FGG.1K.308.CLAC60Z
FGG.1K.308.CLAC60Z
    LEMO(雷莫)
    CONN PLUG MALE 8P GOLD SLDR CUP
FGG.1K.308.CLAC60Z 数据手册
FGG.1K.308.CLAC60Z www.lemo.com SUMMARY # Wires Low voltage 8 Image is for illustrative purpose only Series 1K Termination type Male solder IP rating 68 AWG wire size 30.00 - 22.00 Cable Ø 5.60 - 6.00 mm Status active Matching parts EGG.1K.308.CLL Download Request a quote Eplan Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet and nut for fitting a bend relief Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 22.90 g Performance Configuration 1K.308 : 8 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 5 Amps Specifications Contact Type: Solder Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.8 mm (0.031in) Max. Stranded Conductor: 0.34 mm^2 (AWG 22) Max. Conductor: 0.34 mm^2 (AWG 22) R (max): 6.1 mOhm LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Vtest (contact-shell): 1150 V (AC), 1630 V (DC) Vtest (contact-contact): 950 V (AC), 1340 V (DC) Others Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +200°C Humidity (max): 1000 hr DRAWINGS Dimensions A L M S2 mm. 13 42 28 9 in. 0,51 1,65 1,10 0,35 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Spanner wrench: DCD.1E.008.PA090 Caps: BFG.1K.100.NAS Cables CMN.08.T22.059QGC TPR Grey CMN.08.T22.059QGZE TPR (medical) Grey 16080 PVC Grey 180260 PVC Black 42265 PVC Yellow 80140 PVC Grey LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.1K.308.CLAC60Z
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光隔离型光电开关,具有高灵敏度和高响应速度的特点,适用于各种工业自动化控制领域。
3. 引脚分配:EL817共有6个引脚,分别为Vcc、Out、GND、A、B和C。
4. 参数特性:工作电压范围为5-24V,响应频率为50-60Hz,输出电流为10mA。
5. 功能详解:EL817通过光电转换实现信号的隔离传输,具有抗干扰能力强、稳定性高的优点。
6. 应用信息:广泛应用于工业自动化、医疗设备、安防系统等领域。
7. 封装信息:EL817采用DIP6封装,尺寸为9.1mm x 9.1mm x 4.8mm。
FGG.1K.308.CLAC60Z 价格&库存
很抱歉,暂时无法提供与“FGG.1K.308.CLAC60Z”相匹配的价格&库存,您可以联系我们找货
