FGG.0K.303.CLAC45Z
FGG.0K.303.CLAC45Z
    LEMO(雷莫)
    FGG.0K.303.CLAC45Z
FGG.0K.303.CLAC45Z 数据手册
FGG.0K.303.CLAC45Z www.lemo.com SUMMARY # Wires Low voltage 3 Image is for illustrative purpose only Series 0K Termination type Male solder IP rating 68 AWG wire size 28.00 - 20.00 Cable Ø 4.10 - 4.50 mm Status active Matching parts EGG.0K.303.CLL Download Request a quote Eplan Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet and nut for fitting a bend relief Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 12.01 g Performance Configuration 0K.303 : 3 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 8 Amps Specifications Contact Type: Solder Contact Dia.: 0.9 mm (0.035in) Bucket Dia.: 1.0 mm (0.039in) Max. Solid Conductor: 0.56 mm^2 (AWG 20) Max. Stranded Conductor: 0.56 mm^2 (AWG 20) R (max): 4.8 mOhm LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Vtest (contact-shell): 900 V (AC), 1300 V (DC) Vtest (contact-contact): 1200 V (AC), 1700 V (DC) Others Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +200°C Humidity (max): 1000 hr DRAWINGS Dimensions A L M S2 mm. 11 34 23 7 in. 0,43 1,34 0,91 0,28 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Spanner wrench: DCD.0E.007.PA070 Caps: BFG.0K.100.NAS Cables 130250 PVC Grey 30260 PVC Black 3280 PVC Black LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.0K.303.CLAC45Z 价格&库存
很抱歉,暂时无法提供与“FGG.0K.303.CLAC45Z”相匹配的价格&库存,您可以联系我们找货
FGG.0K.303.CLAC45Z
  • 1+432.703531+56.00897
  • 10+367.7590610+47.60258
  • 30+340.3384030+44.05326
  • 50+328.2980550+42.49476
  • 100+312.64475100+40.46861
  • 250+293.09796250+37.93848
库存:12
