Additional Resources:
Product Page
3D Model
date
07/09/2020
page
1 of 3
SERIES: MD-SP │ DESCRIPTION: MINI DIN CONNECTOR
FEATURES
• vertical
• panel mount
• plastic mounting ears w/recess for hex nut
RoHS
PART NUMBER KEY
MD - XX SP
Base Number
Pin Options
30 = 3 pins
40 = 4 pins
50 = 5 pins
60 = 6 pins
70 = 7 pins
80 = 8 pins
SPECIFICATIONS
parameter
conditions/description
min
max
100
12
rated input voltage
rated input current
typ
at 100 Vac
at 12 Vdc
contact resistance
insulation resistance
at 250 Vdc
voltage withstand
for 1 minute
operating temperature
life
RoHS
yes
A
A
30
mΩ
cuidevices.com
250
Vac
4.5
kg
0.9
3
kg
5
80
°C
5,000
UL94V-0
1
2
MΩ
insertion force
flammability rating
Vac
Vdc
50
withdrawal force
units
cycles
Product Page
3D Model
CUI Devices │ SERIES: MD-SP │ DESCRIPTION: MINI DIN CONNECTOR
date 07/09/2020 │ page 2 of 3
MECHANICAL DRAWINGS
units: mm[inches]
TOLERANCE: ±0.2mm
MD-30SP
MD-40SP
2
2
4
1
3
3
1
MD-60SP
4
2
1
3
6
5
4
3
silver
shell
brass
nickel
body
HIPS (PH-88)
housing
NY6+FB (PA-1010C2)
MD-50SP
5
4
2
3
MD-80SP
7
6
1
PLATING
phosphor bronze
1
MD-70SP
2
MATERIAL
pins
5
cuidevices.com
2
1
5
8
4
7
3
6
Product Page
3D Model
date 07/09/2020 │ page 3 of 3
REVISION HISTORY
rev.
description
date
1.0
initial release
02/23/2006
1.01
new template applied
02/09/2012
1.02
updated datasheet
08/25/2017
1.03
brand update
02/19/2020
changed housing mold
07/09/2020
1.04
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“MD-80SP”相匹配的价格&库存,您可以联系我们找货
