4382-4PG-3ES
4382-4PG-3ES
    SWITCHCRAFT
    4382-4PG-3ES
4382-4PG-3ES 数据手册
MULTI-CON-X® FIELD INSTALLABLE CONNECTORS Cable Pin Panel Mount P/C Tail Panel Mount 3X8X-XPG-XXX Matching Mates: • Cable-Cable 4X8X-XXG-XXX Matching Mates: • Cable Pin 4XXX-XXG-XXX Matching Mates: • Cable Pin 5X8X-XSG-XXX 3X8X-XPG-XXX • Panel • Cable Socket 4XXX-XSG-XXX 3X8X-XPG-XXX • Cable Socket 3X8X-XSG-XXX 3X8X-XSG-XXX Cable Socket Cable to Cable Mechanical Back Shell 3X8X-XSG-XXX Matching Mates: • Cable-Cable 5X8X-XXG-XXX Matching Mates: • Cable Pin (Style #5) 5X8X-XPG-XXX 3X8X-XPG-XXX • Panel • Cable Socket 4XXX-XPG-XXX 3X8X-XSG-XXX Square Flange Adapter Square Flange Gasket 4296 4297 Molded Cable Assemblies Cable End ® Dust Cap Winged Coupling Ring 4295 W/4482 (See pages 3 & 26) Cable to Cable Right Angle 601 East Wildwood, Villa Park, Illinois 60181 • Telephone (630) 834-7504 • Fax (630) 834-8540 14 ® MULTI-CON-X® FIELD INSTALLABLE CONNECTORS Dimensions Molded Cable Assemblies (See pages 3 & 26) 1.110 [28.2] 2.000 [50.8] 2.065 [52.4] 1.455 [36.9] CABLE END ASSEMBLY CABLE TO CABLE ASSEMBLY CABLE END ASSEMBLY STRAIGHT BOOT 0.500 [12.7] MAX. CABLE O.D. STRAIGHT BOOT 0.500 [12.7] MAX. CABLE O.D. 90º BOOT 0.365 [9.3] MAX. CABLE O.D. ® 601 East Wildwood, Villa Park, Illinois 60181 • Telephone (630) 834-7504 • Fax (630) 834-8540 15 ® MULTI-CON-X® FIELD INSTALLABLE CONNECTORS Part Number to Order X X XX-X XG-XXX Grommet Code – Cable O.D. Range: Connector Type: 3 - Cable End 4 - Panel Mount 5 - Cable to Cable 15 18 Back Shell 21 Style 24 3 or 5 28 30 - Contact Size: 1 - #12 (2-4 Contacts) 2 - #20 (4-9 Contacts) 3 - #16 (4-6 Contacts) .15 - .17 (3.8-4.3) .18 - .20 (4.6-5.1) .21 - .23 (5.3-5.8) .24 - .27 (6.1-6.8) .24 - .28 (7.1-7.4) .30 - .32 (7.6-8.1) Back Shell Style: Weathertight grommet grip/seal & (1) interfacial “O”ring. 3DC - Daisy chain grommet with 3 I.D.s (.125, .188 & .250) 5 Mechanical screw-down cable clamp with grommet seal. 3 Contact Style: 80 81 82 91 92 - Crimp (Supplied loose) P/C Tail .187" (4.7) (Supplied assembled) Solder Cup (Supplied assembled) P/C Tail .280" (7.1) (Supplied assembled)* P/C Tail .335" (8.5) (Supplied assembled)* Number of Contacts: 2, 3, 4, 5, 6, 7, 8 & 9 300 - Panel mount with hex nut & gasket. 3ES - 300 with Epoxy (Panel Mount Only) Type of Contact: P - Pin S - Socket Contact Plating: G - Gold over Nickel (Standard) EMI/RFI shielded assemblies available - consult factory. *Available in #20 size contact only. Consult factory for optional threaded coupling. Consult factory for your custom design cable assemblies and connectors. (See pages 3 & 26) Contact Arrangements 1 1 2 2 1 4 4 5 1 6 1 5 3 2-#12 4 1 1 3-#12 4-#12* 1 1 4-#16 6 1 7 5-#20 6-#16* 1 1 7 9 7 8 5 4-#20 5-#16* 6-#20 7-#20 8-#20 9-#20 Contact arrangements shown are wiring view of cable end pins/sockets. Key/keyway shown for orientation only. *Available in connector types: cable end socket, panel mount pin, and cable to cable pin styles only. ® 601 East Wildwood, Villa Park, Illinois 60181 • Telephone (630) 834-7504 • Fax (630) 834-8540 16 ® MULTI-CON-X® FIELD INSTALLABLE CONNECTORS Specifications Typical Specifications Manufacturers Identifications Description Rating Conductor Size Configuration Certification Multi-Con-X® Field Installable Connector & Custom Cable Assemblies 1.95 thru 23.0A, 600V #12 Contacts, 12 thru 14 AWG #16 Contacts, 16 thru 18 AWG #20 Contacts, 20 thru 24 AWG 2 thru 4 #12 Contacts 4 thru 6 #16 Contacts 4 thru 9 #20 Contacts UL Recognized File #E138878 - 250V CSA Certified File #LR89277 - 600V Material Specifications Cable Pin/Socket Backshell (Threaded) Grommet Coupling Ring Contacts Connector Body O-Ring Sleeve Nylon, UL Recognized, Black (Style #3) Santoprene Rubber, Black Nylon, UL Recognized, Black Brass, Gold over Nickel Nylon, UL Recognized, Black Nitrile Rubber, Black Nylon, UL Recognized, Black Cable to Cable Backshell (Threaded) Grommet Contacts Connector Body Nylon, UL Recognized, Black (Style #3) Santoprene, Rubber, Black Brass, Gold over Nickel Nylon, UL Recognized, Black Optional Long Backshell (Threaded) Winged Coupling Ring Mechanical Backshell (Threaded) – Strap – Screws Nylon, UL Recognized, Black (Style #3 with solder contacts) Nylon, UL Recognized, Black (W/4482) Nylon, UL Recognized, Black (Style #5) Nylon, UL Recognized, Black Cadmium Plated Panel Mount Contacts Panel Body Gasket Hex Nut Brass, Gold over Nickel Nylon, UL Recognized, Black Nitrile Rubber, Black Nylon, UL Recognized, Black Optional Dust Cap Square Flange Adapter Square Flange Adapter Gasket Santoprene Rubber, Black (Part No. 4295) Nylon, UL Recognized, Black (Part No. 4296) Nitrile Rubber, Black (Part No. 4297) Mechanical Specifications Durability Vibration Minimum 300 mate/unmate cycles without mechanical or electrical failure Coupling rings have overriding locking feature to prevent loosening or separation of connector All series hex nut to withstand 10-12 inch/lb tightening torque Hex Nut Torque Electrical Specifications Voltage Current 600 V See Electrical Current Rating Chart (Page 27) Environmental Specifications Temperature Rating Corrosion Weathertight -55°C to +125°C (-67°F to +257°F) 300 Hr salt spray contacts Consult factory with specific application Molded Cable Assemblies (See Pages 3 & 26) Watertight NEMA 6P, 13: IEC IP67 ® 601 East Wildwood, Villa Park, Illinois 60181 • Telephone (630) 834-7504 • Fax (630) 834-8540 17 ®
4382-4PG-3ES
物料型号: - 电缆端连接器:3X8X-XPG-XXX - 面板安装连接器:4X8X-XXG-XXX - 电缆尾板连接器:4XXX-XXG-XXX - 电缆套:3X8X-XSG-XXX - 电缆到电缆连接器:5X8X-XXG-XXX - 机械后壳(Style #5):匹配型号包括5X8X-XPG-XXX和4XXX-XPG-XXX
器件简介: MULTI-CON-X®连接器是现场可安装的,适用于电缆端、面板安装和电缆到电缆的连接。
引脚分配: 文档中提供了多种接触件配置,包括2-9个接触件的排列方式,具体配置根据接触件大小和数量而定。
参数特性: - 额定电流:1.95至23.0A - 额定电压:600V - 接触件大小:#12、#16、#20 - 导线规格:12至24 AWG
功能详解: 连接器具有多种安装方式,包括螺纹后壳、机械后壳和翼形联接环等,确保了连接的可靠性和耐用性。
应用信息: 适用于需要现场安装和快速连接的应用场景,如工业、汽车和航空电子领域。
封装信息: 提供了详细的尺寸和安装指南,包括螺纹规格、面板切割推荐尺寸和安装扭矩等。
4382-4PG-3ES 价格&库存
很抱歉,暂时无法提供与“4382-4PG-3ES”相匹配的价格&库存,您可以联系我们找货
