8
7
4
5
6
1
2
3
REVISIONS
F
REV.
ECO. NO
G
2516
H
2730
DESCRIPTION
DATE
UPDATE NOTE 1 AND ADD NOTE 10 MATING PARTS 02/14/2012
UPDATED PROCESSING TEMP. FOR NYLON 6T AND
UPDATED ROW SPACING TOLERANCE 0.15 mm
(WAS 0.05 mm)
03/18/2015
BY
LH
LH
F
E
E
A±.004 [ 0.10]
B .014[ 0.35]
.100±.002 2.54±0.05
.100 2.54
.100±.002 2.54±0.05
.040±.002 1.02±0.05
D
D
RECOMMENDED PCB LAYOUT
A±.008 [ 0.20]
.102 2.58
.200 5.08
.124±.008 3.15±0.20
.256 6.50
C
.335 8.50
C
.063±.008 1.60±0.20
.100±.006 2.54±0.15
.024(W) X .016(T)
[0.60(W) X 0.40(T)]
.100±.002 2.54±0.05
B
B
02-20, 0.20mm MAX.
21-30, 0.30mm MAX.
31-40, 0.40mm MAX.
A
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING.
2. CONTACT MATERIAL: PHOSPHOR BRONZE.
3. CONTACT PLATING: SEE PART NUMBER CODING.
4. CURRENT RATING: 3 AMPS
5. VOLTAGE RATING: 250V AC/DC
6. INSULATOR RESISTANCE: 5000 MEGOHMS MIN.
7. CONTACT RESISTANCE: 20 MILLIOHMS MAX.
8. DIELECTRIC WITHSTANDING: 500V AC.
9. OPERATING TEMPERATURE: -40° C TO +105° C.
10.MATES WITH SULLINS .100 [2.54] CONTACT CENTER MALE HEADER SERIES.
(.025 [0.64] SQUARE POSTS)
8
7
6
Pb
RoHS COMPLIANT
5
4
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN INCHES [MM]
TOLERANCES:
ANGULAR:
5
DECIMALS
.X= .012 [.3]
.XX= .008 [.20]
.XXX= .006 [.15]
DRAWN
DATE
NAME
2/15/2008
JH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
HEADER FEMALE, .100" [2.54mm] CC, 2 ROW, RA
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 8:1
3
2
xPxCxx2LJBN-RC
DWG. NO.
10494
SHEET 1 OF 1
1
REV
H
FILE NAME: 10494, P(N)PxCxx2LJBN-RC
A
很抱歉,暂时无法提供与“PPTC022LJBN-RC”相匹配的价格&库存,您可以联系我们找货
