FGG.2B.310.CLAZ
FGG.2B.310.CLAZ
    LEMO(雷莫)
    FGG.2B.310.CLAZ
FGG.2B.310.CLAZ 数据手册
FGG.2B.310.CLAZ www.lemo.com SUMMARY # Wires Low 10 High 0 Coax 0 Triax 0 Quad 0 Fiber 0 Fluidic 0 Series 2B Termination type Male solder IP rating 50 Cable Ø 0.00 - 0.00 mm Status active Image is for illustrative purpose only Download Request a quote Catalog See video assembly instructions Alternative part Matching parts EGG.2B.310.CLL TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated) shell and collet nut, nickel plated brass latch sleeve and mid pieces Variant Weight 25.40 g Performance Configuration 2B.310 : 10 Low Voltage Insulator L: PEEK (UL 94 / V-0/3.2, depends on material thickness) Rated Current 8 Amps Specifications Contact Type: Solder Contact Dia.: 0.9 mm (0.035in) Bucket Dia.: 0.8 mm (0.031in) Max. Solid Conductor: 0.34 mm^2 (AWG 22) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Max. Stranded Conductor: 0.34 mm^2 (AWG 22) R (max): 4.8 mOhm Vtest (contact-shell): 1300 V (AC), 1840 V (DC) Vtest (contact-contact): 1450 V (AC), 2050 V (DC) Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr IP Rating: 50 DRAWINGS Draws Dimensions A L M S1 S2 mm. 15 50 38 13 12 in. 0,59 1,97 1,50 0,51 0,47 RECOMMENDED BY LEMO LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Tools Spanner wrench: DCD.2B.025.PA120 Caps: BFG.2B.100.PCSG Cables CMN.10.T22.068QGC LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.2B.310.CLAZ 价格&库存
很抱歉,暂时无法提供与“FGG.2B.310.CLAZ”相匹配的价格&库存,您可以联系我们找货
FGG.2B.310.CLAZ
  • 1+690.763221+89.11022
库存:7
