Technical Data Sheet
RF_35/05.10/6.0
Dieses Dokument ist urheberrechtlich geschützt ● This document is protected by copyright ● Rosenberger Hochfrequenztechnik GmbH & Co. KG
MultiMag 6
Receptacle
(PCB Termination)
M9K701-400L
All dimensions are in mm; tolerances according to ISO 2768 m-H
General Information
Magnetic connector
Number and type of contacts
Soldering
Color
6 rigid pins
THT
Black, similar RAL 9005
Interface
Mating with
MultiMag 6 cable assembly
Material and Plating
Connector Parts
Contacts
Housing
Magnets
Material
Brass
PBT GF30
NdFeB
P.O.Box 1260
D-84526 Tittmoning
Germany
www.rosenberger.de
Plating/Color
Gold plated
Nickel plated
Tel. : +49 8684 18-0
Fax : +49 8684 18-499
Email : info@rosenberger.de
Page
1/3
MultiMag 6
Receptacle
(PCB Termination)
M9K701-400L
RF_35/05.10/6.0
Electrical Data
Designed for USB 2.0 specification
5 V DC, 0.5 A
Maximum voltage
Maximum current
24 V DC
1A
PCB Footprint
P.O.Box 1260
D-84526 Tittmoning
Germany
www.rosenberger.de
Page
2/3
MultiMag 6
Receptacle
(PCB Termination)
M9K701-400L
Mechanical Data
RF_35/05.10/6.0
Magnetic disengagement force
Mating cycles without load
Expected Mating cycles with load:
average ∼ 8 N
min. 5.000
Max. Voltage
Max. Current
Mating cycles
5.0 V DC
0.5 A
min. 5.000
12.6 V DC
1.0 A
min. 2.000
24.0 V DC
0.5 A
min. 800
Environmental Data
Temperature range
-20 °C to +65 °C
Magnets start losing their magnetic properties above 65 °C
Compliance
RoHS
compliant
Packing
Standard
Weight
100 pcs in blister
∼ 1.1 g/pc
Caution!
Magnets can impact the function of pace makers and implantable cardioverterdefibrillators (e.g. actuation of reed switch). Keep a minimum distance of 0.2 m
(20 cm) between the magnetic connector and the implanted devices to prevent
malfunction and danger to health.
While the information has been carefully compiled to the best of our knowledge, nothing is intended as representation or warranty on
our part and no statement herein shall be construed as recommendation to infringe existing patents. In the effort to improve our
products, we reserve the right to make changes judged to be necessary.
Draft
Date
Approved
Date
Rev.
Engineering change number
Name
Date
T. Scheuerlein
22.06.16
T. Scheuerlein
22.01.20
b00
20-0163
S. Kirchhofer
22.01.20
P.O.Box 1260
D-84526 Tittmoning
Germany
www.rosenberger.de
Page
3/3
很抱歉,暂时无法提供与“M9K701-400L”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+131.78160
- 200+52.58520
- 500+50.82480
- 1000+49.96080
- 国内价格 香港价格
- 1+177.632211+22.97572
- 10+150.9756310+19.52784
- 25+141.5242725+18.30536
- 50+134.7684850+17.43154
- 100+128.33890100+16.59991
- 300+118.77499300+15.36287
- 500+114.57620500+14.81978
