NPPN171FGGN-RC
NPPN171FGGN-RC
    SULLINS
    弯插,P=2mm
    排母 间距:2mm 1x17P 弯插
NPPN171FGGN-RC 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY D 2515 ADD NOTE 10 MATING PARTS. 01/16/2012 LH E 3120 UPDATE PROCESSING TEMPERATURE FOR NYLON 6T MATERIAL AND CURRENT RATING TO 2 AMPS (WAS 1 AMP), UPDATE STRAIGHTNESS TOL 04/15/2015 LH F F E E .110±.008 2.80±0.20 .063±.008 1.60±0.20 D D .079±.002 2.00±0.05 .020 0.50 A±.010[ 0.25] B±.012[ 0.30] .122±.012 3.10±0.30 .047 1.20 C .169 4.30 C .181±.012 4.60±0.30 .008 0.20 02-20, 0.20mm MAX. 21-35, 0.30mm MAX. 36-40, 0.40mm MAX. A±.004[ 0.10] .079±.002 2.00±0.05 B A NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING. 2. CONTACT MATERIAL: PHOSPHOR BRONZE. 3. CONTACT PLATING: .000030"-.000050" MIN NICKEL UNDERPLATE, GOLD FLASH OVERALL. 4. CURRENT RATING: 2 AMP. 5. INSULATOR RESISTANCE: 5000 MEGOHMS MIN. 6. CONTACT RESISTANCE: 20 MILLIOHMS MAX. 7. DIELECTRIC WITHSTANDING: AC 500V. 8. OPERATING TEMPERATURE: -40° C TO +105° C. 9. *PROCESSING TEMP.: WAVE/MANUAL SOLDERING ONLY. 10.MATES WITH SULLINS .079 [2.00] CONTACT CENTER MALE HEADER SERIES. (.020 [0.50] SQUARE POSTS) RECOMMENDED PCB LAYOUT Pb RoHS COMPLIANT 8 7 6 5 B .031±.002 0.80±0.05 4 UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] TOLERANCES: ANGULAR: 5 DECIMALS .X= .012 [.30] .XX= .008 [.20] .XXX= .006 [.15] DRAWN DATE NAME 03/23/2009 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE HEADER FEMALE, 2mm CC, 1 ROW, RA PART NUMBER SIZE C CAGE CODE 54453 SCALE: 4:1 3 2 NPPNxx1FGGN-RC DWG. NO. 10490 SHEET 1 OF 1 1 REV E FILE NAME: 10490, NPPNxx1FGGN-RC A
NPPN171FGGN-RC 价格&库存
很抱歉,暂时无法提供与“NPPN171FGGN-RC”相匹配的价格&库存,您可以联系我们找货
