NRPN242MAMS-RC
NRPN242MAMS-RC
    SULLINS
    SMD
    CONN HEADER SMD 48POS 2MM
NRPN242MAMS-RC 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY D 2024 HEAD HEIGHT 3.60 WAS 4.00, UPDATE PCB LAYOUT & WARP TOLERANCE 8/11/09 JH 2828 ADD 'LCP' MATERIAL OPTION, UPDATE PROCESSING TEMPERATURE FOR NYLON 6T MATERIAL, UPDATE OVERALL LENGTH TOL TO 0.50mm (WAS 0.35mm), 04/09/2015 UPDATE CURRENT RATING TO 2 AMPS (WAS 1 AMP) E F F LH E E B±.020 [ .50] .157 4.00 D D A±.010 [ .25] .079±.002 2.00±0.05 .079±.002 2.00±0.05 .020 0.50 .142±.008 3.60±0.20 .059 1.50 2X .089 2.25 C 2X .039 1.00 .087 2.20 A .006 [0.15] A C .018±.008 0.45±0.20 OPTIONAL .256±.012 6.50±0.30 C±.008 [ .20] 02-20, 0.20mm MAX. 21-30, 0.30mm MAX. 31-40, 0.40mm MAX. B A±.004 [ .10] C±.004 [ .10] .079±.002 2.00±0.05 .040±.002 1.02±0.05 .047±.002 1.20±0.05 .116±.002 2.95±0.05 .295±.004 7.50±0.10 A NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING, UL 94V-0, COLOR: BLACK. 2. CONTACT MATERIAL: BRASS. 3. CONTACT PLATING: .000030"-.000050" MIN NICKEL UNDERPLATE, GOLD FLASH OVERALL. 4. CURRENT RATING: 2 AMPS 5. VOLTAGE RATING: 150 V AC/DC. 6. INSULATOR RESISTANCE: 5000 MEGOHMS MIN. 7. CONTACT RESISTANCE: 20 MILLIOHMS MAX. 8. DIELECTRIC WITHSTANDING: 500 VAC. 9. OPERATING TEMPERATURE: SEE PART NUMBER CODING. 8 7 6 B .063 1.60 RECOMMENDED PCB LAYOUT Pb RoHS COMPLIANT 5 4 UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] TOLERANCES: ANGULAR: 1 DECIMALS .X= .012 [.30] .XX= .008 [.20] .XXX= .006 [.15] DRAWN DATE NAME 06/15/2005 TT THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE HEADER, MALE 2mm CC, 2 ROWS, SMT PART NUMBER SIZE C CAGE CODE 54453 SCALE: 12:1 3 2 xRPNxx2MAMx-RC DWG. NO. 10495 SHEET 1 OF 1 1 REV E FILE NAME: 10495, NRPNxx2MAMx-RC A
NRPN242MAMS-RC 价格&库存
很抱歉,暂时无法提供与“NRPN242MAMS-RC”相匹配的价格&库存,您可以联系我们找货
