59.9 66.0
72.6 78.7
One on right and
left sides, resp.
One at center
85.3 91.4
One at center
90.4 96.5
One at center
B20
■Three Wall Angle Type
Note 3 : The spacer moves according to the number of contacts.
Note 4 : The 10 contact connector consists of two types.
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
C
★ HIF3BD-10PA-2.54DS(63) 610-0051-8 63
10
32.0 17.5 10.16
HIF3BC-10PA-2.54DS(63) 610-0151-2 63
10
32.0 17.5 10.16
★ HIF3BD-16PA-2.54DS(63) 610-0052-0 63
16
39.6 25.1 17.78
★ HIF3BD-20PA-2.54DS(63) 610-0053-3 63
★ HIF3BD-26PA-2.54DS(63) 610-0054-6 63
26
52.3 37.8 30.48
★ HIF3BD-30PA-2.54DS(63) 610-0055-9 63
30
57.4 42.9 35.56
★ HIF3BD-34PA-2.54DS(63) 610-0056-1 63
34
62.5 48.0 40.64
★ HIF3BD-40PA-2.54DS(63) 610-0057-4 63
40
70.1 55.6 48.26
★ HIF3BD-50PA-2.54DS(63) 610-0058-7 63
50
82.8 68.3 60.96
★ HIF3BD-60PA-2.54DS(63) 610-0059-0 63
60
95.5 81.0 73.66
★ HIF3BD-64PA-2.54DS(63) 610-0060-9 63
64
100.6 86.1 78.74
D
28.14
MAX51.1
28.14
MAX51.1
35.74
MAX58.7
40.84
MAX63.8
48.44
MAX71.4
53.54
MAX76.5
58.64
MAX81.6
66.24
MAX89.2
78.94
MAX101.9
91.64
MAX114.6
96.74
MAX119.7
E
F
21.8 27.9
Polarizing Slot
(Note 1)
(Note 2)
None
One on right side
21.8 27.9
RoHS
None
29.5 35.5
34.5 40.6
42.2 48.3
One at center
47.2 53.3
52.3 58.4
One on right and
left sides, resp.
YES
59.9 66.0
72.6 78.7
90.4 96.5
B21
■Four Wall Straight Through hole
[Flux Blister Prevention Type]
Note1 : The number of polarizing slot and key installed positions changes
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
C
★ HIF3CA-10PA-2.54DSA(63) 610-0701-1 63
10
32.0 17.5 10.16
HIF3CD-10PA-2.54DSA(63) 610-0722-1 63
10
32.0 17.5 10.16
★ HIF3CA-16PA-2.54DSA(63) 610-0703-7 63
16
39.6 25.1 17.78
★ HIF3CA-20PA-2.54DSA(63) 610-0704-0 63
★ HIF3CA-26PA-2.54DSA(63) 610-0705-2 63
26
52.3 37.8 30.48
★ HIF3CA-30PA-2.54DSA(63) 610-0706-5 63
30
57.4 42.9 35.56
★ HIF3CA-34PA-2.54DSA(63) 610-0707-8 63
34
62.5 48.0 40.64
★ HIF3CA-40PA-2.54DSA(63) 610-0708-0 63
40
70.1 55.6 48.26
★ HIF3CA-50PA-2.54DSA(63) 610-0709-3 63
50
82.8 68.3 60.96
★ HIF3CB-50PA-2.54DSA(63) 610-0721-9 63
50
82.8 68.3 60.96
★ HIF3CB-60PA-2.54DSA(63) 610-0723-4 63
60
95.5 81.0 73.66
★ HIF3CB-64PA-2.54DSA(63) 610-0724-7 63
64
100.6 86.1 78.74
D
28.14
MAX51.1
28.14
MAX51.1
35.74
MAX58.7
40.84
MAX63.8
48.44
MAX71.4
53.54
MAX76.5
58.64
MAX81.6
66.24
MAX89.2
78.94
MAX101.9
78.94
MAX101.9
91.64
MAX114.6
96.74
MAX119.7
E
F
21.8 27.9
Polarizing Slot
None
21.8 27.9
Polarizing Key Install RoHS
One on right side
None
29.5 35.5
34.5 40.6
42.2 48.3
One at center
47.2 53.3
YES
52.3 58.4
One on right and
left sides, resp.
59.9 66.0
72.6 78.7
85.3 91.4
One at center
90.4 96.5
B22
BPolarizing Key
HIF3B-GK
562-0601-8
HIF3-GPIN(A)
HIF3BA-GPIN
Note1 : One unit of this
product is a set of five
pieces in conjunction
with a runner. The
unit for sale is defined
one pack containing
20 pieces.
Note2 : This product is
applicable to HIF3A*D2.54R, HIF3C*D2.54C and
HIF3BA-*D2.54C
products.
Part No.
HRS No.
Material
Remarks
with a runner. The
one pack containing
20 pieces.
applicable to the
HIF3BA-*D2.54R
product.
RoHS
HIF3-GPIN(A) 562-0126-6 Poly acetal (white) A set of 5 pieces YES
Part No.
HRS No.
Material
Remarks
RoHS
HIF3BA-GPIN 612-0500-2 Poly acetal (white) A set of 5 pieces YES
B23
BLock
Lock G
Lock F
Part Number : HIF3BAG-**PA-2.54DSA(63)
●Low profile type, and used for lock ejection.
Connector height is reduced.
Since no connector clamp is needed on the cable side,
this is used without turning back on the cable side. Take
care about this point.
B24
27.3
●F Type Lock Pin Header
21.5
●Low Profile Lock Pin Header
●Locking range more reduced than conventional lock type.
Even if connectors are aligned laterally, the mounting
space is reduced.
Note : The clamp must be replaced for HIF3A socket type
60 contacts only. Take care about this point.
■Socket for Crimping
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
HIF3BA-10D-2.54C(63)
610-1041-0 63
10
17.25
10.16
HIF3BA-14D-2.54C(63)
610-1051-3 63
14
22.35
15.24
HIF3BA-16D-2.54C(63)
610-1042-2 63
16
24.8
17.78
HIF3BA-20D-2.54C(63)
610-1043-5 63
22.86
HIF3BA-26D-2.54C(63)
610-1044-8 63
26
37.55
30.48
HIF3BA-30D-2.54C(63)
610-1045-0 63
30
42.63
35.56
HIF3BA-34D-2.54C(63)
610-1046-3 63
34
47.75
40.64
HIF3BA-40D-2.54C(63)
610-1047-6 63
40
55.35
48.26
HIF3BA-50D-2.54C(63)
610-1048-9 63
610-1061-7 63
68.04
60.96
HIF3BB-50D-2.54C(63)
50
HIF3BA-60D-2.54C(63)
610-1049-1 63
HIF3BB-60D-2.54C(63)
610-1062-0 63
HIF3BA-64D-2.54C(63)
610-1064-5 63
HIF3BB-64D-2.54C(63)
610-1063-2 63
60
80.77
73.66
64
85.85
78.74
Polarizing Guide
RoHS
One at center
YES
One right and left side, resp.
One at center
One at center
One at center
Note : Some variations may differ from those in above figures.
B25
■Cover Case for Crimping socket
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
C
D
E
HIF3-20CV(72)
562-0201-0 72
18.0
12.0
30.5
29.95
HIF3-26CV(72)
562-0202-2 72
26
30.2
20.0
14.0
32.0
37.55
HIF3-30CV(72)
562-0203-5 72
30
32.2
22.0
16.0
33.0
42.63
HIF3-34CV(72)
562-0204-8 72
34
34.2
24.0
18.0
33.5
47.75
HIF3-40CV(72)
562-0205-0 72
40
36.2
26.0
20.0
35.5
55.35
HIF3-50CV(72)
562-0206-3 72
50
39.2
29.0
23.0
38.0
68.04
HIF3-60CV(72)
562-0207-6 72
60
42.2
32.0
26.0
40.5
80.77
Note 1 : The type F lock pin header cannot be used for a mating member.
Note 2 : Note that the product cannot be used with AWG #20.
Applicable jacket diameters are as described below.
20 contacts : 1.7mm diameter MAX
26 to 40 contacts : 1.6mm diameter MAX
50 to 60 contacts : 1.4mm diameter MAX
B26
RoHS
YES
BContact (Crimping Contact for Socket)
B27
BTools
●Crimping Tool
Manual Crimping Tool
Part No.
HRS No.
HIF3-T2226HC
550-0063-8
Part No.
HRS No.
CM-105C
901-0001-0
HIF3-T2226HC
●Automatic Crimping Tool (Type : CM-105C)
●Contact Extraction Tools
Part No.
HRS No.
HIF1-PO
550-0049-7
How to use the extraction tool
(1) How to extract contacts
(2) How to adjust the lance (raise)
As shown in Figure 1, where the
extraction tool is inserted in the lance
fixed slot on the insulated case, slightly
pull the cable, and the contact can be
removed.
In order to re-insert the contact
removed from the insulated case,
raise the contact lance area using the
tool A, and re-insert the contact, as
shown in Figure 2.
Figure 1
B28
BSocket Side (Crimping) Assembling Procedures
(1) As shown in Figure 1, peel the applicable cable (AWG#20 to #26) jacket, and connect it using crimping jig HIF3-TA2022HC,
HIF3-TA2226HC, or HIF3-TA2426HC. In this case, insert the cable so as to hit the contact cable stripper position as shown
Figure 2.
(2) After connection as shown Figure 2, check the contact direction, and insert the contact as shown Figures 3 and 4. Slightly pull
the cable, and check whether the contact lance position is firmly fixed to the insulation case, as shown in the area (A).
Note1 : For handling procedures for special crimping tools, refer to the "Handling Instruction Manual".
Note2 : Wire strip length : Refer to crimp condition sheet.
Wire strip length
Figure 1
Figure 2
Figure 3
Figure 4
B29
