PPPC172LJBN-RC
PPPC172LJBN-RC
    SULLINS
    弯插,P=2.54mm
    排母 间距:2.54mm 2x17P 弯插
PPPC172LJBN-RC 数据手册
8 7 4 5 6 1 2 3 REVISIONS F REV. ECO. NO G 2516 H 2730 DESCRIPTION DATE UPDATE NOTE 1 AND ADD NOTE 10 MATING PARTS 02/14/2012 UPDATED PROCESSING TEMP. FOR NYLON 6T AND UPDATED ROW SPACING TOLERANCE 0.15 mm (WAS 0.05 mm) 03/18/2015 BY LH LH F E E A±.004 [ 0.10] B .014[ 0.35] .100±.002 2.54±0.05 .100 2.54 .100±.002 2.54±0.05 .040±.002 1.02±0.05 D D RECOMMENDED PCB LAYOUT A±.008 [ 0.20] .102 2.58 .200 5.08 .124±.008 3.15±0.20 .256 6.50 C .335 8.50 C .063±.008 1.60±0.20 .100±.006 2.54±0.15 .024(W) X .016(T) [0.60(W) X 0.40(T)] .100±.002 2.54±0.05 B B 02-20, 0.20mm MAX. 21-30, 0.30mm MAX. 31-40, 0.40mm MAX. A NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING. 2. CONTACT MATERIAL: PHOSPHOR BRONZE. 3. CONTACT PLATING: SEE PART NUMBER CODING. 4. CURRENT RATING: 3 AMPS 5. VOLTAGE RATING: 250V AC/DC 6. INSULATOR RESISTANCE: 5000 MEGOHMS MIN. 7. CONTACT RESISTANCE: 20 MILLIOHMS MAX. 8. DIELECTRIC WITHSTANDING: 500V AC. 9. OPERATING TEMPERATURE: -40° C TO +105° C. 10.MATES WITH SULLINS .100 [2.54] CONTACT CENTER MALE HEADER SERIES. (.025 [0.64] SQUARE POSTS) 8 7 6 Pb RoHS COMPLIANT 5 4 UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] TOLERANCES: ANGULAR: 5 DECIMALS .X= .012 [.3] .XX= .008 [.20] .XXX= .006 [.15] DRAWN DATE NAME 2/15/2008 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE HEADER FEMALE, .100" [2.54mm] CC, 2 ROW, RA PART NUMBER SIZE C CAGE CODE 54453 SCALE: 8:1 3 2 xPxCxx2LJBN-RC DWG. NO. 10494 SHEET 1 OF 1 1 REV H FILE NAME: 10494, P(N)PxCxx2LJBN-RC A
PPPC172LJBN-RC 价格&库存
很抱歉,暂时无法提供与“PPPC172LJBN-RC”相匹配的价格&库存,您可以联系我们找货
PPPC172LJBN-RC
    • 1+74.039351+9.48748
    • 10+34.7004410+4.44655
    • 50+29.7885950+3.81714
    • 100+26.50814100+3.39678
    • 500+25.85558500+3.31316
    • 1000+25.361741000+3.24988
    • 2000+25.114832000+3.21824
    库存:11
    PPPC172LJBN-RC
    • 1+19.287771+2.47156
    • 10+16.3930010+2.10062
    • 100+13.93031100+1.78505
    • 500+12.43470500+1.59340
    • 1000+11.841241000+1.51735
    • 5000+11.443485000+1.46638
    库存:572
